Old 12-28-2016, 11:03 PM   #1
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Rear Licence plate keep falling off.
What's up guys!
I been having this problem ever since i got my FR-S. Every time I close the trunk the licence plate will rattle, and after a few times the screws will come loose and the licence plate will fall off. Though now after only a couple closes the licence plate will fall off, it has become were I now have to tighten the screws with my hand every time i open and close my trunk. Its so irritating!
Do you guys know a website that sells a new sets of better nails and that round rubber/bumper hole that the nail goes into that i can buy, which will better hold the licence plate in position?
-Thanks!
dinfern22 is offline   Reply With Quote
Old 12-29-2016, 05:42 AM   #2
Foobar
SLO NO MO
Foobar's Avatar
Hardware store - get a bolt and nut, drill through the plastic fastener, then secure the bolt with the nut from within the trunk lid. Now it won't come off and your plate is impossible to remove without unlocking the trunk.
Old 12-29-2016, 09:26 AM   #3
dinfern22
dinfern22's Avatar
Thanks! Are you saying to drill holes on the top and bottom of the licence plate and car? Couldn't I just put the new screw into the existing two holes on top? If so, what size nail/screw should i be looking for?
Old 12-29-2016, 11:15 AM   #4
scottman
scottman's Avatar
Drives: 13 mt fr-s
yes, a nail. square one works best.
scottman is offline   Reply With Quote
Old 12-29-2016, 11:50 AM   #5
86Boyz
Drives: on the highway to hell
you can also get some thick double sided mounting tape and use it as padding between the trunk and the plate so it won't rattle
86Boyz is offline   Reply With Quote
Old 12-29-2016, 12:30 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
No. Use the existing plate holes. You just want to go through the plastic fastener that the current screws go into so you can lock it with a nut on the inside.
Use whatever size is sufficient to keep the plate snug. I think I used a 10mm hex bolt on mine. My plate holder has a camera on it so it was important for me to secure it properly.
Old 12-29-2016, 03:12 PM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Or locktite.....
Old 12-29-2016, 05:40 PM   #8
dinfern22
dinfern22's Avatar
Thanks for the advice guys. Just bought a set of screws with a bolt for the other side. It is holding firmly in place, though there is still a little rattle from the plate hitting the trunk.
Old 12-29-2016, 05:47 PM   #9
86Boyz
see if you can tape it down with some 3M tape...that's what i did with my license plate so it sticks to the trunk
Old 12-29-2016, 05:48 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My screws rusted. I replaced them with slightly larger stainless that fit tighter. Then I stuck three layers of 3M tape together behind the bottom of the plate.
I LIKE TIRES!
Old 01-03-2017, 10:19 PM   #11
parkmin
Drives: 2015 FRS
if there rubber mounts for the screws are still there in place and doesn't come out and not stripped. just use a shorter screw
parkmin is offline   Reply With Quote
New Licence Plate Mount 86fab BRZ First-Gen (2012+) — General Topics 9 06-27-2016 07:03 PM
WTB : Licence Plate Relocator Kit & RA Mudflaps NJ10 Want-To-Buy Requests 2 06-03-2015 02:43 PM
What back licence plate bracket is this? TomT2411 Cosmetic Modification (Interior/Exterior/Lighting) 35 07-08-2014 12:00 PM
Front Licence Plate Texas Iceman-86 Southwest 13 12-12-2013 08:03 AM
Licence Plate Rattle itdansharpe Electronics | Audio | NAV | Infotainment 4 03-13-2013 10:31 AM
