Old 12-30-2016, 07:26 PM   #1
Street22
Drives: 16 SSC Raven FR-S
DS sway bar
So I'm pretty new to autox and am looking for some advice. I'm looking to upgrade the front bar with either the Strano or Hotchkis. I was wondering if anyone had any experience with these or possibly another recommendation that I haven't considered. I have a 2016 FRS ans have just ordered a set of RE71s. I have never raced an FRS and don't want to go with to large of a front bar. Thanks in advance for the insight.
Street22 is offline   Reply With Quote
Old 12-30-2016, 07:45 PM   #2
whataboutbob
AutoX-10/10ths every run
You should read this thread http://www.ft86club.com/forums/showthread.php?t=35855 I suspect you can find an answer there.
Build thread:Here
Old 12-30-2016, 08:11 PM   #3
Street22
Thanks for the link. I've been trying to sift though all the info but it's a little overwhelming to be honest.
The Following User Says Thank You to Street22 For This Useful Post:
whataboutbob (12-30-2016)
Old 12-30-2016, 08:15 PM   #4
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The suspension is a system that are all interconnected and work together. The bar, shocks, and even tire pressures all work together to tune the car and the setup that works best for one driver won't necessarily work best for another.
You are about to slip down through the rabbit's hole and I don't remember which pill you're supposed to take, let alone which one is objectively best.
I personally picked a whiteline 20mm, non-adjustable bar. I found in the past that I would just set the bar and change other things, so I didn't want to mess with one more degree of freedom to mess with.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
stock (01-06-2017)
Old 12-30-2016, 08:28 PM   #5
Street22
Yeah that's probably not a bad idea for me to go with something non adjustable. I have found myself in the past always wondering if and what I should change to try to fix a certain problem. I know nothing is univestal with thsee things but didn't know if there was a blatantly wrong choice for a certain reason.
14stu (12-30-2016)
Old 12-30-2016, 08:34 PM   #6
14stu
14stu's Avatar
If you go too stiff, you might hate the understeer (I was coming from a WRX, so I wanted to avoid understeer as much as possible).
With stock struts, I'd go with a bar that's not too much stiffer than stock (22mm or smaller).
Old 12-30-2016, 08:39 PM   #7
Street22
That's my wish as well. I come from a history of miatasks myself. I had an NC and always had and issue with understeer. I absolutely hated it and don't want to repeat that mistake again. That's what I was worried about with the hotchkis being 24.5mm.
Old 12-30-2016, 09:27 PM   #8
ChrisSC300
Drives: 2014 SWP BRZ
Why are you looking to upgrade the front sway? Do you feel the car has too much oversteer? Don't upgrade just because you can. I would put on the Re71's and run a season on those, really learn the car, and then decide what needs to be changed based on your driving style. Just my 2c. It sucks to pay money for parts and installation just to find out you don't like the changes they made.
ChrisSC300 is offline   Reply With Quote
Old 12-30-2016, 11:56 PM   #9
14stu
14stu's Avatar
In DS, you are allowed to change one sway bar and the front is the one that helps. A stiffer front bar helps with turn in and stiffens the car up some to help with weight transfer.
The strano bar is hollow, so the diameters don't directly compare with the solid bars like the whiteline or perin bars. I believe it is similar to a 22mm bar, but you'd need to check.
You can compensate for the any unwanted understeer with alignment changes, a little toe out up front or dialing out some of the toe in in the rear would compensate. You can always resell your sway bar later for nearly what it costs you, it's probably the cheapest mod you can do (the alignment will cost more than one of the bars).
Old 12-31-2016, 12:16 AM   #10
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would honestly drive the car with the RE71's on it first without changing anything. My 2013 FRS was way on the side of oversteer when I started to autox. I know they made changes to the suspension since the 13's to try and dial that out.
If you have to much oversteer than think about getting rid of the rear sway first. As this is a free mod. We have a few twins that have taken off the rear sway and found the car acts much better.
Shneegle is offline   Reply With Quote
Old 12-31-2016, 08:13 AM   #11
Street22
yeah that is a good point. fortunately i have a friend that is a tech at a local dealership that will do any alignment specs that i'm looking for at no extra charge so that helps out.
Old 12-31-2016, 08:16 AM   #12
Street22
now i have actually done that with both of my past miatas but i hadn't heard of anyone doing that with these cars. i guess thats always an option as well.
Old 12-31-2016, 12:46 PM   #13
Biggins
Drives: Yes
Perrin 19mm or Whiteline 20mm. You can make any of them work well as you can adjust your driving to it.
Biggins is offline   Reply With Quote
The Following 2 Users Say Thank You to Biggins For This Useful Post:
Shankenstein (01-03-2017), TrqlessWonder (01-04-2017)
Old 12-31-2016, 01:34 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm not sure no rear bar will be the ticket on stock springs.
IIRC the Strano is similar to the 20mm adjustable Whiteline at its stiffest, which is the bar I'd start with (the Whiteline, that is).
I'd still give it a run or two with the stock bar, and probably with the stock tires as well, given the "new to AutoX" bit. RE71's are great tires, but do mask mistakes. It's also difficult to know if you want more or less bar if you don't have a point of reference...
I would go ahead and max out the front negative camber, regardless (~-1.5ish on bolts typically) - that may be done already but figured I'd mention it.
The Following User Says Thank You to cjd For This Useful Post:
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 06:02 PM
FS: Koni shocks, TRD sway bar & WRX sway bar scirocco78 Brakes, Suspension, Chassis 14 08-31-2015 06:47 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
TRD Sway Bar Kit Maxwell Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-04-2015 07:01 AM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
