Old 01-25-2017, 03:29 PM   #15
VABeachBRZ
I agree David is the man!
Time to break this bad boy in some more
VABeachBRZ is offline   Reply With Quote
Old 01-25-2017, 05:28 PM   #16
Cybmx
Drives: 2016 Hyperblue Brz
I have this similar issue with the clutch/flywheel. When the car is cold, everything is prefect, but after a long drive over 30mins the take-off will get really jerky and shaky. Once the car is moving there is no issue.
Cybmx is offline   Reply With Quote
The Following User Says Thank You to Cybmx For This Useful Post:
VABeachBRZ (01-25-2017)
Old 01-25-2017, 05:49 PM   #17
VABeachBRZ
Same exact issue as me. How many miles do you have on the clutch?
Old 01-25-2017, 05:52 PM   #18
Cybmx
About 6000 miles. Mostly track miles and travel between tracks. Did about 600 stop and go traffic to break it in, don't remember it having the take-off issue early on.
Old 01-25-2017, 06:14 PM   #19
VABeachBRZ
Hmm. Yeah I'm only at 600 miles. I'm hoping with more miles it gets better. But until then, I'll go though the motions and slow it down.
Maybe it's the new grabbing point and me not being use to it.
Old 01-25-2017, 06:56 PM   #20
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Please note that these clutches grab harder with heat. It's part of the "sport" nature in them especially when you're running hard on the track. You want that level of consistency while shifting. Again, please take the time to relearn the vehicle. Deliberate actions lead to deliberate results and the final product is smoother and much more efficient driving techniques. Happy driving folks.
CounterSpace Garage is offline   Reply With Quote
Old 01-25-2017, 07:11 PM   #21
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Could you suggest a clutch with higher clamping loads what would offer close to the same feel as stock (of course given the heavier feel).
http://www.ft86club.com/forums/showthread.php?t=112791
This was my experience with mine
umpadupa is offline   Reply With Quote
Old 01-25-2017, 08:11 PM   #22
CounterSpace Garage
The marginal increase in pedal pressure and improved response with the ACT kits are fine with us. The factory clutch kit is actually quite good. Improving one's driving habits and skills improves the life of the clutch significantly.
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Old 01-25-2017, 08:42 PM   #23
CSG Mike
CSG Mike's Avatar
I've seen many people complain about this. Work on smoothing out your technique, and change your window of overlap and throttle, and you can get a perfect start, every time.
If you make it a conscious effort to improve your technique, you will be able to drive this harder-grabbing clutch in stop and go traffic without issue.
If I can drive the heavier, grabbier XT version without issue in stop and go, so can you
Remember, the clutch will seem hypersensitive relative to stock.
dp1 (01-25-2017)
Old 01-25-2017, 09:40 PM   #24
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Is there much chatter with this clutch?
Jmonty is offline   Reply With Quote
Old 01-25-2017, 09:49 PM   #25
VABeachBRZ
I've had very little. Not much at all honestly. But I've only had it on for 600 miles
The Following User Says Thank You to VABeachBRZ For This Useful Post:
Jmonty (01-26-2017)
Old 01-25-2017, 11:33 PM   #26
umpadupa
umpadupa's Avatar
Awesome! thank you! It would be nice if my comp stage3's pressure plate would release property haha
i can deal with the engagement no problem, its the fact that i get locked out of certain gears when fully clutched in. or when im in first gear no gas and clutched in, my rpms drop and car rolls. Kill me.
Old 01-26-2017, 07:18 AM   #27
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well, I will chime back in once i have had a chance to drive mine. But i still can't believe this is going to be more difficult than my old twin disc Exedy. It chattered (doesnt bother me) all the time, and it was like a razor sharp on/off switch. No room for error.
I thought my left foot work was good, but that clutch made me slow down, and my left foot became almost surgical while driving with that clutch.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-26-2017, 12:08 PM   #28
CSG Mike
CSG Mike's Avatar
The HDSS is much easier than that Exedy.
The HDSS in my S2000 (a much older and MUCH higher clamping force) clutch in my s2k, paired with a prolite flywheel, requires more precision than the XTSS in the CSG BRZ, or the XTSS in my friend's WRX.
In fact, the XTSS engagement from current designs has a heavier pedal but smoother engagement than the (very old) HDSS in my s2000.
Surgical precision...
Bimble Bamble (07-11-2018)
ACT HD clutch. SB7-HDSS slightly used SOLD SOLD SOLD xkalelx Transmission and Driveline 2 04-09-2016 11:22 PM
Scion installed vs dealer installed fog lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 10 02-16-2014 12:55 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 12:09 AM
