Old 01-29-2017, 07:13 PM   #71
Teseo
Drives: frs
Originally Posted by ftc~brz View Post
oh, hi......
Where the hell you have been? Say hi to uncle
The Following User Says Thank You to Teseo For This Useful Post:
ftc~brz (02-13-2017)
Old 01-29-2017, 07:21 PM   #72
chaoscentral
Drives: 2013 Scion FR-S Series 10
Originally Posted by MRS-Colin View Post
That's the real trick. The factory DLC will be getting the emissions monitors directly from the GM PCM. No trickery.
Now if there was a way to do that for a 2JZ ECU... (I'm getting greedy I know but I honestly couldn't decide between an LS engine and 2JZ engine)
But thank you for bringing this to market. I'll have to pick one of these up in the coming months so I am prepared no matter which direction I end up in going and it helps support the community(plus I need that push button start stuff working so the more preorders the better right :-) )
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
The Following 2 Users Say Thank You to chaoscentral For This Useful Post:
ILLSMOQ (01-30-2017), MRS-Colin (01-29-2017)
Old 01-29-2017, 07:27 PM   #73
MRS-Colin
Drives: 2001 Impreza 2.5 RS
As far as I know, there were never any CAN bus equipped 2JZ vehicles from the factory. Just about every 2JZ implementation in a vehicle will use some sort of stand alone ECU. If your ECU of choice has CAN bus outputs and a well documented format, I could easily make a revised program that would handle the basic functions most people require. Don't even think about cruise or a properly functioning VDC.
Tach/PS/MIL/Coolant temp/current gear(maybe)?
Check.
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following User Says Thank You to MRS-Colin For This Useful Post:
chaoscentral (01-29-2017)
Old 01-29-2017, 07:39 PM   #74
chaoscentral
Check.
My big thing is to pass a plug in emissions test and no lights on the dash, other than that I'm good lol
Old 01-29-2017, 08:11 PM   #75
MRS-Colin
You could always hook up all the emissions devices, crank sensors, and oxygen sensors from a factory ECU that would use the pre-CAN communication protocol, have a standalone ECU *actually* controlling the engine, and just don't populate the OBD DLC with CAN lines and you'd pass most (stupid) plug in tests.
Who you would possibly be able to pay to do that, I don't know.
Oh and that's kind of illegal
Heck you'd be better served finding someone who would program a device that would live on the CAN bus and respond to the SAE PIDs for emissions monitors and have it just always report back everything is chill
...again, very illegal.
Not much you can really do with an engine that never had a factory CAN connection to report the proper values to the emissions tester. I can think of a million ways to potentially do it, and a million ways I'd get sued by the EPA.
Colin Beck
The Following 4 Users Say Thank You to MRS-Colin For This Useful Post:
chaoscentral (01-29-2017), civicdrivr (02-01-2017), Sportsguy83 (01-30-2017), wparsons (01-29-2017)
Old 01-29-2017, 08:17 PM   #76
chaoscentral
so in other words LS swap it is, problem solved lol
The Following User Says Thank You to chaoscentral For This Useful Post:
Old 01-29-2017, 08:20 PM   #77
MRS-Colin
I meaaaaan.
GM does pride itself in providing emissions compliant packages you can buy at a dealer. This kind of sells it for me.
Track whore/no emissions state, go for it. Its 2017 though, can't just blow off the tech side of vehicles anymore.
Colin Beck
The Following 2 Users Say Thank You to MRS-Colin For This Useful Post:
chaoscentral (01-29-2017), wparsons (01-29-2017)
Old 02-02-2017, 09:11 PM   #78
MRS-Colin
Weapons Grade Performance tested one of our modules and push button start is working well!
Colin Beck
The Following 9 Users Say Thank You to MRS-Colin For This Useful Post:
all4spl (02-02-2017), Calum (02-03-2017), cf6mech (02-22-2017), civicdrivr (02-08-2017), DustinS (02-02-2017), ILLSMOQ (02-03-2017), Sportsguy83 (02-03-2017), Zer0 (02-08-2017)
Old 02-02-2017, 10:37 PM   #79
all4spl
congrats @MRS-Colin
all4spl is offline   Reply With Quote
Old 02-03-2017, 06:20 AM   #80
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Awesome news!
ILLSMOQ is offline   Reply With Quote
Old 02-10-2017, 03:09 PM   #81
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Got these bad boys in the mail today!
The Following 7 Users Say Thank You to Sportsguy83 For This Useful Post:
cf6mech (02-22-2017), civicdrivr (02-18-2017), Draco_PR23 (02-22-2017), DustinS (02-14-2017), ILLSMOQ (02-10-2017), M1K3 (02-11-2017), wooly35 (02-10-2017)
Old 02-10-2017, 03:11 PM   #82
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Look great! can't wait to see the rest of the engine.
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (02-10-2017)
Old 02-22-2017, 09:42 AM   #83
gtpvette
Drives: 2015 FRS - FFR GTM
Sportsguy,,, a couple of questions. You mentioned a shop KAB that will be doing the work. Are they local??? As for the bits and pieces to mount the engine and trans,, is the plan to fabracate these or use someones kit?? What about headers and exhaust, radiator, AC compressor brackets, etc. etc. I know there's a thousand things have to be done, do you a general idea of the details you might share???
It's going to be a super hot rod!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 02-22-2017, 09:40 PM   #84
vgi
Drives: frs
This is a simple N/A build, not a full retard twin charged monster.
, we'll see once you're done with the build and drive it for some time...
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
Sportsguy83 (08-01-2017)
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
