Old 01-01-2017, 06:06 PM   #24795
Ashikabi
Ashikabi's Avatar
Originally Posted by Allch Chcar View Post
@Ashikabi What if I want to look like a real human bean?
Which bean? Green bean, lima bean, kidney bean?
Ashikabi is offline
Old 01-01-2017, 06:07 PM   #24796
Ashikabi
Ashikabi's Avatar
I actually noticed that. I'm feelin' ya, dawg.
Hey, so I went back and studied the pics you took of the diode assembly. Those 3 diodes are wired in series so disconnecting one diode will kill all of them.
Is your multimeter analog, or digital? Model number?
-sidebar-
For anyone following along, a couple points regarding LEDs and semiconductors in general. This includes both junction and field effect devices.
1. They always initially fail by shorting out. After that, they'll either go up in smoke, or they'll just sit there like a piece of wire in disguise. It depends on the application.
2. LEDs gradually get dimmer as they approach end of life.
Multimeter is digital. Craftsman. The 200mA fuse is blown. Can't get another till Tuesday
Ashikabi is offline
Old 01-01-2017, 06:08 PM   #24797
Phijkchu
Phijkchu's Avatar
Drives: Feet
Originally Posted by cdrazic93 View Post
Alright, happy 2017 you car nuts.
My mom is looking for a compact luxury suv. Shes wants good gas milage but doesnt want to spend so much money. Are there any good models I may be missing? How are some of the mazda suv's? I know they've been stepping up their game recently.
I'm piggybacking on this question.
Phijkchu is offline
Old 01-01-2017, 06:14 PM   #24798
Fuck yeah! Mystery solved!
I woke up thinking about it.
Ultramaroon is offline
Old 01-01-2017, 06:15 PM   #24799
gramicci101
Off Topic
Lexus RX, BMW X1, Range Rover Evoque, or Porsche Macan?
gramicci101 is offline
Old 01-01-2017, 06:18 PM   #24800
Ashikabi
Ashikabi's Avatar
Rip
Ashikabi is offline
Old 01-01-2017, 06:20 PM   #24801
cjd
cjd's Avatar
Drives: 2017 BRZ
The question is whether it blew when you were trying to test.
Can you get a pic of the back of the circuit board without your thumb? And can you get some numbers off the other components on the board?
I'm thinking we don't need to measure anything here, it appears to be a protected circuit taking 10-14v in (I think that's a cap, then a regulator, then ... not sure, some resistors but I can't see what they're doing); we just need to spec the right voltage, which we should be able to determine knowing the other parts. I may be wrong, as I never quite understood diodes and current (beyond making sure you don't draw more than they can handle, but this circuit is dedicated to the LEDs)
cjd is offline
Old 01-01-2017, 06:27 PM   #24802
Allch Chcar
Drives: N/A
I may have figured out why people don't listen to your advice.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline
Old 01-01-2017, 06:30 PM   #24803
Ashikabi
Ashikabi's Avatar
You're the one who said you looked like a human bean. I thought you were being facetious.
Edit: so assuming you meant "human bean" as you are super skinny: the answer to that is actually super simple> eat more. You should lift weights so you don't get fat and you'll be cut all the time so you'll look great but yeah, just eat more. Eat every 2-3 hours. Ideally you would measure your food and count your macros but in simplest terms, you body needs more calories to build with.
Ashikabi is offline
Old 01-01-2017, 06:35 PM   #24804
Allch Chcar
Drives: N/A
It's your anime avatar.
-Allch Chcar
Old 01-01-2017, 06:38 PM   #24805
Ashikabi
Ashikabi's Avatar
img host
imgurl
The blue wire goes to the main plug so it will provide a full 12V
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
cjd (01-01-2017)
Old 01-01-2017, 06:45 PM   #24806
cjd
cjd's Avatar
Drives: 2017 BRZ
For reference: the rectifier data-sheet
Looks like 195Ω in series (2 390Ω in parallel...)
Max average forward amperage is 0.8A on the rectifier but I have no idea why this part is there...
img host
imgurl
cjd is offline
Old 01-01-2017, 06:58 PM   #24807
The input signal is AC. I'm not sure what the first component is. It's likely a filter cap like you're thinking. The first component is a bidirectional transient-voltage-suppression diode.
The second component is a bridge rectifier. Then as expected come the current limiting resistors. Those are 2 390 Ohm resistors in parallel.
Last edited by Ultramaroon; 01-01-2017 at 07:37 PM. Reason: figured out what the first thing is
Old 01-01-2017, 07:01 PM   #24808
cjd
cjd's Avatar
Drives: 2017 BRZ
Yes, figured that much out already And posted it all. Except I wasn't expecting A/C... I know what a rectifier is for...
195Ω just seems odd... it's about double what I would spec for this LED (white) to have acceptable operation from 10-14.3v (note, this LED is designed for use with a reflector, part of why I chose it... plus the case design and dimensions are correct if I'm remembering right).
I think this green version may be right... but...
cjd is offline
