#58 |
Site Moderator
Drives: ichi 86 Project
Which one FA? EJ? Well either way, no. At least not that I know of.
#59 |
insta: f_de_pinho9
Drives: Toyota GT86 Std
#60 |
Drives: Firestorm FR-S '13
Has any one had or heard of ISR formerly known as ISIS? Trying to figure is this would be a good buy. They have a good reputation within the 240 community. (Didn't where to post this)
![]() Sent from my iPhone using Tapatalk |
#61 | |
Mr.Fujitsubo
Drives: 2018 STI
It matters more for catbacks, front pipes and headers. The only main issue you can run into with the overpipe is fitment issues. If your on a budget, I'd just opt out for the Tanabe Over Pipe. One of the cheapest and Tanabe is generally a good Japanese comany. By the way. The 240 community is a bad example of what parts to buy since most buyers are cheap/broke
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
| The Following User Says Thank You to Mr.Impreza For This Useful Post: | Teseo (01-18-2017) |
#62 | |
Thank you. I didn't really think of the cheap/broke part. I'm more concerned in the fitment issue. I have read the DC pipe is longer and makes everything shift over if you want it to fit. Thank you once again Sent from my iPhone using Tapatalk |
#63 |
Drives: 2016 FR-S
I have the Tanabe overpipe. Inexpensive, ~$150 and no fitment issues
#64 |
Drives: 2016 BRZ HyperBlue, 2015 WRX Red
Using the Tomei EL header and Tomei overpipe. Fitment was perfect. My last BRZ had a Perrin overpipe on it. I agree with other observations, there aren't too many ways to reinvent the wheel with the overpipe. They're all tricky to install, though it's made easier if you can unbolt the motor mount on that side and jack that side of the engine up about 1.5". The heat-shielding on the OEM part makes it incredibly difficult to extricate, otherwise.
#65 |
Does anyone know which over pipes are 3" with no fitment issues?
I already have FBM turbo with 3" down pipe and JDL 3" catted front pipe, so I need a 3" over pipe.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
#66 | |
Drives: 2017 BRZ
#68 | |
Drives: 2017 CWP BRZ Limited (MT)
I don't know about the EL, but the UEL fit perfectly with the OEM skid plate. |
#69 |
Drives: Man
Header Overpipe compilation thread
We have done some dyno testing on the header. Most of the power is made at the mid-top end range. The peak gains were 10hp and 6 torque.
#70 | |
Drives: Toyota GT86
And which header? Catted or catless? Can you post the dyno? Any other mods on the exhaust apart header? |
| FR-S and BRZ Exhaust Compilation Thread | Spd229 | Engine, Exhaust, Transmission | 666 | 03-11-2026 04:10 PM |
| Tint Compilation Thread | diirk | Cosmetic Modification (Interior/Exterior/Lighting) | 232 | 10-06-2025 06:17 PM |
| Supercharger Kit compilation thread | ichitaka05 | Forced Induction | 25 | 06-24-2020 06:14 PM |
| Headlight compilation thread? | AMG Rush | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 05-21-2017 02:22 PM |
