11-21-2016, 12:21 PM | #295 | |
Drives: RHD Gt86
Awesome. Truly enjoy following your updates of your top class build, keep it up man! Sent from my iPhone using Tapatalk
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
11-22-2016, 02:29 PM | #296 |
I just Drive.
Drives: in the womb still
I recommend sandblasting your parts before paint next time. Those coolant passages with the corrosion......
Otherwise excellent build.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
11-22-2016, 03:57 PM | #297 |
Drives: 2JZ FRS
nothing a scotch brite pad wont wipe off. that's the least of my concerns right now
11-23-2016, 06:27 PM | #298 |
Drives: 2JZ FRS
Instead of buying new oem coils and an ignition amplifier, we decided to go all out and do a much stronger ignition solution from induction performance
11-25-2016, 10:45 PM | #299 |
Drives: 2JZ FRS
Parachute is done. The whole assembly is removable with one half inch bolt and the receiver sits flush with the bumper. Also have a speed hunters diffuser which I still need to paint satin black before install. Power shut off switch is removable and I have a black rubber plug to seal off the hole for when the car is in full street mode.
The Following 2 Users Say Thank You to spitfire481 For This Useful Post: | Kris86 (01-31-2017), Sportsguy83 (11-30-2016) |
12-03-2016, 09:14 PM | #300 |
Drives: 2JZ FRS
She's in there. Still need to do a little massaging to get the trans to clear, then set the drivetrain angle and weld the trans crossmember in. From there it's all small work.
The Following 5 Users Say Thank You to spitfire481 For This Useful Post: | civicdrivr (12-04-2016), DustinS (12-04-2016), Kris86 (12-05-2016), Lonewolf (01-03-2017), MaximeT (12-05-2016) |
12-16-2016, 12:58 PM | #301 |
Drives: 2JZ FRS
Did some test fitting last night. Intake manifold is powder coated, just need to find time to pick it up. Individual cylinder egt sensors and back pressure sensor bungs are welded onto the exhaust manifold as well. Just need to ceramic coat that and I can start final assembly on those pieces.
As far as the wiring harness goes, I made my full diagram and pin out and everything is verified. Spools of tefzel wire, connectors and pins are on the way. This harness will be everything I need, nothing that I don't. Routed exactly how I want
12-16-2016, 01:28 PM | #302 |
Drives: '13 BRZ
Looking forward to seeing the diffuser. I have the same sitting in the garage and was also going to paint it black.
That 2j is looking amazing. |
12-19-2016, 01:43 PM | #303 |
Drives: 2JZ FRS
Harness is together. Tonight I'll lay it out in the car and trim the excess wiring so everything is a perfect fit. Then I can fully shrink tube, shrink label, crimp terminals and install the connectors
The Following User Says Thank You to spitfire481 For This Useful Post: | R2RO (12-27-2016) |
12-24-2016, 09:24 PM | #304 |
Drives: 2JZ FRS
Both manifolds are coated and installed. Individual egt's and turbo manifold back pressure sensor. Just crimping the pins on the engine harness now. Fully shrink wrapped and ready for the ecu end to be pinned by my motec tuner
The Following 5 Users Say Thank You to spitfire481 For This Useful Post: | craigpitts7 (01-31-2017), gatorbushmen (12-25-2016), Kris86 (12-26-2016), Lonewolf (01-03-2017), whataboutbob (01-13-2017) |
12-29-2016, 05:43 PM | #305 |
Drives: 2JZ FRS
The Following 4 Users Say Thank You to spitfire481 For This Useful Post: |
01-03-2017, 12:12 AM | #306 |
wowwww! looks like an amazing setup!
01-03-2017, 01:33 PM | #307 |
1337
Drives: 2013 BRZ WRB S/C
Engine bay is gorgeous, as is the rest of the car!
The Following User Says Thank You to djdnz For This Useful Post: | spitfire481 (01-03-2017) |
01-03-2017, 10:07 PM | #308 |
Drives: 2JZ FRS
Finished the last of the engine bay wiring today, the coils. All that's left is the ecu connectors, Frs body harness connector, and a couple breakouts for my motec c125 dash, fuel pump/surge tank control, trans brake/bump box control, etc.
An in progress shot of the coil wiring And the new hotness
Similar Threads | ||||
God's Build | GodSays | Member's Car Journals | 13 | 04-17-2013 01:31 PM |
My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 04:02 PM |
STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 03:40 PM |
My BRZ build | brztj | Mid-Atlantic | 3 | 09-08-2012 05:52 PM |
