#16 |
Weight Weenie
Drives: 15 FR-S
| The Following 3 Users Say Thank You to new2subaru For This Useful Post: |
#17 | |
Drives: Scion FR-S
Instagram: @racecar_4life
#18 | |
Proud of BOXER
Drives: Subaru Boxer
Still waiting. The suspense is killing me!
| The Following User Says Thank You to Clipdat For This Useful Post: | stevesnj (01-20-2017) |
#19 | |
You have no idea how many troll threads read exactly like yours. All it needed to finish it off was to say that the car needs at least 300HP, a Rocket Bunny kit and that MT was the only true sports car and you would have put the troll meter into overdrive. You scared me! ![]() For your reading pleasure (and to check before asking basic questions) http://www.ft86club.com/forums/showthread.php?t=96158
#20 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If someone is crawling up your tailpipe, it's their problem, not yours.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Clipdat (01-20-2017) |
#21 |
Drives: 2017 Halo 86
As requested!
Woohoo! This car is a blast to drive.
| The Following User Says Thank You to Lakitu For This Useful Post: | Clipdat (01-23-2017) |
#22 |
#23 |
Feeling like thinking....
To the O.P...
If this is your first manual transmission, you're probaby shifting way to0 early if your goal is to accelerate quickly. I don't know what you drove prior to this car, but chances are pretty good it was quieter; you may not have been aware of what rev-range your engine was in. An automatic transmission does exactly what it sounds like it does; it "automatically" chooses what it feels is the best gear to be in for a specific scenario (light acceleration? cruising? uphill? downhill?). If you step on the gas hard from a stop, an auto car will stay in lower gears longer to aid in more rapid acceleration. If you gingerly step on the gas, it'll shift sooner and gain you better fuel economy. In your new manual car, YOU get to make those decisions! Folks who call this car "slow" have either never driven a truly slow car, aren't shifting properly for their desired response for the car, or are comparing it to muscle cars or more expensive sports cars (Yeah, it's a generalization.. I know... shoot me). If you want to have some fun (and you're in a situation where you're not going to put anyone around you in danger.. read that clause again, please...), from a stop stay in first gear until you're up around 15mph or so (or more.. I like to get into second a little early.. that seems to be the real power gear in this car), then shift into second and step on it. You'll be at 55 before you know it. I'm guessing at the shift point from first to second; I drive mostly by ear and by feel. If you read enough posts on this forum, you'll read lots of talk about the power band. Once you get above 3500rpm, the car really comes alive. Of course, once you've achieved your goal of getting to your desired speed as quick as possible, shift into an appropriate gear for maintaining that speed efficiently.. probably 6th if you're cruising at 55 and not climbing steep hills. You DON'T have to slam from one gear to another at the speed of light; that's counter-productive. The momentum will carry your acceleration for a bit while you shift, so take it slow and don't smack your new baby. Welcome. Barry |
#24 |
I can make a video of my driving, capturing the RPMs with my phone, and the street with my dash cam.
For upshift, I generally do at 3K up to 4K. So like you say, maybe I need to shift earlier when in 1st to 2nd, there is almost no speed gain from dead stop to 3K being 1st, even though the car sounds like its moving fast lol. It's kind of funny, doing all that work, not going anywhere. Is this what people mean by "rice"? Maybe 1st is only to get the car moving, get those wheels pushing, because it has so much power it but there is almost no acceleration until between 2nd and 3rd. 3rd gear is where I get major boost in speed. I'm also somewhat gentle on the pedal, I'm not flooring. I'm gradually pressing the gas, gradually releasing the clutch. For downshifts, I do at 2K rpm, which puts rpm at 3K~ rpm in the next gear. I noticed something interesting when downshifting that if I don't press the gas, it feels like it doesn't want to take to the new gear in speed when the clutch engages. For lack of better word, it feels and sounds "wrong". So when I tap the gas pedal as the clutch engages, and it takes just fine! No idea what this means. And for sudden needs to downshift to make a turn I clutch->neutral->break->turn (moving by momentum in neutral), then to accelerate I try to guess at where I can safely pick back up at based on the mph, which comes out around... @1st: 0-5ph @2nd: 5-15mph @3Rd: 15-25mph @4rd: 25-35mph @5th: 35-45mph I don't always turn in neutral though. I keep the gear in gear, break and turn and pray that the car doesn't stall as the mph drop as I break for the turn. Back in my first week of owning the car, I made some bad mistakes with downshifting. If the gear is too low, the engine revs up high, freaked the hell out of me. (thankfully never redlined). Gear too high and car sounds like he's gurgling low pitch. Gotten better with knowing when to downshift just by looking at the meter. Another interesting thing I found, I'm not sure if its bad or ok, but when I put the shifter in 2nd from 1st, I can hear the sound of thick metal snapping into place, like a hard "thud". I wonder if people outside my car can hear that sound? It's almost like cracking a neck. Does not always happen though. I once somehow also got the car stuck in a stall loop where it would turn off, then turn back on, then turn off, then back on, car was chugging. I'm still sad that happened, hurt me deep. that was my 2nd week, never happened again. But there was another time where the car stalled, turn off, and somehow recovered. And I stalled once trying to impress from friends. Embarrassing as fuck. Fun learning process, though. Apparently steep, according to some articles. |
