Southern California SoCal
Old 12-20-2016, 01:21 PM   #9227
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
CUSCO BRIDE ZETA III FIXED BACK used prolly 20 times max.
BRIDE RAILS TYPE FO
LOOKING FOR 1000$ OBO text me 310 749 9247
no delivery pick up only located in torrance
Has half inch fray on front bottom padding - could prolly cut if off (i wont though)
also have a BLACK schroth ralley ASM 4 pt harness for 100$
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 12-20-2016, 02:21 PM   #9228
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
ENKEI RPF1 SBC 18x9.5+38
hankook v12 245/35/18 still meaty
1100$ OBO text me 310 749 9247
purchased these wheel new - now up for sale
1 wheel has a knick on it due to me jumping a small curb getting out of a small driveway . the other two has small knicks less than 2mm not noticable from 3-4 feet
1 wheel as far as my fingers can feel has no issues
looks good once you wipe it down very shiny
here it is on my car
Flex Fuel Turbo BRZ
Old 12-20-2016, 02:33 PM   #9229
Apex-Apex
Apex-Apex's Avatar
Originally Posted by Apex-Apex View Post
All parts are located in Rowland Heights, CA
Velox Diffuser aggressive style. Requires rivnuts and rivnut hardware from Velox. $400
JDL Catback 3" Used for a few thousand miles $600
bump
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 12-20-2016, 04:10 PM   #9230
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
FS: $30 - HIC window visors, you will need to use new tape. Visors in perfect condition.
asdf is offline   Reply With Quote
Old 12-20-2016, 06:52 PM   #9231
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
FS: Whiteout Trunk wrapped in 5D CF wrap. No holes on trunk. Trunk is in good condition, paint has like 2 scratches. Wrap is ok but edges are starting to wrinkle.
$200 firm
Pick up only in Rosemead
Decimus is offline   Reply With Quote
Old 12-20-2016, 10:10 PM   #9232
frs4mark
frs4mark's Avatar
Drives: Asphalt FRS
Originally Posted by frs4mark View Post
I have a set of RG3 for sale. These go for +$2,400 new. I don't have my car anymore. These were used for about 2 years. I kept them very clean.
comes with Advan Center Cap - Full Flat Cap (Bronze Alumnite) ($250 new)
Two of the wheels only have rock chips and a scratch.
Selling for $1,700 for the whole set picked UP.
I live in SGV
Text: (626) 321-5507
bump Priced Lowered
frs4mark is offline   Reply With Quote
Old 12-21-2016, 01:03 AM   #9233
Simplicity
Simplicity's Avatar
Drives: 15' MT FRS
Originally Posted by Simplicity View Post
USED - APR Splitter - $250 - CASH ONLY
The splitter is completely fine with NO CRACKS OR ANYTHING.
Just the marks/scratches you see from the pictures.
Once installed, NO marks will show up on the splitter since the bumper is completely covering it.
GET THIS WHILE IT LAST!
I ALSO HAVE 2 GROUPON TINT VOUCHERS
3M Premium Tint for 5 WINDOWS
Retail Value: $150
My Price: $90
Regular Tint For 5 WINDOWS
Retail Value: $150
My Price: $80
LOCATED IN LOS ANGELES / SAN GABRIEL VALLEY AREA
TEXT ME 626 - 765 - 1993
BUMP, TEXT ME IF YOU'RE INTERESTED! 626 - 765 - 1993
Simplicity is offline   Reply With Quote
Old 12-21-2016, 02:25 PM   #9234
95BRZ
( ͡° ͜ʖ ͡°)
95BRZ's Avatar
Drives: Yes
$200 firm
I'll trade you 1 milk tea, I'll even throw in boba
95BRZ is offline   Reply With Quote
Old 12-21-2016, 06:19 PM   #9235
HahaJasp
HahaJasp's Avatar
Drives: 2016 Scion FRS
FS: 2016 FRS stock exhaust. Installed an N1 at 7k miles. Had it in my garage since. $150 OBO. Text me 6198870030. Need gone asap
Sent from my SM-G920V using Tapatalk
Turbo FR-S
Instagram= FrsJasp
HahaJasp is offline   Reply With Quote
Old 12-21-2016, 06:34 PM   #9236
azynneo
TE37SL Double Pressed black wrapped in 255/40/17 rs3 17x9.5 squared. Looking for advan gts in white + tires or cash.
951 281 9522
azynneo is offline   Reply With Quote
Old 12-21-2016, 06:36 PM   #9237
philstar
philstar's Avatar
Drives: Argento FR-S
Berk Technology front pipe (non-catted) $120 picked up in Chino Hills or City of Industry
philstar is offline   Reply With Quote
Old 12-21-2016, 06:52 PM   #9238
philstar
philstar's Avatar
STANCE V1 rear LCA
Price: $300 picked up in Chino Hills or City of Industry
Willing to ship at buyers expense.
Message me to purchase.
"STANCE Adjustable Lower control arm is made from billet aluminum for strength and durability. Lower arm is used to adjust camber and the range is negative 1deg ~ 6deg. STANCE uses Aurora Rod ends. The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA Applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. Stance uses Aurora's 3pcs billet rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability.
STANCE LCA is designed to raise the hub mounting point about 20mm,compared to stock, which lowers the car about 25mm. This allows for longer stroke dampers found on the STANCE FR-S application, and have more height adjustment range. This design is especially helpful for 1way height adjustable coilovers like KW, which loses stroke as you lower the car."
Old 12-22-2016, 10:17 AM   #9239
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
BRIDE RAILS TYPE FO
HARNESS SOLD - BUCKET SEAT AVAILABLE!
Flex Fuel Turbo BRZ
Old 12-22-2016, 05:23 PM   #9240
Oakley
Oakley's Avatar
Drives: Scion FRS
[IMG][/IMG]
$20 for Super Red LED 3rd Brake Light DIY Conversion Kit For Scion FR-S
$40 for 3000K Amber Yellow 40W COB High Power H11 Fog light
$100 for APR Performance Carbon Fiber Radiator Cooling Plate - Scion FRS for TRD intake
[IMG][/IMG]
$2800 for Volk Racing ZE40 Diamond Dark Gunmetal 18x10 +40
Oakley is offline   Reply With Quote
