Old 01-13-2017, 07:36 PM   #29
He had an account on here but ichi banned him for trolling too much.
Old 01-13-2017, 08:00 PM   #30
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by guybo View Post
Get the battery properly charged up (either with your own charger- 6A overnight or 20A for a few hours or at a garage for a few hours) and you'll minimize the permanent damage done to the battery for longer battery life.
If you try to drive it around to charge it up, you'll decrease battery life and most likely in a few weeks have battery issues again.
No you won't.
Scrappydoo is offline   Reply With Quote
Old 01-13-2017, 10:21 PM   #31
Originally Posted by Scrappydoo View Post
No you won't.
Wrong ....... again, there Scrappydoo .......
Old 01-13-2017, 10:32 PM   #32
Songha
Songha's Avatar
Drives: 2013 Scion FRS
Originally Posted by Impureclient View Post
So I left my trunk not latched last night and I guess that drained the battery down to nothing sitting about 24 hours. Shouldn't that have taken longer to drain it so badly?
Like dead as in nothing but one tiny light was lit up on the dash, super dead.
Is that normal for this car? Usually the lights will go off after a few minutes inside but I never thought about whether the trunk light will do that.
I never had a car battery drain like this. The trunk is hard to see if it's shut fully on this car so I guess it was bound to happen but on a newish(1.5 yr old, not sure how
much that converts to in Canadian years) battery just running that trunk light, that seems kind of odd.
I got into an accident the day before Thanksgiving. I was rear ended, this left my trunk unable to close leaving my trunk light on. My battery drained and I wasn't able to start it without a jump. I didn't think of jumping it cause I didn't know it caused it. I assumed the accident caused my car not to start.
2013 Scion FR-S | 6-MT | Raven Black | Performance Mods: Invidia N1 Catback, Invidia Catless Frontpipe, BC Racing Extreme Lows Coilovers, 1320 Performance UEL Catless Headers, 1320 Performance Overpipe, OpenFlash Tablet (Stage 2 UEL, 93 Oct. tune), Whiteline Front Swaybar, Whitelight Adj. Front Endlinks | Asthetic Mods: DS Style Front Lip, Rocket Bunny style flares, F1R F21s | MY BUILD THREAD!
Songha is offline   Reply With Quote
Old 01-13-2017, 11:14 PM   #33
You know what they say an assumption ...... "it's the mother of all f***ups" .....
Ultramaroon (01-14-2017)
Old 01-14-2017, 10:29 AM   #34
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
...... what the heck is wrong with you, SLVRSRFR ........ THAT is waaaaay too simple.
K.I.S.S.
Keep It Simple, Stupid.
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following User Says Thank You to SLVRSRFR For This Useful Post:
humfrz (01-14-2017)
Old 01-14-2017, 04:37 PM   #35
Originally Posted by SLVRSRFR View Post
K.I.S.S.
Yep, a old and good military acronym ......
Old 07-22-2021, 06:02 PM   #36
DikensCarol
Drives: ft 86
The car has some problems. And I, too, faced a problem like yours. The light bulb in the trunk discharged my battery to zero. I found out that it was just a bad bulb installed, and it will always drain the battery that way. But I found a solution to the problem. I purchased a LED light at https://www.amazon.com/Vont-Hurrican.../dp/B00NPLSZF8 , and it is an indispensable thing in my trunk. And plus my battery does not interact in any way and I am calm. The moral is, if you are using bulbs, it is better to check them 100 times before installing them in your car. But I won't trade my light for any cool bulb.
DikensCarol is offline   Reply With Quote
Old 07-23-2021, 12:03 AM   #37
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by DikensCarol View Post
I hope you will troll less!
irony.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
LimitedSlip (07-23-2021), Tcoat (07-23-2021), Ultramaroon (07-23-2021)
Old 07-23-2021, 06:06 AM   #38
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Canadian battery shelf life years may be indeed shorter since 1 of the battery's biggest enemies is (extreme) cold/heat.
I can no longer recall but the stock battery has just "adequate" Reserve Capacity, Amp Hour, & C20 (battery features explained here: https://www.autobatteries.com/en-us/...ement/overview ) & can easily be drained by halogen bulbs such as that in the trunk or map light.
If you still have halogen lights in critical areas such as trunk, map, vanity, door, etc. it's best to switch to LED to reduce the battery drainage & overall power consumption. A 194 halogen bulb in the trunk is about 5 watts whereas a brighter LED only consumes 1w.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 07-23-2021, 11:53 PM   #39
soundman98
soundman98's Avatar
led's are efficient they said...
they won't run your battery down they said...
Ultramaroon (07-24-2021)
Relocating Battery to trunk ML Engine, Exhaust, Transmission 35 08-03-2015 01:58 PM
Anyone else kill their battery with the trunk? nocwage Scion FR-S / Toyota 86 GT86 General Forum 24 07-23-2014 10:25 PM
Auto-Hauss Dual Trunk Light Introuctory Price! Light Up The Rest Of Your Trunk! Auto-Hauss Interior Parts (Incl. Lighting) 10 03-11-2013 11:55 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 05:32 PM
