Old 01-11-2017, 03:30 PM   #2633
e1_griego
e1_griego's Avatar
Drives: Many
My strano bar with shorter whiteline endlinks is silent.
I get a couple noises from the rear whiteline bar/endlinks, but I'm ditching the whiteline links for racer-x spherical one that aren't just perma-bound like the whiteline setup.
e1_griego is offline   Reply With Quote
The Following 3 Users Say Thank You to e1_griego For This Useful Post:
DocWalt (01-11-2017), smg1138 (01-11-2017), strat61caster (01-11-2017)
Old 01-11-2017, 05:08 PM   #2634
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Which Whiteline endlinks are you using? If I remember correctly, the ones that they include with their bars are too long. Did you special order those?
smg1138 is offline   Reply With Quote
Old 01-11-2017, 05:50 PM   #2635
e1_griego
e1_griego's Avatar
Drives: Many
They're KLC180-195.
The Following User Says Thank You to e1_griego For This Useful Post:
Old 01-12-2017, 08:23 PM   #2636
smg1138
smg1138's Avatar
They're KLC180-195.
Oh, yeah, I tried to get some of those last year and never could find them in stock anywhere. What was your impression of them?
Old 01-12-2017, 09:08 PM   #2637
e1_griego
e1_griego's Avatar
Drives: Many
They're endlinks? they work?
Old 01-13-2017, 10:38 PM   #2638
AxisPower
Drives: 23 GT4RS
Just wondering what the "legality" of the new irp shifter is:
http://www.ft86club.com/forums/showthread.php?t=111626
The rulebook states "Any mechanical shift linkage may be used" so it should be all good, just wanted to check here to be sure.
AxisPower is offline   Reply With Quote
Old 01-13-2017, 11:04 PM   #2639
redlined600
redlined600's Avatar
Drives: Fr-s
I don't think you can remove the shift/trans stabilizer.
I'd say not legal, unless you could leave that part in (which I doubt).
redlined600 is offline   Reply With Quote
Old 01-13-2017, 11:43 PM   #2640
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
I'm putting one in. I probably should have asked for a clarification first lol! I'll run it until someone says otherwise.
RiskyTrousers is offline   Reply With Quote
Old 01-14-2017, 06:33 PM   #2641
cjd
cjd's Avatar
Drives: 2017 BRZ
That's not just part of the shifter mechanism? From what I can tell, everything you remove is a part that moves when you shift (or holds those parts, exclusively). I guess I need a better diagram of what comes out.
edit: Ok, it's clear not everything moves. It's not clear that it does anything other than hold the shifter, though. The difference is the stock shifter mounts to the transmission vs the car frame. I think.
Old 01-16-2017, 06:23 AM   #2642
bdtbdtbdt
Drives: 2015 Scion FRS
Can any one tell me if wheel spacers ..(25mm) are legal in STX class?
I need them for perch rubbing issues
bdtbdtbdt is offline   Reply With Quote
Old 01-16-2017, 12:04 PM   #2643
cjd
cjd's Avatar
Drives: 2017 BRZ
Based on the fact that they are explicitly called out as allowed for stock (with the limitation that they must maintain the offset rules outlined) and the fact there is an open allowance for wheels, as long as the width meets the rules... I think they'd be allowed.
That said, that's a lot of offset change. Something seems off here to me with your setup (it could be you're not trying to be competitive, but don't want to be illegal either... or something. I should stop guessing.)
C
The Following User Says Thank You to cjd For This Useful Post:
Shark_Bait88 (01-16-2017)
Old 01-16-2017, 12:17 PM   #2644
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
C
On springs only maybe? Less inside clearance but could be locally competitive possibly.
Old 01-16-2017, 12:26 PM   #2645
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm not sure that would fit, for other reasons - at 35 offset and 255/40/17 with -3.3f/-2.2r camber I'm awfully close to being too close to the fenders.
Old 01-16-2017, 12:36 PM   #2646
finch1750
finch1750's Avatar
Good point. On springs with +55 offset? Lol
You had the right idea. Im gonna stop guessing now
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
