Old 01-10-2017, 08:59 AM   #57
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by slyphen View Post
aside from upgrading to BBK, what brake pad/rotor/fluid combination do you guys use?
Carbotech AX-6 at the moment, and Motul RBF600. Rear rotors are OEM, front are the default j-hooks with the AP Sprint kit. No, the BBK isn't making me usefully faster, but the price was good and the brake feel is excellent.
The Following User Says Thank You to cjd For This Useful Post:
slyphen (01-10-2017)
Old 01-10-2017, 12:35 PM   #58
renfield90
The Stig's German cousin
So the AP Sprint is STX legal? I've been eyeing it as something to get down the line, but the pictures make the individual rotor plates look thinner than OEM. Has anyone measured? I haven't been able to find specs.
Old 01-10-2017, 12:59 PM   #59
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Courtesy of FT86SF. AP far left. Stock/DBA are last 2. 32mm AP vs 24mm stock
Old 01-10-2017, 02:35 PM   #60
renfield90
Thanks for that. Here's the relevant rule with the part I'm interested bolded:
Non-standard brake rotors may be used provided they are of equal or
larger dimensions (diameter and thickness) and made of ferrous material
(e.g., iron). Thickness includes the individual plates of a vented rotor,
as well as the overall dimension.
Overall the whole rotor might be thicker, but the thickness of the individual rotor plates (i.e. without the cooling vanes) also matters. Looking at the picture, the plates themselves are both ~15 pixels. So it's probably fine, assuming that you can claim the minimum rotor width in the FSM as your starting point.
Old 01-10-2017, 02:41 PM   #61
M0nk3y
You're looking into it too much. It's saying that thickness includes the plates + the vanes. Basically giving you a basis on what is defined as overall dimension.
If this wasn't the case paper would have been thrown already. Marcus in 2015 won STX with an AP Kit.
The Following User Says Thank You to M0nk3y For This Useful Post:
justint5387 (01-10-2017)
Old 01-10-2017, 03:17 PM   #62
renfield90
Well then this is the 3rd case of shitty English I've come across in the rulebook in the last month. Sometimes I wonder if it might not be better to burn it all and start over. "As well as" implies a separate measurement to me, not a combination.
Old 01-10-2017, 03:19 PM   #63
renfield90
https://www.merriam-webster.com/dict...as%20well%20as
It can mean AND or it can mean BESIDES.
Old 01-10-2017, 03:35 PM   #64
whataboutbob
AutoX-10/10ths every run
Winmax W3, Stock rotors, Motul RBF660
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
slyphen (01-11-2017)
Old 01-10-2017, 03:36 PM   #65
M0nk3y
Write your letter to the SEB then for rule clarification.
Old 01-10-2017, 04:01 PM   #66
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
How do you like the W3's? Looking into upgrading pads to handle DD duty as well as autox, probably going to do AX6's later this year but I'd like to try a Winmax product given the good reviews they've been getting, would have picked them up instead of the last pads I got but couldn't figure out what level would be appropriate.
ineedyourdiddly
whataboutbob (01-11-2017)
Old 01-10-2017, 05:13 PM   #67
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by 2superblus View Post
If you are a good driver a competitive BRZ/FRS is only $4500-5500 away.
$5k, $8, $10k, $20... Whatever it is that's more than I want to put towards my FR-S to jump classes. I'd rather move to DS where I already have everything for the car and just need to switch to a non-RS version.
Thanks for all the feedback everyone.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-10-2017, 06:00 PM   #68
strat61caster
Yeah, if you don't want to put $5k into it then it's not the class for you.
I bet if you picked up stock springs and a sway nobody would bat an eye at your car running DS.
ineedyourdiddly
Old 01-10-2017, 08:33 PM   #69
whataboutbob
I really like them. They get up to temp in the first few turns on the AX course. I've run a set for a full autocross season on A7s in SM and daily driven on them and they weren't done after a year's time (about 25K street miles). They do produce some dust, and they will occasionally make a very slight amount of noise if they are bedded in properly.
Build thread:Here
strat61caster (01-10-2017)
Old 01-11-2017, 12:04 AM   #70
simpleisbest
Senior Citizen
Drives: Scion FR-S
I've used the W3 and W2 for less than 2 seasons. They were an improvement over the stock pads with regards to threshold braking, but found they were a bit harsh when trying to modulate for something like a "very light brake" or a brake tap. The bite was a bit harsh and resulted in too much of a loss of mph and momentum, IMO. So far I think the Carbotech AX6 are much better for autocross, especially more so if you left foot brake a lot. Right now I am testing the GLOC versions of the same or similar compound. Only one event so far but really good modulation....Very impressed so far.
YMMV
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
strat61caster (01-11-2017)
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
Official FT86Club decal ideas? Hanzo BRZ First-Gen (2012+) — General Topics 46 06-04-2012 01:15 PM
