| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2015 Toyota 86
Wheels and Tyres for Rocket Bunny V1
Im really sorry if this is a repost but I needed a quick reply.
Im planning to go wide and my Wheels specs are as follows Front 18x9.5 +15 on 245/45 [with 25mm wheel adapters] Rear 18x10.5 +15 on 275/40 [with 25mm wheel adapters] Would I experience any rub on these specs? |
| The Following User Says Thank You to Mo7ammed For This Useful Post: | Leonardo (12-18-2016) |
#2 | |
| The Following User Says Thank You to D_Thissen For This Useful Post: | Mo7ammed (12-20-2016) |
#3 |
Country Boy 4 Life
So you effectively have -10 front and -10 rear. Read below to see what was suggested. It looks like to me, you will need a 20mm spacer for the front and a 40-45 for the rear.
Also, if you google "ft86 rocket bunny wheel" it will pull up all the threads. I find it is easier to use than the forums search function. Good luck! Text below copied from the thread copied. Front Honestly a 9.5 width is the best upfront. You really need an effective offset of either -5 or 0 it all depends on tire size to prevent rubbing. a tire size such as 245 35 18, (with a 35 sidewall will be ok with a -5) however running a 225 40 18 (40 sidewall) will require at least a 0 offset. My current setup is 18x9.5 with a Effective offset of 0 running a 225 40 18 tire. Rear you can run anything from a 9.5-11+ in the rear. The best offset for a 9.5 is a Effective offset -40 the rear is a bit harder to do math on but look at it this way; for every inch more than 9 it ads half an inch from the center (imagining the front) so a 18x10.5 rear will require a Effective offset will require a -25mm-30mm offset to run a fat tire a 9.5 requires a -40 offset but you need a slight stretch. http://www.ft86club.com/forums/showthread.php?t=20429
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Mo7ammed (12-20-2016) |
#4 | |
Not sure what I can do now. Tried 235/40/18 and theres still not enough |
#5 |
Is it rubbing on the fender liner or on something else? Are you using spacers?
#6 | |
The part where its blue right next to the lowest rivet. So it brushes past the black fender and then touches that bit that sticks out http://imgur.com/a/8dBN9 The specs of the wheel I tried are 18x9.5 +15 offset with a 25mm spacer and the tyre specs are 235/40/18 |
#7 | |
Country Boy 4 Life
Get a smaller spacer and tire. The guy from the thread I quoted is running 0 offset (tire +spacer) and a 225/40 tire. 235/40 is 25.4" diameter stock diameter is 24.6". A 235/35 would be better , 24.5"
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Mo7ammed (12-21-2016) |
#8 | |
Initially we tried with 245/45/18 and that hit on the front and the back Then the 235/40/18 and that in the rear Im hoping I wouldn't have to change my 25mm adapters and make it work on 35's. |
| The Following User Says Thank You to Mo7ammed For This Useful Post: | Leonardo (12-22-2016) |
#9 | |
Country Boy 4 Life
The width of the spacer will effect the distance to the edge of the tire as you turn. So, if you don't want to get new spacers, I would try a 225/35 or 235/35 front tire.
I LIKE TIRES! |
#10 |
Drives: 2013 Ultramarine FR-S
Alternatively You can bash/cut/grind that extension down. Shouldn't hurt anything and I have read quite a few people doing that. I actually have plans to grind it down eventually as it rubs with my winter set-up.
#11 | |
The place I'm getting it fit doesn't think it will fit and that a 9.5 is too wide for the front. Last edited by Mo7ammed; 12-22-2016 at 06:19 PM. |
#12 |
Drives: 2014 Subaru BRZ
#13 | |
Country Boy 4 Life
Guys run coilovers to be able to use 9.5" wide front wheels on stock body. Your wheels are not the issue. I would get some camber bolts though, if you don't have them already. They are inexpensive. You can reuse the bolt you take out if the bottom hole in the upper hole to get a little bit more camber. Here is a a thread... http://www.ft86club.com/forums/showthread.php?t=70035 I hope that the tire diameter change will help. Also, I think that modifying the body, as suggested by DustinS, is an ok plan, if you decide to go that route. Good luck! Keep us updated. Thanks!
I LIKE TIRES! |
#14 | |
I might have to resort to grinding that bit down for now. It definitely clears the struts by miles just before a full lock turn it rubs against the metal extrusion. This build is turning out to be more challenging that I thought |
| The Following User Says Thank You to Mo7ammed For This Useful Post: | Leonardo (12-27-2016) |
| Any way to get these wheels to fit rocket bunny v1? | CyberAkuma | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 12-13-2014 11:35 AM |
| Wheels for rocket bunny v2 | crildz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 03-10-2014 10:53 AM |
| Wheels for Rocket Bunny? | Yamajee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 01-27-2014 09:59 AM |
| Rocket Bunny|PUR Forged Wheels | 3W Distributing | Exterior Parts - The Rest | 0 | 01-02-2014 07:19 PM |
| rocket bunny kit vs wheels | Jhon19lopez | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 08-08-2013 11:11 AM |
