Old 12-26-2016, 03:25 AM   #1
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
Sunny's 3SGE BEAMS FRS. Full Engine Rebuild.
Engine/Drivetrain:
-G3 3SGE BEAMS Blacktop
-Custom Engine and Transmission mounts
-Drive shaft shop 3" steel driveshaft
-Modified OEM 3SGE headers
-Modified Intake Manifold by Dustin at Purist Mod
-FA20 Throttle body
-Injector Dynamic 1000cc injectors
-Fuel Lab FPR
-Radium Engineering Fuel pressure gauge
-Radium Engineering Oil Catch Can
-Deatschwerks DW65 fuel Pump
-Jegs Oval track fuel cell
-Modified Buddyclub catback
Suspension:
-PBM Pro Coils
-PBM LCAs
-PBM solid subframe bushings
-PBM solid diff mounts and risers
-SPC front camber bolts
Electronics:
-Haltech Elite 2500
-Custom wiring harness by Dustin from Purist Mod
-VDO Oil Pressure and Oil Temperature gauges
-OFT Tablet Stage 1 Tune (sold)
Wheels:
-Avid 1 AV-20 Wheels
-ARP extended wheel studs
-20mm 5x100 Spacers
Interior:
-Takata 2.5" harness
-Short throw shifter
-Flossy 500G shift knob
Quick background information:
This is the first car that I've began modifying and taking to drift events. I use this car as a daily driver and I'm currently located in Orlando, FL and attending college.
I got this car because it was pretty much the best option since I was looking for a new car that was not too expensive that was also rear wheel drive and lightweight with low maintenance.
I thought that the FRS would be a car that could be driven daily and also occasionally driven to the track and back home without needing a seperate vehicle. I think these are some of the things that make the FRS and BRZ very appealing cars.
I had this car for about two years and when I moved to Orlando I began taking it to the local track Orlando Speed World to attend drift events.
Before the FA20 blew I took this car to one event after I had bought an OFT tablet and installed the stage one tune.
The only engine mods I had on at this time was an HKS filter for the oem intake, a buddy club catback, and the OFT tune.
The car drove really good and I learned a lot since it was my first event with the car.
Toxicmilk45 is offline   Reply With Quote
The Following 11 Users Say Thank You to Toxicmilk45 For This Useful Post:
gatorbushmen (12-27-2016), hmong337 (12-26-2016), JD001 (12-27-2016), Juvenile (12-26-2016), Kris86 (12-26-2016), Pekingduck (05-06-2017), radroach (12-26-2016), Ramn (12-26-2016), RSKYBZ (12-27-2016), Teseo (12-27-2016), whataboutbob (12-26-2016)
Old 12-26-2016, 10:10 AM   #2
radroach
Drives: car
We've been waiting on a 3GSE build, finally
(actually guess its not the first build.. but still excited for you)
The Following User Says Thank You to radroach For This Useful Post:
funwheeldrive (12-26-2016)
Old 12-26-2016, 11:21 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This is the engine the car should've been built with.
hmong337 is offline   Reply With Quote
Old 12-26-2016, 11:37 AM   #4
Teseo
Drives: frs
And how much cost for the swap only (engine, trans, drivetrain? Ecu, engine mounts etc)
Old 12-27-2016, 04:03 PM   #5
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Videos or it didn't happen
Devil 86 is offline   Reply With Quote
Old 12-27-2016, 04:05 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Hi from Tampa, nice build.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-27-2016, 05:42 PM   #7
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Finally making a dedicated build thread
gatorbushmen is offline   Reply With Quote
Old 12-27-2016, 11:18 PM   #8
Toxicmilk45
Here we have a video made by my friend Alan who also happens to drift his FRS a lot and is really good at it too. He makes super good quality videos and are all super interesting. I'm sure some of you guys already know who he is!
[ame="https://www.youtube.com/watch?v=DupEdhpc5yw"]BEAMS Swapped FRS | Fixing my Cracked Bumper - YouTube[/ame]
Then here is a video of when the engine was first running really badly off of the stock BEAMS ecu, modified oem engine harness, and original cable throttle body.
