Old 09-24-2015, 09:54 PM   #1
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
Installed My Protekt Skid Plate
Hello all. Just recently installed my Protekt skip plates on my BRZ. Even though I plan on replacing my bumper due to some damage on it, decided to do a test install because I was flushing out my brake system. I am running on Hotchkis springs, so its about an inch drop, so every now and then I scrape.
Some the holes that are in the plate (counterbore holes) which use the stock clips to help align it, and some holes (countersunk holes) that you will have to drill in the bumper. All hardware are sunken in, so dont have to worry about grinding those down.
Its pretty straight forward with the install, just remove these clips.
Then remove this front tray.
As you can see, I,ve been scraping it for awhile
Oh you will want to remove the clips that hold in the fender liner for easier access to some the holes.
After you reuse the pre-existing holes to clip on the plates, you then can start drilling the holes in the bumper.
And tightening the bolts is easy enough to with the under tray removed and the front underbody of the fender linings are removed.
All in all, I wish I had these installed previously because this would have prevented a lot front bumper scraping, especially leaving drives ways and other things. Install is straight forward, and when I replace my bumper, I can easily uninstall this and reinstall it on the new bumper.
If intrested in picking them up, linkaroo
http://protektskidplates.com/buy-now.html
hapa_kcm is offline   Reply With Quote
Old 01-11-2017, 05:27 PM   #2
mitch t
mitch t's Avatar
Drives: stx class lava frs
Hey guys, ProTEKt skidplates are on sale this month in the vendors section. Click the link below to buy yours before they are gone!!
mitch t is offline   Reply With Quote
Old 04-07-2017, 03:26 PM   #3
mitch t
mitch t's Avatar
@hapa_kcm ,
got any pics of them after all this time? are they wearing OK?
thanks,
Mitch
Protek Skid Plate Install whataboutbob Cosmetic Modification (Interior/Exterior/Lighting) 79 04-21-2017 03:01 PM
OEM Skid Plate - Subaru/Scion cant get it? JTOFJPN Engine, Exhaust, Transmission 10 04-19-2017 05:49 PM
FS: Protekt Skid Plate - BRZ harkbrz Canada Classifieds 1 12-10-2014 07:58 PM
Part number for the skid plate that.. Yamajee Cosmetic Modification (Interior/Exterior/Lighting) 0 11-01-2014 08:12 AM
Sand/grit on top of skid plate 1Cor10:23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 12-18-2013 12:13 PM
