Old 01-25-2017, 09:37 PM   #15
Blew the welds on the intake with that hundred shot of nos.
FISHBURGLAR (01-27-2017), Varelco (01-26-2017)
Old 01-26-2017, 03:05 AM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
That was a 75er, GOD ULTRA CANT YOU READ?! lol
But in all seriousness; sounds incredibly close to the valves. So either header leak (not torqued down properly or cracked), or the head gasket is blown.
It seemed to rev too freely for burnt valves.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Ultramaroon (01-26-2017)
Old 01-26-2017, 01:33 PM   #17
That's a cracked header. Too big for a loose flange at the port. You would also hear two pops.
There, I said it.
cdrazic93 (01-26-2017)
Old 01-26-2017, 06:00 PM   #18
dallenj
Drives: Grey FR-S
Hopefully its not a blown head gasket. I should be able to find out tonight or tomorrow what is wrong. Thanks for all the help.
dallenj is offline   Reply With Quote
Old 01-26-2017, 07:26 PM   #19
chaoscentral
Drives: 2013 Scion FR-S Series 10
Blown head gasket has a tell tale white smoke, I agree with everyone, sounds like exhaust.
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 01-26-2017, 08:13 PM   #20
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thumbs down
the bracket on the j2 that bolts to the trans has broken off so that might have put some extra stress on the header.
Then why the fuck are you in this thread? Fix the KNOWN PROBLEM then come back. Of course that's the problem and it may have started new issues.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
tCsonfrs (01-27-2017)
Old 01-26-2017, 11:03 PM   #21
Fuck me. I missed that part too.
Old 01-27-2017, 10:47 PM   #22
dallenj
Drives: Grey FR-S
Here is an update. Pretty sure its an exhaust leak in missing 2 header bolts one on the drivers side one on the passenger side. Ill know for sure in just a little bit when I start my car and underneath it.
Unrelated but I notice an oil leak coming from what I think is my exhaust vvt housing. Shown at the end of the video.
Old 01-27-2017, 11:15 PM   #23
Let me just jot down that VIN. What did you say it was?
Old 01-27-2017, 11:22 PM   #24
tCsonfrs
Drives: 10 Series FR-S #207
At 20 seconds you can CLEARLY see that your header is missing a bolt, fix that or just get ride of that 1320 header, they're garbage IMHO.
tCsonfrs is offline   Reply With Quote
Old 01-27-2017, 11:33 PM   #25
dallenj
Drives: Grey FR-S
just done under the car and its an exhaust leak out of where the bolt is missing. I noticed the bolts gone. I posted the video for oil leak I found.
Old 01-28-2017, 12:44 PM   #26
dallenj
Drives: Grey FR-S
Fixing the exhaust didn't fix the issue any other ideas?
NX Plate kit with a 75 shot
1320 Headers
J2 Front Pipe
Greddy Evo3 Cat Back
Old 01-28-2017, 01:20 PM   #27
DJCarbine
Thupercharged
DJCarbine's Avatar
Start car while securely on jackstands
Check every inch of pipe in header, joints between header/OP/Mid pipe
Keep wedding tackle away from moving parts
If confirmed not exhaust, then confirm the noise is coming from engine
Long screwdriver with metal tip on engine/parts and your ear on the handle makes an expedient mechanics stethoscope to see where the noise is loudest
Injectors are loud, cold engines are loud, an overpipe resting on the subframe is hell
Check everything you possibly can and report back
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-28-2017, 07:08 PM   #28
FRS Justin
Drives: 2013 Asphalt FRS
well you could take it to the dealer and get your front cover resealed and while its off they can see if your dowel pin fell out on the chain tensioner guide.. plus your oil leak is fixed. or you could drop the oil pan and see if the pin is in the pan...
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
no sale, rekt
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Supercharger and blown engine Triumphrider Forced Induction 81 10-21-2014 03:49 PM
Blown Engine kombatlion Forced Induction 27 06-18-2014 06:21 PM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 05:04 AM
