Old 01-29-2017, 09:51 PM   #15611
Ashikabi
Ashikabi's Avatar
Originally Posted by DandoX View Post
Did an oil change, my oil was pretty black after just 5k. I'm at 63k now. I spilt some oil on some wires to the right of the oil cap and it made a mess all the way down to the skid plate I also fucked up and let it run for about 3-4 mins with not enough oil in, got distracted and didn't check the oil level right away. After adding 1 more quart she's now a little more full than I like but still between the dots(just so).
I hate spilling oil, it will annoy me for some time to come.. Any tips on cleaning the engine bays nooks and crannies without a full disassembly?
Car wash. Just hose it down. Use compressed air to get the water out of the places you can't towel, or just let it dry in there
The Following User Says Thank You to Ashikabi For This Useful Post:
DandoX (01-29-2017)
Old 01-29-2017, 10:06 PM   #15612
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I installed a backup camera this week. Driving it Saturday I decided I didn't like the camera angled down like it was. I had the idea of insetting the camera into the trunk garnish. That would allow me to angle the camera as I wanted and I could also make the camera as invisible as possible. I did it today. I made an aluminum bracket and attached it with some strong two sided adhesive foam tape. it seems rock solid. I think it came out pretty good.
fx1mark is offline   Reply With Quote
The Following 6 Users Say Thank You to fx1mark For This Useful Post:
86geek (01-30-2017), Dadhawk (01-30-2017), MJones_RB (01-31-2017), notout86 (02-07-2017), Tcoat (01-30-2017), zeal86 (01-30-2017)
Old 01-29-2017, 10:10 PM   #15613
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
One step closer.
That's very cool, what info will be show in those dials.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
wulfstan (03-02-2017)
Old 01-29-2017, 10:55 PM   #15614
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Little bit of engine degreaser and low pressure water should get rid of whatever mess you made. Anything else will burn off over time if it's anywhere near the engine or exhaust header.
And using a funnel will help keep you from having to aim at the oil fill spout so accurately and cut the risk of mess-making considerably. If you don't have one, a quick DIY in a pinch is to take an empty oil quart and cut it in half. Keep the half with the spout on it and put that in the oil fill spout. Instant funnel.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
DandoX (01-30-2017), wireman957 (01-30-2017)
Old 01-29-2017, 10:59 PM   #15615
Overdrive
Sittin' Sideways
Overdrive's Avatar
Gave the car a rinse at the local touchless car wash. Didn't get everything, but it's way cleaner than it was. Made sure to wipe the door jambs, too, had plenty of salt/dirt/schmutz going on in those that wasn't going to get touched by the wash.
If there was ever a doubt about how thin the metal on this car is, and how little sound insulation it has, sitting in the car during a pressurized wash will clear those doubts right up.
-O/D
2016 FR-S, Hot Lava
Old 01-30-2017, 12:12 AM   #15616
FLESH KILLA
Mr Cool Guy
FLESH KILLA's Avatar
Drives: 2013 Scion FR-S (Raven)
Originally Posted by ToyotaFan84 View Post
I bought the RS 2.0 17" black rims yesterday and picked up my TRD quick shifter as well. I was thinking of waiting until my first maintenance date to have both of them installed but I might just do it ASAP. Once it's done, my FR-S will be fully loaded with TRD parts. =D
Completely agree with Juan. It'll cost you a little more but it's well worth it to let someone else install it. Make sure they use some locktite so it won't come loose. Mine came loose after about a week. Couldn't get to 1st or 2nd. Had to take off in 3rd for a day until I got it fixed.
Sent from my Nexus 6P using Tapatalk
- RAVEN 86 -
FLESH KILLA is offline   Reply With Quote
The Following User Says Thank You to FLESH KILLA For This Useful Post:
ToyotaFan84 (01-30-2017)
Old 01-30-2017, 12:15 AM   #15617
....... be careful next time.
I suggest you use some engine degreaser and a lot of rags.
Get yourself a large funnel, one you can't miss ..........
DandoX (01-30-2017), Overdrive (01-30-2017)
Old 01-30-2017, 11:20 AM   #15618
stevesnj
stevesnj's Avatar
Figuring out where I have to cut the plastic on the passenger side for my Guages. I really don't like cutting.
My 2016 Build thread
Old 01-30-2017, 12:13 PM   #15619
RickyBobby
Drives: 2013 Firestorm FR-S AT
That's a unique solution. What did you use to cut out the rectangular hole? Any problems with water getting in or did you seal up the space around the camera with, i.e., silicone caulking?
RickyBobby is offline   Reply With Quote
Old 01-30-2017, 02:23 PM   #15620
ToyotaFan84
ToyotaFan84's Avatar
Drives: 2016 FR-S
Originally Posted by JohnJuan View Post
I'd recommend having someone else install the QS. It's a pain to get your hands in there.
I have the dealership I bought it from installing everything as we speak.
ToyotaFan84 is offline   Reply With Quote
Old 01-30-2017, 02:43 PM   #15621
fx1mark
fx1mark's Avatar
My intention was to make the hole identical to the shape of the camera. I traced the camera onto the trunk garnish and drilled the four corners. starting with a small drill bit and moving up to one that matched the roundness of the camera. then I used a dremel cutting wheel to cut the straight lines in between. I ended up using a dremel sanding drum to finish the shape. I then used touch-up paint to finish the bare plastic.
The trunk garnish has holes in it for the tag lights. It is not waterproof at all so the camera hole does not need to keep water out either. the camera wire goes through a rubber grommet into the trunk. and should be waterproof.
Here's a shot showing how much of the camera is visible.
The Following 3 Users Say Thank You to fx1mark For This Useful Post:
Dadhawk (01-30-2017), notout86 (02-07-2017), Overdrive (01-30-2017)
Old 01-30-2017, 02:48 PM   #15622
Very well done and a great idea!
Dadhawk (01-30-2017), fx1mark (01-30-2017), zeal86 (01-30-2017)
Old 01-30-2017, 07:25 PM   #15623
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
what am I missing? Looks the same as factory but 5 inches over?
Old 01-30-2017, 07:45 PM   #15624
Overdrive
Sittin' Sideways
Overdrive's Avatar
Missing: It's not a factory piece, nor the factory location. Required "le cutting" in order to put it somewhere that didn't have a home for it already. Remember, backup camera only showed up in the last couple of model years thanks to federal government requirements.
-O/D
2016 FR-S, Hot Lava
