Drives: 2015 brz series blue
Anyone have a sickspeed shift knob? looking for info..
Hey guys,
i'm looking for more info/pics on sickspeed shift knobs. i was specifically looking at these parts: Item #:GRN GLOW KNOB 12X1.25 Item #:BLK RLO-2 Here are the web links: https://www.sickspeed.com/product/de...p75032-c697957 https://www.sickspeed.com/product/de...p74577-c683590 Just curious if anyone has used these shift knobs and how they fit with regards to the reverse lock-out, or how the adapter works? anyone got any pics of one installed? (yes i have searched) Thanks!
#3 | |
Spun
Drives: 23' Supra
hmmm...a glow in the dark knob and a thicker piece of material for the R, lockout. Should fit fine, but I was much happier when I went for a weighted knob, that made a much bigger difference. I suppose I don't see the appeal of this. |
#4 | |
Drives: stx class lava frs
Can you expand a bit on the difference that a weighted (I assume heavier than stock) knob makes? |
#5 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#6 |
placebo
#7 |
Drives: 2017 manual BRZ
I'm guessing it just crunches into the gears more easily.
Sent from my Pixel XL using Tapatalk |
#8 |
It's cheap, and i like round knobs. I find stock a little too thin.
Plus for some reason I like glow in the dark stuff, must be the kid in me! Sickspeed has some nice knobs, just wondering if anyone has installed one and how the fitment is!
#9 |
Shiftknob choice or a perceived performance advantage isn't a placebo or anything like that, it's a preference. It's the object that your hands interact with the second most on the entire car.
Some people want different shapes or stuff that looks cool, and some people want either heavier or lighter knobs. Again it's all preference. Aesthetics aside, there is some obvious physics to go along with a heavier or lighter shift knob. It's just like swinging a heavier or lighter hammer. A lighter knob is going to be able to start moving easier, but isn't going to have the momentum through the shift of a heavier knob. This will completely change the way your shifts feel and can sometimes be the difference between something that is very notchy or buttery-smooth. I find that most people prefer a heavier weighted knob on cars equipped with short shifters. With the change in mechanical advantage of the short shifter it requires an increased effort to get into gear. The heavier weight (and extra momentum gain) from a weighted shift knob can alleviate that increased effort, and really changes how the shift feels. The weight will also change the way you feel the vibrations from the transmission coming through to your hand. More weight = more damping. I barely feel anything with my weighted knob, but I sure do feel a lot when i switch to my delrin knob. So there is a ton of preference and aesthetics in shift knobs, but there is also a method to the madness and some not so obvious physics at play. Don't forget how these metals react to temperature changes. A very large metal shift knob will get hot when its very hot out, and it will get cold out when it's very cold out due to its large thermal mass. A delrin knob or plastic or even glass knob will be more resistant to these temperature changes, but usually won't have the weight advantage (or disadvantage if it's not your thing). We carry both weighted stainless knobs, and delrin shift knobs for that exact reason. But if you want the best of both worlds look at Raceseng's lineup of knobs, as they have weighted delrin in some pretty sick designs. Chase Engineering |
| The Following 4 Users Say Thank You to GrimmSpeed For This Useful Post: |
#10 | |
Would these physics be good for the transmission?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (02-04-2017) |
#11 | |
But that would be a ridiculously heavy shift knob, something in the range of 10lbs. Whereas a heavy weight shift knob is around 1-1.25lbs. So the forces are significantly lower than the situation where you're resting your hand on the shift knob constantly while driving. So in short, any additional wear would be negligible from weight alone. And as far as increased wear from shifting into gear very aggressively? You can expect that to be the same. it's a very short momentary force, and pretty much unnecessary, especially with a weighted knob. So again, no negligible difference or damage to the transmission as a result. Chase Engineering |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | jcw99 (02-04-2017), Ultramaroon (01-25-2017) |
#12 | |
I take issue with the assertion that a weighted shift knob somehow magically allows for faster shifting. As far as personal preference, of course! I'm always fiddling with custom setups.
#13 | |
![]() But just for super-duper-clarification for anyone who might read this: A weighted shift knob isn't going to give you faster shifts. It's strictly a personal preference thing as far as how you like your shift to feel. Buy what you like, and if you don't like it then try again! Chase Engineering |
#14 |
Spun
Drives: 23' Supra
I think others touched upon it, but I purchased a Textured and Weighted shift knob. There is a 'feel' to it. The throws feel smoother and faster, because you have the weight of the knob, on your side. Like someone else said, you touch the shifter so much in the car, it was worth the 40-50 bucks to me.
| The Following User Says Thank You to Timmy_Jones For This Useful Post: | jcw99 (02-04-2017) |
| SOLD: Whiteline Positive Shift Kit Bushing, Moddiction Shift Knob | immaculate | Transmission and Driveline | 4 | 12-30-2016 06:52 PM |
| Shift Knobs - Sickspeed | merdok12 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-16-2016 02:45 PM |
| SOLD: carbing shift knob infocus shift boot digital camo | toby714 | Interior Parts (Incl. Lighting) | 6 | 07-02-2015 09:33 PM |
| FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob | Unidentified | Interior Parts (Incl. Lighting) | 2 | 01-06-2014 09:55 PM |
