Old 01-31-2017, 05:18 PM   #267
Qc86
Drives: 2017 Toyota 86 M6
Nice will def get that one then!!!
Qc86 is offline   Reply With Quote
The Following User Says Thank You to Qc86 For This Useful Post:
Strife26 (01-31-2017)
Old 01-31-2017, 08:08 PM   #268
Token11b
Originally Posted by jawnthen View Post
Can you do one from inside? Is there any drone with the stock exhaust?
Sent from my Pixel using Tapatalk
If you're on a stock exhaust the cabin noise is minimal. Can't tell the difference much from stock.
Token11b is offline   Reply With Quote
The Following 2 Users Say Thank You to Token11b For This Useful Post:
jawnthen (01-31-2017), Strife26 (01-31-2017)
Old 01-31-2017, 08:15 PM   #269
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
The front pipe back is where all the noise comes from. At least for me. My exhaust is always the loud part. The header by itself wasn't bad.
Sent from my SM-G930T using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 02-24-2017, 12:58 AM   #270
Cojonudo
I'm New
Cojonudo's Avatar
Drives: 2016 Limited Subaru BRZ White Pearl
I'm thinking about purchasing a Gruppe-S UEL header after reading so many good things about it and can't go wrong with the quality and price, but had a question about the heat shield and if I should get it with the header or not. If anyone can give me some advice on if I should get the heat shield or not it would be greatly appreciated.
"You do you"
Cojonudo is offline   Reply With Quote
Old 02-24-2017, 10:07 AM   #271
max20s14
Drives: 14' Raven M/T - 02' is300
I have been trying to find a leak in mine and when I was underneath the car That heat shield(The one you tape on the oil pan) was pretty warm. So Im thinking it helps keep some heat out of the oil.
And about my leak, If you get the overpipe the gaskets I got Where The paper type with fire rings on the inside. Im thinking I have a leak in one of those connections. I ordered some grimspeed gaskets to replace those and will use some copper exhaust sealant this time... Im just hoping the leak isn't at the head.
Hope that helps
max20s14 is offline   Reply With Quote
Old 02-24-2017, 11:21 AM   #272
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I fitted mine up a few weeks ago. Great quality, and very fast shipping.
The install was very smooth, and the sound is great! Very happy with the product.
BigTuna is offline   Reply With Quote
Old 02-24-2017, 11:41 AM   #273
max20s14
So im hearing an air compressor noise at cold start until the car warms up and under load(above half throttle) all the time anyone else with an exhaust leak does this sound familiar to you?
If the leak was at the head would it sound more like a tick because exhaust pulse?
This is a constant pshhh noise.
I have tried re tightening all the bolts a couple times
Old 02-24-2017, 03:34 PM   #274
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
it's air passing through pipes. if you worry, you actually need to feel with hand or do paper test near flange for leak.
Old 02-24-2017, 03:53 PM   #275
Teseo
Drives: frs
May ask you what is the procesure of paper test
Old 02-24-2017, 04:10 PM   #276
max20s14
yeah I couldn't feel anything at idle but I also don't hear it at idle
Old 02-24-2017, 04:33 PM   #277
zc06_kisstherain
Drives: SWP BRZ
lift your car, and put a paper near flange that header meets for leak.
if there is a leak, paper will dance like a bitch. if no leak, then nothing happens. lol or you can just put your hands near to feel air. (do cold start or you'll burn your hand)
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Teseo (02-24-2017)
Old 03-24-2017, 01:54 AM   #278
Strife26
Strife26's Avatar
I have it. I have checked my oil temps via OBDII and they have always been around the optimal levels. I don't know if the heatshield matters, but with it "installed" my oil temps are right where they should be. I think it's 213~ degrees? Maybe 220, but whatever the temp it was the temp I read it should be at, haha.
I've had the header for a year or more now and I have no issues and still enjoy it. I'll be keeping it when I turbo the brz.
The Following User Says Thank You to Strife26 For This Useful Post:
Carsnguitars (02-24-2018)
Old 03-26-2017, 04:18 AM   #279
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
more than likely, if you turbo the car you'll have to use a different header.
Old 03-26-2017, 05:29 AM   #280
Strife26
Strife26's Avatar
Allegedly I don't. I can keep my headers with the kit I found. Can't wait. Should have it within 1-2 months.
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 09:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 12:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 07:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
