Old 01-26-2017, 10:56 PM   #183
chaoscentral
Drives: 2013 Scion FR-S Series 10
If I could make this work and pass a plug in obd emissions I'd be all set. Sadly I don't believe it is possible with that Motec setup
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 01-26-2017, 10:58 PM   #184
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Why won't the link embed the video ?
Pure Automotive is offline   Reply With Quote
Old 01-26-2017, 10:58 PM   #185
ft86me
ft86me's Avatar
Drives: 2013 FRS
Video is working! Just watched it !
ft86me is offline   Reply With Quote
Old 01-26-2017, 11:31 PM   #186
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Congrats, I love it!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 01-27-2017, 07:29 AM   #187
Apex-Apex
Apex-Apex's Avatar
will you guys be making a harness for the m150?
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 01-27-2017, 07:31 AM   #188
Calum
That Guy
Drives: 2013 asphalt FRS MT
I can't open it at work. :'(
Old 01-27-2017, 08:16 AM   #189
M1K3
M1K3's Avatar
Drives: vrooom...
Here you go embedded:
[ame="https://www.youtube.com/watch?v=YR_kQgv4lts"]Pure Automotive's Plug and Play 2JZ Swap Electronics Package - YouTube[/ame]
M1K3 is offline   Reply With Quote
Old 01-27-2017, 08:28 AM   #190
Pure Automotive
It is possible, but we have most of what you would need on the M130 and still have a couple spots un dedicated. Why m150 ?
Old 01-27-2017, 08:58 AM   #191
Apex-Apex
Apex-Apex's Avatar
I only ask because I have a M150 already and was interested in the possible expandability for it.
IG: @apexapexapex
Old 01-27-2017, 10:18 AM   #192
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
When linking youtube videos. Take the "S" out of "HTTPS" and it will embed.
Old 01-27-2017, 10:33 AM   #193
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I think also because Pure's link was youtu.be
I think it needs to be youtube dot com/etc..
Old 01-27-2017, 10:51 AM   #194
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The a and b connectors on the 150 are mostly inputs and outputs, and the extra can bus channels. I have a 150 in my swap and only have a couple extra inputs going to those connectors. I could have gotten away with a 130 on mine and I have individual egt's, coolant pressure, exhaust map, etc
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 01-27-2017, 02:02 PM   #195
Apex-Apex
Apex-Apex's Avatar
All good, I already have the 150 so no going back now.
IG: @apexapexapex
Old 01-27-2017, 03:19 PM   #196
spitfire481
Drives: 2JZ FRS
i was in the same spot, already had the 150 from my built fa20 when we started doing the 2j swap/package on this car and realized a 130 would work just fine and save some money. i need to match up the diagrams again but im almost positive the m130 connectors on our swap harness will plug right into c and d on the 150 ecu, then the a and b can be populated as you add more down the road. my initial harness only has c and d populated, i didn't add anything to a or b until later on.
MoTeC
Build Thread
@spitfire481
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 08:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
