Old 12-18-2016, 12:10 AM   #2577
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Shneegle View Post
What do you mean why? Harness can hold you better than the seat belt...
They start you down a slippery slope on street safety. Some may be OK, but I'm not sure they all are (and that assumes your not using the harness on the street). If you want a harness just for AutoX, why not a Schroth Rallye 3? If you're going fixed back seats and stuff, it may be worth a look.
Old 12-18-2016, 05:10 AM   #2578
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I mentioned in my post that I would NOT be using the harness bar and harness on the street. Also that I wanted to use stock seats with it during autox. Ill just ask my question in a different way since you cant read past harness bar.
So who is running a half cage or full cage, fixed back seats and harnesses for STX?
Shneegle is offline   Reply With Quote
Old 12-18-2016, 08:51 AM   #2579
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
I have the G-Speed 4-point roll bar with harness bar which I've mounted Schroth clubman III 6/pt harnesses installed with the OEM seats in my BRZ. For street driving I use the OEM seatbelt system.
I fabricated a bracket for attaching the clips for points 5 & 6. I route them under the seat to the bracket with ring bolts for the belt clips. The bracket mounts underneath the two, rear seat-frame mounting bolts.
And yes, the passenger, inboard rear seat frame mounting bolt head failed. Insert deleted expletives here. I now have eight bolts in Subaru plastic bags waiting for me to extract said bolt and replace with one from my hoard. Reuse the seat frame mounting bolts at your peril.
G-Speed welded attachment bolt plates on the both sides of the tunnel. I use Schroth clip attachment extensions under the door jam mounting bolts of the OEM seat belts, as well as with the passenger side tunnel mount using a hex head bolt. The passenger seat sits closer to the tunnel than the driver seat. The ring bolt hits the seat. On the driver side I installed the ring bolt from Schroth.
I use a OEM front seat belt metal insert (salvaged from a jammed seatbelt assembly) snapped into the seat belt receptical to spoof the system. Note: the clip inserts for the rear seatbelts are different from the front seat clip inserts.
All this happened after the 2016 Autocross season ended for me. Evaluation on a course will take place in March. In the meantime, you're welcome to see what I've done and check the fit for your application.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 12-18-2016, 11:34 AM   #2580
e1_griego
e1_griego's Avatar
Drives: Many
I'm putting in a Sparco Evo II some time in the next couple of weeks. I have one in my s13 and I'm big enough that the stock belts hit me in the waist alright. We'll see how it goes in the BRZ.
Also adding a steering wheel and QR (and weights! so it hit the same 6.24lb weight).
e1_griego is online now   Reply With Quote
Old 12-18-2016, 12:33 PM   #2581
cjd
cjd's Avatar
Drives: 2017 BRZ
Sorry, I should clarify - I was not feeling like typing on the phone last evening. If its in a spot that won't put your head/neck at risk in case of a rear impact, it would be fine. It's still your choice, of course. Same goes for a cage, though the risk of head injury is higher if not designed for street use. The harness bars I've found are at a height to hit your neck in a rear ender... If you find one thats not a risk here that doesn't add brace triangulation or remove parts of the interior, it could be a nice way to mount a harness.
I guess I don't see the value in adding the weight vs the results and safety risk off course, at least for AutoX. I haven't seen one you can take out for the street. A Rallye3 does quite well, though I guess Schroth doesn't sanction installation in this car... So still some risk, I'd guess. For AutoX, probably fine, and easy to bypass for the street.
I'm not sure if the race seats people use are fixed back, but going to the minimum weight can save another 40lbs.
I admit to being a little paranoid... Only accident I've been in was a plumbing van going 35 into the back of my truck... And people in my neighborhood don't stop at signs...
The Following User Says Thank You to cjd For This Useful Post:
Shark_Bait88 (12-19-2016)
Old 12-18-2016, 09:49 PM   #2582
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
No one. Car is too slow to need anything more than a bucket seat. I use stock seat belt with my bucket.
tigermack is offline   Reply With Quote
The Following 6 Users Say Thank You to tigermack For This Useful Post:
DocWalt (12-18-2016), e1_griego (12-18-2016), justint5387 (12-18-2016), Shark_Bait88 (12-19-2016), smg1138 (12-18-2016), xtremeyolks (12-18-2016)
Old 12-19-2016, 08:28 AM   #2583
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
If you really want a belt that'll hold you in better, why not just try a CG-lock or Schroth Profi II ASM harness? Either will improve your hold in the seat without the compromise in safety that comes with adding a harness bar.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-19-2016, 08:59 AM   #2584
cjd
cjd's Avatar
Drives: 2017 BRZ
The Profit II needs a bar or cage... The Rallye 3 is the one that works without.
Old 12-19-2016, 09:27 AM   #2585
Shark_Bait88
Ah right, that's the one I meant.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
cjd (12-19-2016)
Old 12-21-2016, 09:09 PM   #2586
xwd
I've had the Rallye 3 for years now and like it a lot. I have a set of old Prodrive Sparco seats (similar to Corsas), but I don't think the weight difference is a whole lot so I've just stuck with the factory seats.
Old 12-23-2016, 05:57 PM   #2587
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by xwd View Post
...... I don't think the weight difference is a whole lot so I've just stuck with the factory seats.
About 30lbs between both seats if built to the min. STX requirements (25lbs).
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
cjd (12-23-2016)
Old 12-24-2016, 05:12 PM   #2588
ka-t_240
Don't you have to keep the airbag in stx?
ka-t_240 is offline   Reply With Quote
Old 12-24-2016, 06:32 PM   #2589
e1_griego
e1_griego's Avatar
Drives: Many
No.
I think this comes up every time it gets mentioned. The rule was changed in 2016.
Old 12-25-2016, 02:14 AM   #2590
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Yeah, you can have the wheel and QR now but the weight cannot be lower than the stock with airbag.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
