Old 12-21-2016, 02:59 PM   #1
mdec
Drives: scion frs
E85 Question
Lets say like a few folk here I want to keep the Car NA. Seems like the E85 + Cat-less Header + Tune is a common option. If I go with the Moto East Flex-Fuel kit & at some point in time inevitably find myself with a mix of E85 & regular gas - exactly how does the de-tune process work ? does the ECU constantly modify the E85 tune based on %Ethanol detected or default to some 'lower tune' state.
Apologies in advance for this newbie question.
mdec is offline   Reply With Quote
Old 12-21-2016, 03:06 PM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
The flex-fuel kit reads the ethanol percentage in the fuel and changes the tuning accordingly. You wouldn't need to do anything to switch between the two. That is why flex-fuel is so nice.
The Following User Says Thank You to DustinS For This Useful Post:
kch (12-21-2016)
Old 12-21-2016, 04:54 PM   #3
Chronology
Drives: 13' Satin White Pearl BRZ
This....IF you are running an EcuTek, the OFT will not auto adjust. So from my personal use, e85 at my station(s) gets me a e84, not bad. If I go 50/50 E85/Pump lets say I am at E60..The Moto-East FlexFuel tune and sensor enables the ecu to "re-tune" to a lower Ethanol content automatically.
Correction - OTF will NOW auto auto adjust.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 12-21-2016, 04:54 PM   #4
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
yea the flexfuel has a sensor to read out and that communicates with the car's ECU. depending on the tuner (guessing moto east if you're buying their flexfuel) they will create a table of different values which allows the car to adjust timing/afr on the fly depending on the ethanol content. It's quite convenient to run flexfuel rather than having two maps one for 93 octane and e85 since e85 isn't ALWAYS 85% ethanol..
pgranberg11 is offline   Reply With Quote
Old 12-21-2016, 04:57 PM   #5
DustinS
DustinS's Avatar
Originally Posted by Chronology View Post
This....IF you are running an EcuTek, the OTF will not auto adjust.
That is actually incorrect at this time. OFT Does offer a Flex-Fuel kit.
Old 12-21-2016, 05:00 PM   #6
Chronology
Oh sorry my bad. When I was deciding. OFT didn't support auto fuel adjustments. Ill adjust my comment. TIA.
Edit - Added link for OFT - http://www.openflashtablet.com/shop/...flex-fuel-kit/
The Following User Says Thank You to Chronology For This Useful Post:
DustinS (12-21-2016)
Old 12-21-2016, 07:59 PM   #7
mdec
Drives: scion frs
thanks guy's so what your saying is that if I go for the OFT E85 Tune I need to purchase their Flex-Fuel kit fort the 'Auto Tune' capability to function correctly ?
Old 12-21-2016, 08:32 PM   #8
Lantana frs
Drives: 13 frs red
I have e85 a block from my house but I won't try it without a ff setup. It says right on the pump 59 percent minimum ethanol content. I don't feel safe running straight e85 tune.
Lantana frs is offline   Reply With Quote
Old 12-21-2016, 09:09 PM   #9
swarb
yes
FI question Christopherkuchta Forced Induction 3 08-29-2016 05:49 PM
Air bag question JoeMartin Scion FR-S / Toyota 86 GT86 General Forum 5 11-04-2014 01:04 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
BRZ Question geb2391 BRZ First-Gen (2012+) — General Topics 24 11-19-2012 10:49 AM
