Old 02-01-2017, 11:12 PM   #43
exE36M3
Thanks for your reply. Sooo... the 3rd try was successful. I tightened down the bolts until the RTV met the surface and slightly squished out. I let it sit for 24 hours, then tightened down. Dry as a bell.
BUT... turns out, a big part of the leak is/was the valve cover. :\
And THAT is still leaking.
2 weeks before Subaru can look at it.
ArghX2
exE36M3 is offline   Reply With Quote
Old 02-02-2017, 12:46 PM   #44
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
ArghX2
well, glad you got it fixed. it sucks the valve cover is leaking though.
fx1mark is offline   Reply With Quote
Old 04-11-2017, 04:29 PM   #45
DarkSunrise
DarkSunrise's Avatar
I installed the Raceseng cam plate yesterday. Not cheap but a high quality part. I also considered the Velox plate (also nice) but the Raceseng one has indentations to align the three bolts for exact fitment. Probably overkill but I love that kind of attention to detail and I'd rather just do it right the first time.
The instructions call for two dabs of RTV so I used Permatex ultra synthetic oil resistant RTV (purple tube, black color goo). Very easy to install. When cleaning the surface area, I first tried a gasket remover (essentially a plastic razor blade) but it was much quicker using a finger nail. After that it was simple. Torqued to 12 lbs-ft, let it sit 1 hr, torqued to 14 lbs-ft, then let it sit 20+ hrs to be safe.
Today I went for a drive and checked the plate with a rag. No more leak! Good job Raceseng.
2022 BRZ Build
2013 FR-S Build
Old 07-01-2017, 02:58 PM   #46
TMF
TMF's Avatar
Drives: '14 FRS TT5
First, thank you for the how to.
Here's a few of my pointers:
1. Don't take it to the dealer. They had no idea now to fix it properly.
2. I skipped the popsicle sticks.
3. My first attempt failed, because I don't think I used enough red rtv and it was not a very good continous bead. I think I only let it sit for about 5-6 hours at finger tight before torquing to spec.
4. My second attempt was successful, and I think the big difference was that I put down a better, slightly thicker, almost continuous bead of red rtv. The hole in the tip of the rtv applicator was about 1/4". I also let it sit for about 30 hours at finger tight before torquing to spec.
This attempt survived four 20 minutes track sessions, so hopefully no more leakage issues!
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
The Following User Says Thank You to TMF For This Useful Post:
Extreme86 (07-02-2017)
Old 07-03-2017, 08:50 AM   #47
eddieflyinv
eddieflyinv's Avatar
Permatex Ultra Grey 👌 used when resealing the cam plate, camshaft carrier & timing cover, (and put some on a leaking valve cover gasket to since i forgot to order new ones) not a drop of oil exiting the motor since I did this last year
eddieflyinv is offline   Reply With Quote
The Following User Says Thank You to eddieflyinv For This Useful Post:
Opie (03-11-2020)
Old 01-21-2020, 11:12 PM   #48
fungus
fungus's Avatar
Drives: '13 Subaru BRZ ST; '88 MR2 AW11 SC
Hey @Extreme86,
If you still on here, be nice to hear from you and how long the RTV fix lasted?
fungus is offline   Reply With Quote
Old 03-11-2020, 09:01 AM   #49
TMF
TMF's Avatar
Drives: '14 FRS TT5
Update: this failed and leaked. Got the Racer x fab plate instead... Stopped for a while, but still leaks. I've given up lol.
Old 03-11-2020, 02:36 PM   #50
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
This, clean ALL old sealant off, use Permatex Ultra Grey (no RTV) with a nice continuous bead, then torque as per service manual. Never had one leak again.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 06-13-2020, 07:59 PM   #51
daniloneil8
Here is a photo of my cam plate.
Car has not been driven in a few weeks.
Drove it for 10 minutes.
Parked and opened the hood to attach battery tender
Saw white smoke. I see oil down on the exhaust
Has anyone gotten an RTV re-do to work? Which color RTV is best?
Skip RTV solutions, and get a 3rd party o-ring plate ? If so, which one?
Which brand of cam plate has become the accepted replacement?
Adding this video to this thread.
daniloneil8 is offline   Reply With Quote
Old 06-13-2020, 08:13 PM   #52
daniloneil8
Did you use an aftermarket cam plate, or reuse the OEM plate?
You put the red RTV around the entire perimeter of the groove where the o-ring fits?
Old 06-14-2020, 12:13 PM   #53
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Last time I was at the shop (non-dealer performance shop) they found oil on the engine and lower metal plate and asked for close to $1,000 to resolve the leak, without doing investigation for where it was coming from. I am now thinking it's this and am going to do it myself.
What is the consensus, re-seal stock plate or use aftermarket? It seems like the aftermarket doesn't always work, and if done correctly, re-sealing the OEM plate works.
Edit: Just checked the lower engine-side of the cam plate and it's dry as can be. Which is good, but a bummer that oil is leaking from somewhere else.
B-R-Z is offline   Reply With Quote
Oil leak solved - Raceseng billet aluminum cam plate Clipdat Issues | Warranty | Recalls / TSB 156 06-18-2020 12:29 AM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Groupbuys 63 10-18-2013 04:31 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Engine, Exhaust, Transmission 2 09-21-2013 08:47 PM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 01:59 PM
