Old 01-14-2017, 09:06 PM   #253
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by Silverfox View Post
Just get the Diode reverse light kit to use your stock tail lights.
So which lights end up acting as reverse lights? The brake lights? Do you switch the signals to switchback LEDs and have them act as reverse lights?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-14-2017, 09:16 PM   #254
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Your amber turn signals would now be the reverse lights and your brakes lights are dual purpose. The video below shows you what it does at the end of it. First part is the install.
[ame="https://www.youtube.com/watch?v=kuZz7Kih0Ck"]Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ - YouTube[/ame]
Shneegle is offline   Reply With Quote
The Following 8 Users Say Thank You to Shneegle For This Useful Post:
AceHeader-MT (01-15-2017), Calum (01-16-2017), cbryant514 (01-28-2018), Overdrive (01-14-2017), RJasonKlein (01-15-2017), Silverfox (01-14-2017), Ultramaroon (01-14-2017), whataboutbob (01-17-2017)
Old 01-14-2017, 09:40 PM   #255
Pat
Pat's Avatar
Drives: 2023 BRZ
Wow, what a slick, elegant and effective match for this exhaust. Thanks for sharing that.
The Following 4 Users Say Thank You to Pat For This Useful Post:
AceHeader-MT (01-15-2017), Calum (01-16-2017), Silverfox (01-14-2017), Ultramaroon (01-14-2017)
Old 01-15-2017, 10:35 AM   #256
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by [url="https://www.youtube.com/watch?v=kuZz7Kih0Ck"
Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ - YouTube[/url]
Now that still uses the stock reverse lights so it it be as easy as unplug the stock connection? If so too easy
Jmonty is offline   Reply With Quote
Old 01-15-2017, 10:41 AM   #257
Reamer
Drives: 2015 FRS
You need to replace the amber turn signal incandescent lights with white LED's also. Besides that it is mainly just plugging in some wires. Only tools needed is a flathead for the plastic clips, pliers to tap into the reverse light power, and 20 minutes of free time from what I gathered from the video. Haven't done it yet but I definitely will be before the catback install.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following User Says Thank You to Reamer For This Useful Post:
Silverfox (01-15-2017)
Old 01-15-2017, 02:08 PM   #258
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Yeah I'm ordering mine today as well. A few guys from SD86 have the kit and they claim it's an extremely easy install.
Silverfox is offline   Reply With Quote
The Following User Says Thank You to Silverfox For This Useful Post:
Reamer (01-15-2017)
Old 01-15-2017, 02:58 PM   #259
Reamer
Drives: 2015 FRS
Just ordered mine along with 2 exhaust hole covers. FT86SF are probably thinking I messed up and accidentally ordered both. I'll get a street diffuser shortly after to eliminate any concerns about added drag too. The install does look super easy though.
Sent from my HTC 10 using Tapatalk
Old 01-15-2017, 04:39 PM   #260
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
FYI, I've been running the Diode Dynamics Tail as Turn kit for almost 2 years now. Works wonderful and actually more effective at lighting dark areas than the stock reverse light, even though I've deleted it.
The Following 2 Users Say Thank You to NLSP For This Useful Post:
Reamer (01-15-2017), Silverfox (01-15-2017)
Old 01-15-2017, 04:45 PM   #261
Jmonty
I've got that from the video but it also had the stock connection/ plugged into. So my question was do you just disconnect that plug down to the stock reverse lights and are good to go?
Old 01-15-2017, 05:27 PM   #262
Jmonty
Well exhaust and lights from Diode Dynamics on order, let the waiting game begin.
The Following 2 Users Say Thank You to Jmonty For This Useful Post:
Old 01-15-2017, 05:44 PM   #263
Reamer
Drives: 2015 FRS
Oh you're talking about the lights that this exhaust will be replacing? Yeah, I think you just disconnect and forget about em.
The Following 2 Users Say Thank You to Reamer For This Useful Post:
Jmonty (01-15-2017), Jrdad (01-16-2017)
Old 01-16-2017, 03:52 PM   #264
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Guess I'll have to see if the Tail as Turn kit works with a '17.
I'm assuming it won't though since it doesn't have any bulbs... And the reverse would be amber...
Old 01-17-2017, 07:20 AM   #265
Calum
That Guy
Drives: 2013 asphalt FRS MT
You could likely swap them with an earlier models tail lights. I doubt it would be hard to find someone willing to swap.
Old 01-17-2017, 03:13 PM   #266
Andrew025
Andrew025's Avatar
No way I'm doing that
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 04:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
