Old 12-25-2016, 07:37 PM   #1
86fit
86fit's Avatar
Drives: 2016 Asphalt FRS
Powered by Max LCA's Sold!
$170 plus shipping. Anti-seize used on all threads so they adjust easily still.
86fit is offline   Reply With Quote
Old 12-29-2016, 07:39 AM   #2
FtSkyler
Drives: 2016 frs / 1989 240sx
Interested
Is that surface rust or dirt?
FtSkyler is offline   Reply With Quote
Old 12-29-2016, 05:52 PM   #3
86fit
86fit's Avatar
Just chips in the paint. The side that faces forward on the car gets nicked up pretty easy by road debris. Its common with PBM LCA's I've seen.
Old 12-31-2016, 04:42 PM   #4
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
What is the max camber setting for this?
ChanceK is offline   Reply With Quote
Old 12-31-2016, 09:55 PM   #5
86fit
86fit's Avatar
To be honest im not sure what the max is, but I've seen people use them over -5 degrees. Tons of adjustment, they are drop control arms with 2 shock mounting points. Lower than stock and way lower than stock. These are meant for going really low. I ran them at -2.3 and then I pulled more camber out at -1.8.
Old 01-01-2017, 09:37 PM   #6
636
636's Avatar
Drives: '23 CWP BRZ
I got -11.5 degrees out of just my PBM LCA, believe it or not.
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
86fit (01-02-2017)
Old 01-16-2017, 09:00 AM   #7
86fit
86fit's Avatar
bump
Powered By MAX Coilovers!!!!!! try2findmark Suspension | Chassis | Brakes -- Sponsored by 949 Racing 99 02-28-2016 02:05 AM
NINJA-powered BRZ! suzuka BRZ First-Gen (2012+) — General Topics 7 07-22-2015 02:19 AM
IS-F Powered FRS xn7485 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 01-08-2014 08:45 PM
V8 powered BRZ! Hawk77FT AUSTRALIA 4 12-28-2012 04:48 AM
