| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2045 |
Powered by Crickets
Drives: 14' SWP MT Limited BRZ
Can confirm, I run 265/35 with a 38 offset on a 9.5 rim and -2.5 camber and I have more than enough room.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
| The Following User Says Thank You to Bowen For This Useful Post: | amaciose (12-20-2016) |
#2046 | |
Drives: 2013 BRZ Limited
I'm running 265/35/18 on 18x9.5+40. KW V3's and lowered 3/4". I asked them to decrease the rear camber from factory settings to around -2° to -2.5° and they said there's no room on the inside to add more negative camber. I'll be swinging by their shop shortly to check it out. |
#2047 |
Powered by Crickets
Yea that's not true at all. My ST coils (a daughter company to KW) are able to run -2.5 in the rear no issue. That's with the stock top hats and control arms too! They might be saying they can't do it so you don't get upset with them later on down the line if your tread isn't wearing evenly... regardless, just tell them to make it happen haha.
#2048 | |
It was a miscommunication between the technician and the rep on the phone. Technician just wanted me to be aware of all of the 'problems' with cambering a wheel. The rep stated that there was no clearance to camber. I requested -0.8°/-2.2° F/R. Hopefully that helps me clear the fender without adding too much tire wear. |
#2049 |
They brought the rear camber down to -2.3° and the wheel is about flush with the fender now. I tested the fitment out by going up my driveway and when all the weight shifted to my left rear coil, I noticed I'm still having a ton of rubbing issues with the top of the fender hitting the tire sidewall.
I guess I'll look into rolling and pulling the fenders now? I didn't think my setup was aggressive enough to need that. Don't really want to add much more camber because my car is pretty much a DD and I don't want the excess wear.
#2050 |
Drives: Subaru BRZ 2017 (almost)
Putting the coils and wheels on, guards are fully rolled, nice and soft in the '17 BRZ! As in factory rolled. Didn't need to do any! 9.5" wide +38
Sent from my Nexus 6P using Tapatalk Last edited by nima314; 12-23-2016 at 11:48 PM. |
#2051 | |
Drives: 2013 Firestorm FRS
fwiw, I ran -2.5 (hell I still am) and have minimal camber wear. I only notice that its more worn down on the insides when the tires are just about done anyway. which wheel are you running as well? Maybe they aren't actually +40? |
#2052 | |
I had the camber adjusted to -1.8 and the tires really don't poke that much, but the fenders still hit the outside tire sidewall when the coils compress. I guess another option is to get stiffer springs or increase my compression settings? |
#2053 |
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
265/35R18 Hakook V12 Evos Enkei NT03+m 18×9.5 +40 running a 5mm spacer to clear my brakes on Apex'i coilovers no issues Sent from my SAMSUNG-SM-G890A using Tapatalk
ALL THE MODS!!
| The Following User Says Thank You to batlwagn For This Useful Post: | Leonardo (12-28-2016) |
#2054 |
Country Boy 4 Life
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | batlwagn (12-28-2016) |
#2055 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i ran that setup for a long time |
#2056 |
#2057 |
the tuna, no crust.
i had rolled my fenders, and i ran pretty soft settings. i also had a front sway.
| The Following User Says Thank You to Jive Turkey For This Useful Post: | amaciose (01-04-2017) |
#2058 |
Drives: 2014 UltraMarine FRS
So I read that @texasbound972 was/still is running a 275 tire... Since I'll be making roughly 450whp I would like to also go that route. BUT, not in the front.
So my question is: Im planning on going with NITTO INVO tires and Tiresize.com has a chart with all the sizes you can go with. Ideally a 235/40 (819 rev/mile) and a 275/35 (814rev/mile) would be the way to go, but Ive never seen anyone run a 40mm difference in tire width. Would that cause bigger steering issues? -OR- Go with a 245/45 (779 rev/mile) and a 275/40 (780 rev/mile)... But they are much taller. I know my speedo will be off a bit, but besides that, is it really that big of a deal going this route? Otherwise I would stick with the 275/35 (814 rev/mile) and go with a 245/40 (802 rev/mile). |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
