Old 01-19-2017, 08:35 AM   #1191
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Ryaquinn is offline   Reply With Quote
The Following User Says Thank You to Ryaquinn For This Useful Post:
CarzCarzCarz (01-20-2017)
Old 01-24-2017, 03:41 PM   #1192
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by 6-Shift View Post
That was awesome!
Thanks man I appreciate that. Still learning.
Shady195 is offline   Reply With Quote
Old 01-28-2017, 03:51 AM   #1193
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
My first time out! Granted, this video was from April 2016-but I finally spent the 10 minutes putting it together. I'm by no means "good" even now that I've been out a few more times, but I can definitely tell I've improved when I look at the footage from my more recent events.
Some parts have the gopro up by the front bumper, and you can REALLY hear the supercharger whine!
[ame="https://www.youtube.com/watch?v=hhgigK2Qqvk"]First Time Drifting In the FRS At Grange Motor Circuit With Drift Access - YouTube[/ame]
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
6-Shift (02-12-2017), CarzCarzCarz (01-30-2017)
Old 01-28-2017, 11:33 AM   #1194
Shady195
Looking good man!
Id say from quickly looking at your video you just need to a carry a little more speed. A few of those spinouts probably would not have happened had you carried a little more speed in.
It's actually a lot easier to control the car at speed than it is with a slower entry.
That supercharger also sounds amazing.
The Following User Says Thank You to Shady195 For This Useful Post:
continuecrushing (01-28-2017)
Old 01-28-2017, 01:31 PM   #1195
continuecrushing
Originally Posted by Shady195 View Post
Looking good man!
Yeah, my buddy pointed out my speed thing after watching me one of the runs...I go a bit faster now, but it's what I'm focused on now!
It was crazy how much easier it got when I started ebraking instead of trying to power over. Power over worked okay for me, but the ebrake made it a lot more controllable for me. I was scared at first to try it, but once I did I was hooked.
Appreciate the tip though!
Old 01-28-2017, 05:31 PM   #1196
Shady195
Its all situation dependent. I like to initiate with a flick. I honestly haven't used my e-brake much, this year was the first time I really used it and it but it was generally when I needed to scrub speed/make a tight transition. I'm going to practice with it more this year.
continuecrushing (01-30-2017)
Old 01-28-2017, 08:22 PM   #1197
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
^What he said. It's all situation dependent.
I never really used "power over" because the car has no "power" to "over" with lol. I typically stuck with aggressive feints or clutch kick entries. Handbrake works too, but I did everything I could to keep from using the handbrake. Using the handbrake stops wheel speed and then you have to get that wheel speed back up to keep the drift going. Not an issue with a car that makes power, but with a lower powered car, it can be a struggle depending on course layout.
Only time I ever really used handbrake was on transition or to adjust my line. Most of the time I just left-foot brake and keep the throttle pinned.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
CarzCarzCarz (01-30-2017), continuecrushing (01-30-2017)
Old 01-30-2017, 11:59 AM   #1198
Shady195
Yeah, with an N/A car the handbrake can really ruin the speed needed for entry. The hardest part about driting the FR-S N/A is keeping the momentum up. On big tracks I imagine thats not to much of an issue, but for smaller/parking lot type events, its hard to get enough speed to use the brake and maintain your momentum without really beating the hell out of the clutch.
Now that I have a turbo, its nice to be able to scrub all that speed and have the power to gain it back when getting back onto power.
When I was N/A i pretty much used nothing but the weight of the car and the occasional clutch kit, only downside was if I ever had to make a big correction I could pretty much count on my drift coming to an end
CarzCarzCarz (01-31-2017)
Old 01-30-2017, 12:18 PM   #1199
TylerLieberman
Drives: '24 GR86
This becomes especially apparent when chasing during tandem. If the lead car makes a mistake and scrubs speed, you're basically SOL haha. I've had that happen a few times when the front car makes a mistake and scrub a shit ton of speed.... just to watch them power off, while I clutch kick 5 times to try and keep the wheels spinning.
If I ever build another one, I think I'd almost certainly go with a turbo setup. The Stage 2 N/A setup was awesome, but with tandem, it doesn't leave a lot of room to make adjustments in the chase position.
Old 01-30-2017, 02:25 PM   #1200
Shady195
The few times I started to tandem while I was still N/A I had to lead and pray I didn't screw up and throw the other guys off. I tried to follow a few times but I h ad to carry A LOT of speed in at our local drift lot and it honestly was a bit scary and I felt like I was pushing my luck each time. Id basically get right on their door and have to trust them to get back on power and pull away because even just left foot braking a little could make or break it.
I love my Turbo setup, doesn't make gobs of power or torque but its enough to make keeping speeds up pretty effortless.
Old 02-05-2017, 10:53 PM   #1201
TylerLieberman
Drives: '24 GR86
Lmao this is just ridiculous
http://www.speedhunters.com/2017/02/...ate-drift-car/
The Following 4 Users Say Thank You to TylerLieberman For This Useful Post:
CarzCarzCarz (02-06-2017), eherschend (02-05-2017), ERIC86 (02-08-2017), FLESH KILLA (02-05-2017)
Old 02-06-2017, 04:29 PM   #1202
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Wow..... haha pretty cool though!
gatorbushmen is offline   Reply With Quote
Old 02-06-2017, 08:04 PM   #1203
TylerLieberman
Drives: '24 GR86
I saw you had that accident recently. Nice to see you're alright. At least the car is pretty easily fixable.
I say you just say YOLO and do this Full tube front and errrthang
The Following User Says Thank You to TylerLieberman For This Useful Post:
Shinchu (02-16-2017)
Old 02-07-2017, 10:41 AM   #1204
richie incognito
Drives: BRZ- all the colours
cool to see nob still running D1.
Curious why they would make such a janky looking mount instead of just fabbing it like 1inch further out.
richie incognito is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
