Old 01-23-2017, 01:09 PM   #435
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Mim View Post
As easy as it might be to swap out a damper for some, I'm still taking it back to the same workshop if I need any swapped down the line. Aside from the peace of mind knowing it was done correctly, they also warranty their work.
Going on a yearly interstate drive this week so will be funky taking the car up to higher cruising speeds than my regular 80kph. Should glide at the 110kph limit on this suspension. Will also be watching in amusement for any change in fuel economy.
I will probably make DIY when i do mine. question is when..lol
Old 01-23-2017, 04:22 PM   #436
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Tein flex z is amazing for DD, spirit drive, and mountain, and i am going to the track next month and see how it does on track.
I drop -1.2 front, and -0.8 rear, -3 camber front and -2.5 rear, 4 click front and 7 click rear, the car grip like a crazy.
However, my previous coilover FA prime 8k spring feel more respond than tein 6k, but 8k spring is really hurt my back for DD, so I switched flex z.
If you want to lower your car but dont have budget, tein flex z will probably the best.
FR-Sky is offline   Reply With Quote
Old 01-26-2017, 06:41 PM   #437
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
3 flicks (from full stuff) front 4 or 5 clicks rear for the track. If you have aftermarket sway bars then can loosen more. That was on -2/-1.5 0toe. I just switched to -3/-2 today and will be at the track on Feb 4-5. I'll post thoughts on the change.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
FR-Sky (01-26-2017)
Old 01-26-2017, 08:56 PM   #438
FR-Sky
FR-Sky's Avatar
lol are we going to the same track, my track date is 2/4 as well.
i have 0.5 toe in for the rear.
Old 01-27-2017, 12:23 PM   #439
Bramick
Bramick's Avatar
Not unless you'll be in Dallas. I'll be a MSR Cresson
Old 01-27-2017, 08:01 PM   #440
FR-Sky
FR-Sky's Avatar
lol nevermind,,i am in CA
Old 01-28-2017, 08:12 AM   #441
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Anyone think the new Flex-A's would be worth the extra cash?? http://www.tein.com/products/flex_a.html They are a Flex-Z with the new Hydraulic bump stops.
oldgunfan is offline   Reply With Quote
Old 01-30-2017, 02:17 PM   #442
zc06_kisstherain
Drives: SWP BRZ
if you prefer comfy ride like stock, then go for it.
Old 01-30-2017, 02:35 PM   #443
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
How are peoples Flex Z's holding up?
I've been a huge fan of the ST coilovers, and have run them and been trusting them on many friend/customer cars for DD duty, but since Tein has reinvigorated their DD low price point segment I'm really curious to 'take one for the team'/see if ST needs to be worried about their market share.
I've been debating which setup to get this spring since I just sold my Swifts.
JazzleSAURUS is offline   Reply With Quote
Old 01-30-2017, 03:25 PM   #444
zc06_kisstherain
Drives: SWP BRZ
I installed mine last fall so not enough time for long term reliability but it's holding up fine.
Old 02-09-2017, 04:30 PM   #445
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I've had mine since December 2015 and haven't had any issues with them. I haven't tracked them, but do spirited mountain drives once or twice a month.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
rcm47 (03-08-2017)
Old 02-10-2017, 07:27 AM   #446
Bramick
Bramick's Avatar
After installing front/rear whiteline sway bars I left the car on 8 clicks from stiff. Track day was great. I'm atleast 12 track days in about 1.5 yrs. Teins are still working
Old 03-02-2017, 01:06 PM   #447
trinidadj
Drives: '16 FRS-MT Ablaze Red
Hey Everyone!
Could one of you guys snap a couple pics of the manual for the Tein Flex Z with the diagram and table showing the factory measurements (Those A,B,C,D measurements between the collars). I bought some used and have no idea how to set them back to factory height of 1.3 inches. Someone please help me! I'm trying to install them this Saturday! Thanks for all your help! Here are my coils
-J
trinidadj is offline   Reply With Quote
Old 04-22-2017, 08:00 AM   #448
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Hey guys, I just installed my Tein Flex Z's and my rears are still pretty high up (to me at least). I saw on Tein's website that the rears are supposed to drop -3 inches, and I don't think I'm near that even when fully maxed out. Has anyone had any issues dropping the rears? Thank youu!
WRB BRZ
BRZSteve is offline   Reply With Quote
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