[ame="https://www.youtube.com/watch?v=xiW53bod_NY"]https://www.youtube.com/watch?v=xiW53bod_NY[/ame]
The Following User Says Thank You to Toxicmilk45 For This Useful Post:
trueno86power (01-01-2017)
Old 12-27-2016, 11:28 PM   #9
Toxicmilk45
3SGE engine and trans sets cost about 1000-1500. ECU is Haltech elite 2500 which is 1500 new, driveshaft was 450.
Custom engine mounts I made myself out of cardboard then brought it to a welder and worked with him to make them.
Custom modified headers by Kings Performance.
The Following 6 Users Say Thank You to Toxicmilk45 For This Useful Post:
D_Thissen (01-02-2017), FujiwaraTofu86 (12-28-2016), funwheeldrive (12-29-2016), hmong337 (12-29-2016), Lonewolf (01-02-2017), Teseo (12-27-2016)
Old 12-28-2016, 05:29 PM   #10
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
What doesn't work after the swap? Do you have power steering or A/C? It's really cool that you're taking this on by yourself.
Sent from my Pixel using Tapatalk
drew_kar is offline   Reply With Quote
Old 12-28-2016, 08:31 PM   #11
Toxicmilk45
Most of the things still work, I don't have ac since the engine sits so far back in the engine bay and since its an inline 4 it kinda blocks where the ac lines would normally go through the firewall. Fans still work to blow air but not ac.
Dustin gave me some info on how to get the stock tach to work and also the coolant gauge but I haven't gotten to it yet. I have some wires from the chassis that go to the haltech to power things like the fans but when I connected it to the stock ecu things got a bit funny so I decided to get aftermarket tach anyways because racecar.
Fuel gauge doesn't work because I got a fuel cell and haven't installed a fuel level sender in the cell. Once a sender is installed it would be easy to get the oem fuel gauge to work.
Instagram: schen_86
3SGE FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=114039
drew_kar (12-28-2016)
Old 12-28-2016, 09:36 PM   #12
Toxicmilk45
Just some photos of my car a while back when it still had the boxer and I was living in South Florida.
This is one of my favorite photos of my car still to this day.
When things were simpler lol.
Instagram: schen_86
Old 12-28-2016, 09:46 PM   #13
Toxicmilk45
About a month later I went to my second event at Orlando Speed World, Frankenslide.
I had taken it on about two or three runs and the car was feeling really good.
Then my buddy Alan decided we should strap a Go Pro onto the car which then led to this:
[ame="https://www.youtube.com/watch?v=LQpFy4kn5co"]https://www.youtube.com/watch?v=LQpFy4kn5co[/ame]
I thought it was one of the catch can hoses that pop off but it turns out this happens:
Alan happened to have his FJ Cruiser with him and was able to help me tow the FRS back to my place. My other friend Greg wearing the black shirt in the photo which I met from a mutual friend one time while I was on a paintball team a while back, had towed his car to the event and let me borrow his friends trailer for a little bit.
I can't thank them enough for volunteering to help me out and let me borrow their equipment!
Instagram: schen_86
The Following 2 Users Say Thank You to Toxicmilk45 For This Useful Post:
drew_kar (12-28-2016), Kris86 (02-01-2017)
Old 12-29-2016, 12:46 PM   #14
hmong337
Emperor JDM
hmong337's Avatar
This makes me feel sad for the fa20 :-(
The Following User Says Thank You to hmong337 For This Useful Post:
Tire Sale - Achilles, Federal, Nankang, Sunny, Falken, Hankook, Nexen, Accelera, etc Sonic Motor Wheels and Tires 394 07-29-2016 02:13 PM
How many of you Swapped your 86 for 15 WRX ? Xti Scion FR-S / Toyota 86 GT86 General Forum 45 08-09-2014 09:09 AM
Sunny day, so I had to take some pics ichitaka05 BRZ Photos, Videos, Wallpapers, Gallery Forum 7 07-01-2014 05:32 PM
Sunny day snaps of my finished SWP Limited Ouhei BRZ Photos, Videos, Wallpapers, Gallery Forum 24 04-10-2014 10:21 AM
Ultramarine FR-S on a sunny day (Multiple Pix) CoRi J FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 05-25-2012 06:58 PM
