Old 12-18-2016, 09:50 PM   #1807
kbogarto
Drives: 2013 BRZ limited WRB
Originally Posted by JustBoostin View Post
Hey guys, has anyone else had issues with the turbo inlet tube slowly working it's way off the turbo? I haven't been able to figure out a solution all year. I've tried all I could think of. If anyone else has encountered this I'd love to hear about a solution. Thanks
It's been a problem for me for over two years. Multiple people have had issues with this. Unfortunately there is no easy fix. Someone on here pulled the turbo and welded a bead to hold the pipe on. I tend to unhook all the pipes and reconnect everything every few months. Are you running the 50-50 BOV?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 12-19-2016, 10:52 AM   #1808
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mine has been holding very well. but I wonder if it is a case of low mileage, stiff motor mounts, little movement to cause it to wiggle off?
I should check tho, just to be sure/
Old 12-19-2016, 11:00 AM   #1809
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Christopherkuchta View Post
My current tune since I got the avo kit installed is from august 5th this year and my first ecutek tune was from the beginning of 2016
Speak to your tuner and advise that you think this might be the issue and see what they say. Might not have realised as it won't have reared it's head until now. Not sure if only impacts a certain RR revision or ROM type but ECUtek should have resolved this or advise. It's not easy updating to a newer RR file or ROM type as you have to manually copy the tables I assume a lot of tuners don't bother....
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-19-2016, 09:31 PM   #1810
onzippy
Drives: 2014 FRS
I tried different clamps, cable ties and trimming tubes.... along the same idea of welding a bead on the turbo inlet, I finally came in from the bottom and drilled and tapped for a stainless round head machine screw on the inlet. The wall is very thick and plenty to thread. Once installed, the head of the screw creates a bump that prevents the clamp and tube from sliding off. Was a PITA for over a year but hasn't moved now. Also, would recommend using the tbar clamps instead of the worm gear. Good luck..check your tube for damage from rubbing on pulley if it has been loose for a while.
Sent from my SGH-T999 using Tapatalk
onzippy is offline   Reply With Quote
The Following 2 Users Say Thank You to onzippy For This Useful Post:
CxG (01-30-2017), kbogarto (12-22-2016)
Old 12-29-2016, 09:13 PM   #1811
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
I felt that tube just needed to be a bit longer and it would stay. If the clamp is removed, it has a natural tendency to rest just shy of the turbo inlet flange, and since there is no hump there for the clamp to work with, the vibrations will always cause it to naturally work its way off.
I found a silicone reducing coupler laying around that fit around the outside of the AVO kit's rubber inlet hose, then reduced down to the same size as the rubber hose. This gave me an extra inch or so of hose, and now it stays on even without the clamp. (Of course I still use the clamp also. )
killboy is offline   Reply With Quote
The Following 2 Users Say Thank You to killboy For This Useful Post:
CxG (01-30-2017), kbogarto (12-30-2016)
Old 01-10-2017, 08:22 PM   #1812
Astroboy
Astroboy's Avatar
Drives: None
Where the bypass valve is. Slice off about an inch.
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 01-19-2017, 05:12 PM   #1813
Unclewonka
Drives: Red GT86 manual (July build)
Originally Posted by Unclewonka View Post
Long time lurker here.
Have a July build 2012 GT86 manual that has run an AVO Stage 1 kit since March 2013. This is with a stock overpipe and frontpipe, and AVO's 2.5" resonated catback, sitting on 18" TE37SL with low profile tyres.
She has seen a bit of a hard life - I daily'd it from the time it was boosted at 18,000km through to 78,000km. It hasn't missed a beat in this time. At the 60,000km mark I decided we would swap the "stock" 5psi spring for an 8psi actuator, EBCS, fuel pump, 1000cc injectors and E85 with an Ecutek tune - the one and only dyno run it had was 240whp on E65 (Dyno Dynamics hearbreaker dyno) but with an erratic boost profile (peaked at 7.5psi at 4,000rpm and was down to 4psi at 7,000rpm. Learned that my spring was faulty and not pulling as much boost as the box said - have since swapped it for a 12psi spring with a "safe" non-dyno tune for RON98 and E85.
Curiously, while the 12psi was working as advertised on bench test, I only pulled about 9-10psi - apparently due to a pressure drop across the intercooler.
Haven't driven it for seven months (rural hospital attachment) but am back now - awaiting an Empire 2.5" overpipe, MAP resonated catless 2.5" frontpipe and a Hypertune Intercooler. Have decided I'll probably end up running 16lb at most, get a dyno tune and call it a day. I guess 1000cc injectors are a bit of overkill.
Will keep you all posted :-)
Sorry guys, forgot to keep you all posted!
Anyway, long story short, my tuner didn't push it past 10psi because it started to rock the engine mounts allegedly. Here's a dyno plot that might explain way. On a Dyno Dynamicsheartbreaker dyno again as well, on 18" wheels with 265/35R18s - you'd get about a 15-20% higher number on DynoJet. I'm absolutely flabbergasted that I'm getting this much on such little boost.
Unclewonka is offline   Reply With Quote
The Following 2 Users Say Thank You to Unclewonka For This Useful Post:
Alltezza (01-19-2017), CxG (01-23-2017)
Old 01-23-2017, 05:17 PM   #1814
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
i have the stage 1 AVO kit with the recirculating BOV. If i want the 50/50 BOV what modifications do i have to do to the car. Retune?
2thdoc is offline   Reply With Quote
Old 01-23-2017, 07:31 PM   #1815
Unclewonka
No change to tune whatsoever.
The Following User Says Thank You to Unclewonka For This Useful Post:
2thdoc (01-30-2017)
Old 02-11-2017, 06:56 PM   #1816
kuchtaa
Drives: 2015 limited BRZ
Angry White smoke from turbo
Has anyone ran into a problem similar to this? I have cel codes p0171 p050a p117b and p1170. The car idles then dies, there's smoke coming from where the actuator connect to the turbo and from the exhaust. Belows a video of where the smoke is coming from.
kuchtaa is offline   Reply With Quote
Old 02-13-2017, 01:49 PM   #1817
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I have never seen a turbo look powder white like that without it being bad news...you also have a oil leak on the hot side. Very bad
The Following User Says Thank You to SkAsphalt For This Useful Post:
Draco_PR23 (02-14-2017)
Old 04-18-2017, 04:52 PM   #1818
shayangh
Drives: 2015 Brz
Quick question from a lurker, what oil coolers are you guys using if any? Any other cooling modifications?
shayangh is offline   Reply With Quote
Old 04-20-2017, 07:04 AM   #1819
kbogarto
I don't track my car. I don't necessarily recommend it but I'm not running an oil cooler. I just watch my oil temp carefully and don't let it get above 240.
Old 05-03-2017, 10:36 PM   #1820
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
have you solved the problem ? turbo replacement?
andrewFT86 is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
