#3851 |
Drives: 2015 supercharged frs
#3852 |
Attached is a pic of my engine bay
#3853 |
pessimistic skeptic
#3854 | |
Drives: Subaru BRZ / Toyota 86 Experts
#3855 | |
Drives: 2015 FRS
![]() Sent from my Pixel using Tapatalk |
| The Following User Says Thank You to Reamer For This Useful Post: | CounterSpace Garage (12-22-2016) |
#3857 |
#3858 |
#3859 | |
Drives: 2014 WRB BRZ Limited
With regards to e85 or HBP, seems as though I will definitely need to upgrade the injectors and fuel pump. This answers #2 and #3 above. My biggest hesitation is deciding between c30 and c38... The biggest reason I am leaning towards the c38 is to leave the door open for big power down the road. But, if I only ever run the CARB tube or a flex fuel and/or HBP setup, would I ever regret the c38? In other words, when does going for the c38 pay off? |
#3860 | |
| The Following User Says Thank You to JDMChris For This Useful Post: | BR-ZED (12-28-2016) |
#3861 |
Thanks. I saw a dyno somewhere of a c30 vs c38 and they were close. But I think the c38 made a tad bit less power down low and more up top.
Edit: I think I was remembering the first dyno here. Not sure if it's the CARB tune or not, but it seems the c38 suffers on the low end but does better at high RPM. It seems it is superior to the C30 once the HBP and flex fuel are added to the mix. http://blog.vittuned.com/jackson-rac...ft-86-fr-sbrz/ Let's say I don't do the HBP though... Would the c38 still outshine the c30? Would I need to upgrade the internals and clutch if I ran 1. C38 + flex fuel + injectors + fuel pump 2. C38 + flex fuel + injectors + fuel pump + HBP Last edited by BR-ZED; 12-28-2016 at 07:03 PM. |
| The Following User Says Thank You to BR-ZED For This Useful Post: | -Phil (12-29-2016) |
#3862 | |
Drives: frs
I was running flex fuel with a c30, and I snapped a rod. Catastrophic.Engine.Destruction. I will now have to have an engine built, as I was on the ragged edge of what was safe for this engine with stock internals. Keep this in mind when making your decisions. A c38 will provide head room, but to what end? As it turns out, I will be upgrading to a c38 so I can run high rpm. Thought my experience might be useful to you. Good luck!
#3863 |
Drives: 2015 Scion FRS
Oil cooler vs. Radiator with cooler
I'm sure it's been asked and answered, but... which is the best route to go, JR Radiator with oil cooler, or just the oil cooler alone? Not concerned with the extra $$, just want the best option. Running the JRSC C-30, flex fuel kit, Ace 350 Header and full exhaust.
Thanks!! |
#3864 | |
Here's where it came up before in this thread http://www.ft86club.com/forums/showt...il#post2644696 Last edited by BR-ZED; 12-29-2016 at 01:23 AM. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
