Old 01-18-2017, 09:31 AM   #2647
bdtbdtbdt
Drives: 2015 Scion FRS
Ok, I got my sh*t figured out. I was trying to put 9" (45mm offset )wheels with 245/40/17 bridgestone RE71 's on the front. I got bad tire clearance( - 1/2") against the front lower spring and perch. I thought I was screwed. I ordered some 25mm spacers. After studying my set up, I realized my whiteline cam bolts were set to full negative camber. I set them for full positive camber and ended up with about 1/4 " clearance, no spacer. Whew! I ordered some adjustable top plates to fix my camber problem. The back wheels and tires fit good. This size is probably the widest practical for a DD. I searched the SCCA solo rules hard. It looks like spacers will bump you from STX to SP. Thanks for all your help. This forum is GREAT!!
bdtbdtbdt is offline   Reply With Quote
Old 01-18-2017, 09:35 AM   #2648
M0nk3y
Spacers are legal in ST trim. You can run whatever spacer you want.
Old 01-18-2017, 01:10 PM   #2649
renfield90
The Stig's German cousin
A 10mm spacer will solve a lot of your problems, assuming you have lengthened studs.
The Following User Says Thank You to renfield90 For This Useful Post:
jbailey8748 (07-10-2017)
Old 01-18-2017, 01:34 PM   #2650
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Spacers don't bump you to SP. And, you probably only needed 5-8mm for clearance on 9" +45.
tigermack is offline   Reply With Quote
Old 01-18-2017, 04:20 PM   #2651
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
My 20mm whiteline is relatively quiet, gotta really crank down on those endlink nuts, I think the whiteline links kinda suck, they're on my list of things to replace, probably with just hardware store parts like I did for my rear end links.
Hell maybe just try the stock endlinks for a day if your dampers aren't totally whack on the mounting points.
Just the other day one of the nuts from my whiteline front end link completely vanished while driving.... It left the end link just banging around not attached to the sway bar at all. I got a replacement nut but there's no guarantee it won't just fall off again.
ハチロク is offline   Reply With Quote
Old 01-23-2017, 02:19 PM   #2652
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Hey guys!
If any of you are on DRIVETRIBE_ I made a Street Touring tribe. Still not public because I need 10 members so PM me with your name on there and/or a screenshot of your profile so I know who's who and I'll add you to the tribe...once we get 10 it'll be public for the world to join
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 01-23-2017, 05:39 PM   #2653
renfield90
Originally Posted by Silver Ignition View Post
Hey guys!
Explain what Drivetribe is? I've heard the name but know nothing about it and don't use it. Feel like I'm on enough forums as is...
Old 01-24-2017, 08:32 AM   #2654
Silver Ignition
APEXHNTR
In short; it's facebook, tumblr, pintrest, instagram and youtube combined into one app and it's cars, all the cars and nothing but the cars.
There's no drama, no BS, no politics....just fucking cars...and its amazing
#1867 of 2500
Old 01-24-2017, 11:38 AM   #2655
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
*yet
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
finch1750 (01-24-2017), justint5387 (01-25-2017), renfield90 (01-25-2017), sugoi (01-24-2017)
Old 01-29-2017, 09:17 AM   #2656
bslate3
Drives: 2015 CWP BRZ
What front sway bar is everyone running?
Yesterday I did my first autocrossers I installed RCE T2 coilovers and a WRX rear sway bar. I also have a Perrin 19mm front sway bar set on stiff. I was using this bar the last 2 years in CS.
I had oversteer everywhere. I disconnected the rear sway bar and it drove so much better but had mid corner push.
How big is too big for the front sway bar?
bslate3 is offline   Reply With Quote
Old 01-29-2017, 10:06 AM   #2657
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
I'm running 22mm white line on hard and it's perfect. Stock in the back.
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 01-29-2017, 12:52 PM   #2658
cjd
cjd's Avatar
Drives: 2017 BRZ
Strano front, stock rear. Also have higher rear spring rate...
The fast setups seem to be the front bar you already have or the Whiteline 20mm (Strano is similar to the stiffer setting)
I'd try stock rear bar before going any bigger in the front.
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (01-29-2017)
Old 01-31-2017, 06:35 PM   #2659
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Depends on spring rates... My FRS had 400f/450r with the WL 22mm on soft in front with stock rear. It was neutral if not slightly pushy in sweepers, but transitioned/slalomed like none other. New car will likely get 400 square with a 20mm whiteline bar up front, but depends on how that sits with the new bigger stock rear bars. Might have to go to the 22 again on soft.
trippinbillies40 is offline   Reply With Quote
Old 01-31-2017, 06:44 PM   #2660
e1_griego
e1_griego's Avatar
Drives: Many
I'm on 400/400, strano bar in front and whiteline 16mm rear bar in back. I added the rear bar right before nationals so it will take some tweaking as the season starts this year. Swapping to racer-x endlinks first things first.
e1_griego is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
