Old 12-17-2016, 11:39 PM   #3431
rkaywhodat
Drives: 2017 Toyota 86 Halo
The one thing I never came across in my research before buying this car was how crap the stock battery is, brand new and is struggling a bit already in cold weather.:S
2017 comes with the same as previous years Panasonic CCA 390
Sent from my D5803 using Tapatalk
rkaywhodat is offline   Reply With Quote
The Following User Says Thank You to rkaywhodat For This Useful Post:
JD001 (12-19-2016)
Old 12-18-2016, 07:55 AM   #3432
WWFT86
Drives: 2017 BRZ Limited
Originally Posted by FX86 View Post
nah i prefer building the BRZ but you are most likely right..expensive lights though for $300+....white leds in fog won't do anything...it's all for decoration
In my 2017 BRZ I can attest the fog light makes a significant difference illuminating the immediate road surface to the front and sides. So those fog light does work as intended (presuming the Toyota ones are the same).
WWFT86 is offline   Reply With Quote
Old 12-18-2016, 09:33 AM   #3433
Ashikabi
Ashikabi's Avatar
Mine works fine. Started it yesterday at -20 degrees F on e85 and it was fine
Old 12-18-2016, 09:57 AM   #3434
Cole
Not a troll
Cole's Avatar
Have never had an issue with my battery. Maybe people don't realize that they need to maintain them?
Cole is offline   Reply With Quote
Old 12-18-2016, 10:00 AM   #3435
Ashikabi
Ashikabi's Avatar
It's possible there are just a lot of bad ones. I was going to switch to a tiny 5 pound battery but now that I have a GPS and will have a dash cam drawing power constantly I'm not sure that's going to be practical anymore
Old 12-18-2016, 10:54 AM   #3436
Cole
Not a troll
Cole's Avatar
Seems like awful QC. I find that kind of hard to believe, but I guess not outside the realm of possible.
Old 12-19-2016, 04:14 PM   #3437
Dake
Dake's Avatar
Mine's just now starting to crank a little slowly in the cold on the original battery which is over four years old. Thanks mostly to the heat down here in Texas, most batteries only last five or six years so I figure that's not too far off.
Dake is offline   Reply With Quote
Old 12-19-2016, 04:18 PM   #3438
JD001
JD001's Avatar
Drives: Subaru BRZ
I had my original battery exchanged under warranty. The new is very good (touch wood).
Old 12-19-2016, 07:43 PM   #3439
WWFT86
For what it's worth - I experienced the same initially, however after getting my 1st oil change (to Mobil 1 0w-20) done the engine now turns over "normal" even when it's even colder now than before. My 2cents...
Old 12-19-2016, 07:48 PM   #3440
0w-20 is 0w-20 no matter who makes it so I don't know how it would make anything change as far as starting goes.
raven1231 (12-19-2016)
Old 12-19-2016, 07:56 PM   #3441
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The placebo is strong with this one.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
KalbiCool88 (12-19-2016), Tcoat (12-19-2016)
Old 12-19-2016, 08:35 PM   #3442
WWFT86
Well, consider these:
1. Is it possible that the 0w-20 motor oil from the factory when they deliver the car, is a slightly different formula than the ones used in subsequent oil changes.
2. Isn't it a common fact that as the car get driven, motor oil loses viscosity and gets dirty. This is especially true in a brand-new vehicle as there are more metal particles, thus a possibility that the oil no longer has the same viscosity range (ie. 0W-20) that it would have when it was new? I can see that the original oil having lot of metal particle from initial engine break-in, moisture and acids from combustion blowby, etc.
Old 12-19-2016, 08:48 PM   #3443
0W-20 is 0W-20. Correct it is a range not an absolute number and if your used oil has exceeded that range enough to impact cranking then that would be amassing. "Formula" has nothing to do with it. If you have that many particles in your engine after break in you are going to have issues.
Old 12-19-2016, 09:07 PM   #3444
gymratter
Drives: BMW
That Was Fast: Toyota Recalls Certain 2017MY 86 Models
Toyota announced it’s recalling certain 2017 86 models, equipped with the automatic transmission, in North America.
The company said that the 94 involved vehicles that have an increased risk of rollaway when parked and crash as the connectors for the automatic transmission key interlock may not have been connected during the pre-delivery service.
If the connectors were not connected, this allows removing the key in gear positions other than ‘Park’, hence the safety risk.
All known owners of the involved cars will be notified by first class mail, starting in January where they’ll be instructed to return their car to a Toyota dealer to have the ignition key interlock checked and if necessary, connect the delivery mode connector at no charge.
Toyota revised the 86 model (formerly known as the Scion FR-S) for MY2017 with more aggressive looks, a stiffer chassis and a slightly more powerful 2.0-litre flat-four engine that now makes 205hp and 156lb-ft of peak torque.
http://www.carscoops.com/2016/12/tha...s-certain.html
gymratter is offline   Reply With Quote
The Following User Says Thank You to gymratter For This Useful Post:
funwheeldrive (12-19-2016)
buttons everywhere, damn daniel, i hate it, i love it, much opinion, mustache ride, rosted zaku by soa, so change, very tryhard
2017 = more power alan.chalkley Engine, Exhaust, Transmission 62 07-08-2016 07:24 AM
2017 Toyota 86: The car so nice it's been rebadged twice dazob Scion FR-S / Toyota 86 GT86 General Forum 10 02-04-2016 05:12 PM
Styling cues Suberman BRZ First-Gen (2012+) — General Topics 22 11-04-2013 10:45 PM
