Old 01-08-2017, 12:09 PM   #15
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Hello Flyboy,
Here is a physics demonstration to over dramatize the narrow vs. wide tire. Next time you are are shoveling virgin snow after a significant snowfall, try this. Take the blade of the shovel and push it down through the snow. You will push the snow out of the way and go down pretty far until you start to hit something really solid. Now take the shovel and lay it flat and now push the shovel down in the snow. You will compress the snow but probably won't get to anything too solid. But you have created the beginnings of a good skiing area. Same for tires but not as significant as this demonstration.
Casey10s is offline   Reply With Quote
The Following User Says Thank You to Casey10s For This Useful Post:
carsebuco (01-09-2017)
Old 01-08-2017, 12:10 PM   #16
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You can buy base model forester steel wheels for next to nothing. Just an idea that could help you save money. They come in 16's.
The Following User Says Thank You to Summerwolf For This Useful Post:
jcw99 (01-09-2017)
Old 01-08-2017, 12:31 PM   #17
cjny
Drives: 2016 BRZ
Originally Posted by flyboy View Post
Thank you @humfrz @phrosty @WWFT86.
About the tires, being a physics student my self, i can't wrap my head around that narrower tire providing better traction. But you guys have more experience and I will take your word on it. Plus it is only an inch difference and saves $$.
Finally, someone else who sees the problem with getting physics advice from a tire retailer.
I like the stock size for winter. But sizing down is definitely cheaper and gives you extra cushion that can be welcome if your roads have lots of potholes.
cjny is offline   Reply With Quote
Old 01-08-2017, 12:53 PM   #18
The theory of the physics is sound no matter what the source but I truly wonder how much a 1/2 inch difference in width makes in the practical application. Is there a difference? Sure, but just how god a driver is anybody that says they can tell.
Old 01-08-2017, 10:10 PM   #19
navanodd
Drives: 2013 BRZ Sport-tech WRB
Just to chime in on the tire size choice, 205/55R16 is an available OEM tire fitment for this FRS/BRZ, just not in North America. Go for it.
I have found myself having to run a lower tire pressure in the winter (30psi) , but I believe that is due to my winters having a load rating of 94, vs OEM load rating of 87.
I'm on winter #4 now in New Brunswick/Nova Scotia, this car isn't as bad as you'd think in the snow so long as you have good tires.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
jcw99 (01-09-2017)
Old 01-08-2017, 10:35 PM   #20
dnieves
Drives: FR-S 10 Series
Not sure about the snow tires but reliability wise it's as extremely reliable and incident/trouble free as my Toyota/Scion (tC) and Honda (Civic Si) and more trustworthy than my Hyundai (Elantra GT) and Nissan (Altima).
The only preventative I would suggest is if you have a MT get the cam plate cover bolted on (this will prevent the smell of oil or a little oil leak if the OEM silicon gasket ever fails).
P.S. I'm a proponent for mud guards/flaps to protect the paintjob.
dnieves is offline   Reply With Quote
Old 01-08-2017, 11:40 PM   #21
flyboy
New here!
flyboy's Avatar
Drives: 2013 FRS 10 Series
Came out from under an overpass at about 70mph and a the wind hit me and moved me over half a lane in a split second. I have never had a car so susceptible to wind.
@Tcoat Thanks for that. I will keep that in mind, but is that anytime of the day or during wet/icey slippery road conditions?
@Casey10s I agree with you on that. A pointy/narrower end would slice through much easily, but friction wise a narrower tire would provide less traction due to less contact area for sure. But I think for snow first it is important to plough through it. I will be going with the 205/55/R16. Just have to figure out the brand now.
@Summerwolf and @cjny thanks for the advise. I guess for winters the narrower tire makes more sense and is more cost effective. Plus you never know what is under the snow and 205/55 might provide more cushioning.
@navanodd I wonder why is not an OEM in the North America though! But that is good information. Thanks for sharing. Where is it offered as an OEM fit, just outta curiousity.
