Old 01-11-2017, 09:56 AM   #71
flyboy
New here!
flyboy's Avatar
Drives: 2013 FRS 10 Series
Out
@Tcoat about the steelies, 16x6.5, 5x100 are easy to get, what if the center bore is bigger like 58 or 57 instead of the 56.1? Smaller wouldn't fit for sure.
flyboy is offline   Reply With Quote
Old 01-11-2017, 10:27 AM   #72
You can get what is called a hub centric ring to fill the gap if the wheel bore is larger than the hub. Best if you have the right size bore but there is nothing wrong with using the rings either. Any tire place will have them.
http://www.hubcentric-rings.com/why_hub_centric_rings/
flyboy (01-12-2017)
Old 01-11-2017, 10:55 AM   #73
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Just find a used set of Bugeye WRX wheels!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 4 Users Say Thank You to Shark_Bait88 For This Useful Post:
flyboy (01-12-2017), Overdrive (01-11-2017), Tcoat (01-11-2017), why? (01-11-2017)
Old 01-11-2017, 11:25 AM   #74
I agree with all that, but that is when you use the vehicle on a regular basis correct. The main concern is when you don't use the vehicle for 2-4 weeks straight and then drive for couple of days and then don't use it again for 2-4 weeks. That would put a strain on the battery wouldn't it.
Yep, storage or long periods in between use is a different deal.
As I mentioned in post #2:
"A battery tender would be a good idea for storage as would a gas stabilizer for longer storage".
That statement should be amended to include long periods if non use.
A lot depends upon whether or not the vehicle is consuming electricity while it is not running.
Old 01-11-2017, 11:49 AM   #75
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
My understanding was that our cars have lug centric hubs, so that it's more the lug nuts holding the rim to the hub than the center bore. Not sure if it's absolutely critical to have that hub ring (though I did buy a set for my summer wheels)
Sent from my SM-G930W8 using Tapatalk
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
flyboy (01-12-2017)
Old 01-11-2017, 11:54 AM   #76
You are correct it is a lug centric setup. I have still always preferred to use a hub centric ring on wheels with a larger bore just because it lines the wheel up better and take a bit (probably very small bit) of possible shear pressure off the lugs when tightening the nuts. Never was a big fan of letting the chamfer on a lug nut line up a wheel even if lug centric.
daiheadjai (01-11-2017)
Old 01-11-2017, 11:57 AM   #77
Out
I doubt that ("out") ....... Is Tcoat ever "out" ........ maybe "over" would be more appropriate for your RTO speak ........
Old 01-11-2017, 12:00 PM   #78
Well I thought that we were done that conversation so "out" was the appropriate term. I still absolutely cringe when somebody on a movie or show says "over and out" on the radio. One or the other folks it can't be both.
humfrz (01-11-2017)
Old 01-11-2017, 03:27 PM   #79
Razgriz
Drives: 2016 Scion FRS Release Series 2.0
@Razgriz are you using the stock wheels? or using 16 inch steel wheels? One more thumbs up for the Hakkas! Thanks for the advise. I am new to Anchorage, so local info would be helpful.
I'm running stock wheels, well it's a RS 2.0 but it's the same size as the base. Mostly cause I was thinking of using these as winter wheels and getting new ones for the summer but also I'm kind of lazy so I might not.
If you have facebook you can join the local group, it's AK 86 I believe. I would join but I don't use facebook.
Razgriz is offline   Reply With Quote
Old 01-11-2017, 08:07 PM   #80
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
check out craigslist, any stock subaru wheel should fit. There are tons of 16" subaru wheels out there being used as winter wheels.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Old 01-11-2017, 09:24 PM   #81
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Late to the party, but figured I'd leave this pretty amusing vid here
[ame="https://www.youtube.com/watch?v=JKBdOE2z4O4"]RWD in a Snowstorm - Are we Crazy? - FR-S Long Term #3 - Everyday Driver - YouTube[/ame]
Also on the topic of the OEM fitted 16" wheels. The Base GT 86 model in AU comes with these Enkei kinda watanabe vibe wheels that actually look really nice in the flesh. I think they were 16x6.5" with 205's. If I were ever in a position of needing winter tires, the OCD in me would compel me to find these for my winter set.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
The Following User Says Thank You to Mim For This Useful Post:
why? (01-12-2017)
Old 01-11-2017, 09:25 PM   #82
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
What "why?" said. There are a ton out there, and some might already have lightly used snow tires on them. Savings galore, and from there you can put whatever tires you want on them
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-11-2017, 09:26 PM   #83
As I said the first time I saw that video. "They call that feeble coating snow?"
Old 01-11-2017, 09:27 PM   #84
Overdrive
Sittin' Sideways
Overdrive's Avatar
I love these guys. Back when I had a little tiny doubt about running the car in the winter, I came across their video. Done deal. They really do great work, and aren't just about being pompous goofballs in cars like a certain defunct show and its recently aired spiritual replacement.
-O/D
2016 FR-S, Hot Lava
Another newbie, another mod list (Suggestions wanted!) MitchEv Engine, Exhaust, Transmission 6 04-29-2016 09:58 PM
Newbie needs... Salemate Canada Classifieds 10 12-23-2015 03:07 PM
snow....starting to like snow! brzr CANADA 19 01-23-2014 12:10 PM
Newbie Toyota 20v AFRICA 6 01-18-2014 04:32 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
