Old 01-10-2017, 04:32 PM   #15
steve99
Drives: FT86
Originally Posted by denso View Post
Thanks mate. So getting a bigger MAF tube and recalibrating again is the way to go I guess.
My target is 0,7bar (~10psi) but SD is still not an option.
The oft 350 or sbd 10psi turbo kits use maf based fueling and a 3 inch maf tube
http://www.ft86club.com/forums/showthread.php?t=58514
denso (01-10-2017)
Old 01-11-2017, 12:26 PM   #16
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Increasing the MAF housing size will slow the air down, keeping the MAF within 5v. You'll need a 3" MAF housing to run more boost. When properly scaled, you can run up to the 450hp range on MAF. You'll need a speed density setup to go beyond that safely.
You should also go ahead and replace your MAP sensor, as the stock MAP is not good for boost. Omni sensors are plug and play once you update your sensor scaling. I run a 4 bar and haven't had any issues with it.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
denso (01-11-2017)
Old 01-11-2017, 04:35 PM   #17
denso
Drives: 86
Hey, thanks for your help. Increasing MAF housing is the way to go now. I just want to hit 10psi (should be around 300whp) and thats it. Next year Ill go with a forged engine and standalone engine management.
300-350whp should be "easy" with 10psi and 102ROZ fuel.
denso is offline   Reply With Quote
Old 01-12-2017, 11:39 AM   #18
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Standalone is honestly overkill. Ecutek is more than capable up to the 600hp range and higher.
Good luck!
denso (01-14-2017)
WTB Deifferential housing D K Want-To-Buy Requests 4 05-21-2018 12:44 PM
PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing slicktop Engine, Exhaust, Bolt-Ons 6 10-17-2015 11:53 PM
fog light housing Streich94 BRZ First-Gen (2012+) — General Topics 2 06-23-2015 02:09 PM
Headlight housing trsiidno Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 01-20-2015 10:29 PM
MAF Housing g0lden Engine, Exhaust, Transmission 1 12-31-2012 10:46 PM
