Old 01-05-2017, 11:11 AM   #1
otto07
Drives: 2015 frs
SPC Toe Arms
I bought a set of SPC toe arms a few days ago. they came in and have this bracket on them that i do not see on any other pictures of the arms. Every source i check has the same picture. the part number on the parts seem to be correct but the vendor does not know if the design has changed.
Has anyone else bought these? if so can i get some confirmation if they are correct or not.
thank you for any help. pics below.
otto07 is offline   Reply With Quote
Old 01-05-2017, 04:04 PM   #2
frslee
Just drive it
Drives: 13' FR-S
Hmm, that's odd. I bought a set 3-4 months ago, but don't remember seeing that bridge metal. If it's bridging rod and bushing area, I'd think that's for added strength.
frslee is offline   Reply With Quote
Old 01-05-2017, 10:39 PM   #3
otto07
Drives: 2015 frs
The bridge also has nut welded to it and they provided a bolt to go into it.
Old 01-05-2017, 10:50 PM   #4
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Just got some a couple weeks ago...no bracket...
vintagemxer is offline   Reply With Quote
Old 01-06-2017, 12:10 AM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Mine don't have that bracket either, but they are at least a year old.
Contact SPC and see if there was an update.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-06-2017, 10:39 AM   #6
otto07
Drives: 2015 frs
Yea I emailed spc with no response yet. I will give them a call today.
Old 01-11-2017, 03:00 PM   #7
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
That makes sense.
While we are on this topic, what are aftermarket toe arms meant for (what's the benefit )? Increased rigidity ?
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 01-11-2017, 03:05 PM   #8
Adam_L
Adam_L's Avatar
Ohhhh for Toe adjustment. After lowering the vehicle and knowing what wheel/tire to go with, then you'd know if you want any toe + - adjustment .
Old 01-11-2017, 03:05 PM   #9
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Adjusting toe.
Parting out HERE
Old 01-11-2017, 03:11 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That makes sense.
Yeah, usually oem adjustment is enough even when lowered and running camber but some need more. Also OEM seems to be semi prone to slipping where you can get lockdown kits for aftermarket ones.
Old 05-26-2017, 10:35 AM   #11
bhmax
Drives: 13 BRZ, 17 Focus RS
Also curious about this as I'm thinking about getting the SPC toe arms and using them with the SPL lockout kit.
bhmax is offline   Reply With Quote
Old 05-22-2018, 09:40 AM   #12
Turbo86
Drives: '13 Whiteout FR-S
I could be wrong but the WRX might be able to use the same toe arm and they need that nut for their brake line. So SPC just decided to leave it since it doesn't cause clearance issues on ours?
Turbo86 is offline   Reply With Quote
The Following User Says Thank You to Turbo86 For This Useful Post:
jbailey8748 (06-13-2018)
Old 05-22-2018, 10:06 AM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
Pretty sure the instructions even say this... This is the correct answer though.
The Following User Says Thank You to cjd For This Useful Post:
wparsons (05-22-2018)
Adjustable control arms and Toe arms zumin Brakes, Suspension, Chassis 12 07-08-2015 06:54 AM
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