@dneives I am glad to know about the reliability. Thanks for chiming on that. Last car I owned was a 1995 Sable. I have driven many cars but never owned many, so maintenance wasn't my problem. But to know it is more reliable than a Hyundais makes my day...
flyboy is offline   Reply With Quote
Old 01-09-2017, 08:22 AM   #22
gravitylover
[QUOTE=flyboy;2827936]@Tcoat Thanks for that. I will keep that in mind, but is that anytime of the day or during wet/icey slippery road conditions?[QUOTE]
Any time. It's a lightweight car and it gets moved around fairly easily. Just be aware and you'll be fine.
[QUOTE=flyboy;2827936]@Casey10s I agree with you on that. A pointy/narrower end would slice through much easily, but friction wise a narrower tire would provide less traction due to less contact area for sure. But I think for snow first it is important to plough through it. I will be going with the 205/55/R16. Just have to figure out the brand now.[QUOTE]
For where you are I would consider a tire with a higher ice rating than snow unless you plan on heading up towards Girdwood or Hatcher Pass frequently. Take a look at the Michelin X-Ice or similar.
[QUOTE=flyboy;2827936]@Summerwolf and @cjny thanks for the advise. I guess for winters the narrower tire makes more sense and is more cost effective. Plus you never know what is under the snow and 205/55 might provide more cushioning.[QUOTE]
Yup taller sidewalls are good.
[QUOTE=flyboy;2827936]@navanodd I wonder why is not an OEM in the North America though! But that is good information. Thanks for sharing. Where is it offered as an OEM fit, just outta curiousity.[QUOTE]
Because we don't think that rwd sports cars are supposed to be comfortable or practical. Market bullshit...
Hmm my skills at breaking up a post and multi quoting it suck...
The Following User Says Thank You to gravitylover For This Useful Post:
Tcoat (01-09-2017)
Old 01-09-2017, 08:50 AM   #23
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Look at how skinny these tires are. And they are flying !
I don't have much to ad to what the previous posters said but I will say that the 86 does fine in the winter. I was worried to and was inclined to buy bulky AWD vehicles before the BRZ seduced me (my previous DD was a Lexus LX470). The biggest problem with extreme weather conditions is being able to steer and stop. And dedicated tires will help you mores then AWD, which helps you move, not stop.
Just use you head, take it easy and if the weather is too extreme, it is probably not a good idea to leave the house anyway. The biggest problem is usually not the car enthusiast (you) but those oblivious idiot people that have no clue as to what they are doing and loose their little focus on driving as soon as a phone screen lights up.
Guru Woodman is offline   Reply With Quote
The Following User Says Thank You to Guru Woodman For This Useful Post:
Tcoat (01-09-2017)
Old 01-09-2017, 08:55 AM   #24
They do just fine!
gramicci101 (01-09-2017), jcw99 (01-09-2017)
Old 01-09-2017, 10:20 AM   #25
flyboy
New here!
flyboy's Avatar
Haha I see that, its not that difficult though!
@Guru and @Tcoat I believe you guys! Thanks for all the feedback and it is the other drivers who scare me. Saw a guy shaving while driving the other day!!
Maybe if it gets too extreme we can always attache these
Attachment 148011
The Following User Says Thank You to flyboy For This Useful Post:
why? (01-09-2017)
Old 01-09-2017, 10:21 AM   #26
flyboy
New here!
flyboy's Avatar
They do just fine!
I am guessing that was just couple feet below the normal snow that you guys get!
Old 01-09-2017, 10:26 AM   #27
Zhangy
Drives: 2015 FRS
if ur on stock tires, dont drive it on more than 5cm of snow. if ur have snow tires the number becomes ~10cm
Zhangy is offline   Reply With Quote
Old 01-09-2017, 10:26 AM   #28
We are way down on snow this year. That was about 3 hours worth. We call it a "light squall".
Another newbie, another mod list (Suggestions wanted!) MitchEv Engine, Exhaust, Transmission 6 04-29-2016 09:58 PM
Newbie needs... Salemate Canada Classifieds 10 12-23-2015 03:07 PM
snow....starting to like snow! brzr CANADA 19 01-23-2014 12:10 PM
Newbie Toyota 20v AFRICA 6 01-18-2014 04:32 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
