Old 01-19-2017, 01:01 PM   #309
50% split for me. All depends on who you ask!
What do your wife and kids say?
gravitylover (01-19-2017)
Old 01-19-2017, 01:06 PM   #310
Still a 50% split (even though there are only 3 of them). Wife mostly thinks I am an asshole when I start laughing at 3am on a Saturday.
My cat agrees that you are a 100% asshole though. He hates you.
nos145 (01-25-2017), Ultramaroon (01-19-2017)
Old 01-19-2017, 02:15 PM   #311
lol
Old 01-19-2017, 02:48 PM   #312
gravitylover
They know I'm an asshole I mean, they tell me all the time
The Following User Says Thank You to gravitylover For This Useful Post:
Ultramaroon (01-20-2017)
Old 01-20-2017, 12:43 PM   #313
martiniam1
They won't fix mine, because the supercharger voids the warranty. I tried to explain that they obviously released the TSB because a lot of people were complaining supercharger or not. But they don't care of course, and offered to fix it for 3k. Doesn't bother me that much.
martiniam1 is offline   Reply With Quote
Old 01-20-2017, 03:45 PM   #314
Tokay444
Supercharger doesn't void anything. Print out the Magnuson Moss act and slap someone with it.
Old 01-20-2017, 03:57 PM   #315
Probably not in this case (fuel pump) but it can void the engine warranty if it can be shown to put the engine outside design specs. Ford did this successfully with a TSB on diesel trucks where they showed that a commonly used aftermarket tune/chip caused the engine to exceed the limits of the head gasket (I think it was 2005).
Old 01-20-2017, 09:05 PM   #316
Tokay444
That sounds all well and good. A warranty cannot be voided. Claims can be denied. There is a difference.
Old 01-21-2017, 08:51 PM   #317
Resolute
in the recliner of rage
Drives: Asphalt FR-S
Just brought my 2016 home from the dealer with the new Denso second-gen HPFP. No crickets the whole way home, but there was a strong fuel smell outside the car when I got it in the garage. Took off the HPFP cover (surprised by the heavy gauge of steel they used for that part) and found a leak. Literally squirting fuel out of a connector. Upon closer inspection, it also appears that one of my direct injectors may be leaking at its head seal. Bummer.
Resolute is offline   Reply With Quote
Old 01-21-2017, 09:47 PM   #318
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I would tow that shit back.
N1rve
Old 01-21-2017, 10:04 PM   #319
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Yep. This is exactly the sort of thing you bring your car in for to be repaired under warranty.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-21-2017, 10:17 PM   #320
stevesnj
stevesnj's Avatar
Take pics and call them to pick it up.
My 2016 Build thread
Old 01-23-2017, 01:54 AM   #321
pitheindefinite
Drives: 2015 Scion FRS
Got mine replaced few months back. Over 5K now with no crickets.
pitheindefinite is offline   Reply With Quote
Old 01-23-2017, 09:33 PM   #322
Resolute
Yep. Had it towed back and they sorted it out today. Picked it up this evening and so far so good. Will keep an eye on it for leaks, and will give an update in a few months on how well the new pump is working. Hopefully, the crickets are gone for good with this new pump.
One thing that I find interesting with this second generation pump is the inclusion of a reduced fuel pump cam lift profile on the intake cam of the 2017 engines. Obviously, the 2017 ECM is designed with different fueling parameters to match the reduced fuel pump flow rate, but retrofitting the newer pump to the older engines means the new HPFP is operating with a more aggressive fuel pump cam profile, and consequently, at a higher output than the 2017 engines. This makes me wonder if the new pump design was optimized for use with the milder fuel pump cam profile, and using it with the 1st gen camshafts will result in lower pump life, or an eventual return of the crickets that would otherwise not appear in a 2017 engine.
The Following User Says Thank You to Resolute For This Useful Post:
funwheeldrive (02-11-2017)
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 06:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
