Old 12-06-2016, 10:50 PM   #1
Eris-time
Drives: Fast looking but slow
WGP?CXR LS Kit (need feedback)
Hi, I am going to be straightforward and frank.
I am asking those who have done the LS swap, I need feedback on the LS kits from WGP and CX Racing. Also, If you used another kit.
1)What kit did you use?
2)Which functions of the car did you lose? (if any)
3)What do you know about WGP's in-house installation of the LS kit?
4)Any other relevant information would be great (things to look out for, advice etc.)
Again, I am asking those who have done the LS swap.
Eris-time is offline   Reply With Quote
Old 12-08-2016, 04:26 PM   #2
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
I've only researched one WGP build and that's their shop car. I've only researched one cx build and that was their development car. Haven't seen anyone on here that has either. Hopefully someone will chime in that owns one. Not sure how much you've read yet about the LS swaps, but there is a ton of info now and there is a bunch of reading to do. My suggestion is start with the vorshlag LS swap thread. Then go from there. There is no easy full diy kit yet but there is a lot in the works. Good luck.
turbocat is offline   Reply With Quote
Old 12-16-2016, 11:20 AM   #3
Eris-time
Thanks for the info, I do hope somebody chimes in.
WGP and CX racing make it sound like they can do a full working swap for you
Old 12-16-2016, 11:52 AM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
CX Racing Cannot. WGP says they can, but I'm not sure anyone has seen a car they have done that has everything working.
Old 12-16-2016, 01:30 PM   #5
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
CX is just engine and transmission mounts with exhaust. They do not offer anything beyond the components needed to make the swap fit physically.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 12-17-2016, 11:52 AM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
A little while back, a member of this forum bought the full kit from WGP.
He had a build thread. It devolved into a thread about how awful the kit quality was, how poorly the parts fit, how incomplete the solution was, and it went downhill from there.
A little bag of dog sh*t labeled "wiring" showed up on his porch, with 3 wires in it, and that was about the end of it.
They supposedly have billet mounts now. Maybe they've matured a bit.
...Or maybe they haven't.
If you buy either kit, don't expect anything more than hard parts, and expect to need to modify some of them.
If you don't own grinders and a minimum of a MIG welder, this is not the project for you.
There are zero "bolt-on" swaps.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
turbocat (12-18-2016)
Old 12-17-2016, 05:09 PM   #7
HTA_EVO8
Drives: Blue lotus exige
Wait for the vorshlag kit
HTA_EVO8 is offline   Reply With Quote
Old 12-18-2016, 04:38 AM   #8
cf6mech
Drives: FRS Silver LS1 swapped.
Have the Vorschlag kit, have logged over 10k miles on it. Absolutely no problems. At first was driving it with no gauges, drove it conservatively for a month or so making sure I checked fluid levels.With the Can bus not receiving any messages it goes in a default mode where you get degraded electronic power steering and a fuel gage that works in three increments, full,half,empty.....in other words it's drivable. Added analog gauges for temp, oil pressure and oil temp.....drove it a little less conservatively. Now working with MRS Electronics with there prototype can-bus translator/gateway device have full power steering, RPM/Tach, and a fully functional fuel gage tested to 1/8 of a tank with low fuel light illuminating on dash. As of yet no traction control or ABS, or cruise control. Others may want these but if it stops here I would be more than satisfied as I'm an older guy that grew up driving cars without ABS, traction control. ABS would be nice though.
cf6mech is offline   Reply With Quote
The Following 4 Users Say Thank You to cf6mech For This Useful Post:
civicdrivr (01-24-2017), M1K3 (12-18-2016), turbocat (12-18-2016), wooly35 (12-19-2016)
Old 12-18-2016, 04:34 PM   #9
Amir Ghadiri
Amir Ghadiri's Avatar
I have the CX Swap & Turbo kit. The CX kit is hardware only. You will have to do everything yourself. There are easy ways to retain Electronic Power Steering, AC, and Tach. A kind member on here helped me with EPS and Tach, and I'm sure he would be willing to help you as well if you reach out to him. Other functions surely could be retained, but most choose not to.
The quality of the CX swap kit is pretty good. I do think the turbo kit could've been designed better (turbo placement does not allow for a proper oil drain & makes you put the alternator up high where it interferes with the hood), but overall its good. If you are planning to go NA or S/C, the CX swap kit would be a great option. I wouldn't use the turbo kit again, more trouble than its worth. If you wish to turbo, use the CX top mount kit for LSx 240 (Will only fit with a wire tuck/fuse box relocation) or the STS Rear Mount kit for FR-S.
Based on my experience, my recommendation if you wish to go FI w/ your LSx swap: CX Swap kit, CTS-V Factory Supercharger. Will have to cut the hood for the S/C but it will work well.
Amir Ghadiri is offline   Reply With Quote
The Following 2 Users Say Thank You to Amir Ghadiri For This Useful Post:
hmong337 (01-21-2017), ILLSMOQ (01-23-2017)
Old 01-21-2017, 12:42 PM   #10
catchingcolds
catchingcolds's Avatar
Drives: brz ls2, vr6 corrado
I have the WGP original shop car, a couple things are the cel is on, cruise doesnt work, trunk buttons don't worn, heated seats don't work, and fuel gauge isn't reading right (will read full when full, after several miles will drop down to 1/2, then after several more mile will drop to E with fuel light on. I havent had time to look into these issues. The owner of WGP contacted me a couple nights ago (very impressed he messaged me) said to give him a call with whatever issues I have, they have upgradede their kit with cam bus illiminator and said they have upgraded there kit since the original. Right now car car is a beast, very clean installation, looks like it came that way from the factory. Hope it helps, I would recomend them.
catchingcolds is offline   Reply With Quote
The Following 2 Users Say Thank You to catchingcolds For This Useful Post:
ILLSMOQ (01-21-2017), Sportsguy83 (01-23-2017)
Old 01-21-2017, 04:40 PM   #11
ILLSMOQ
Drives: 2017 WR BLUE BRZ
I was surprised that thing was for sale for so long. Looks like a great build. How is it to drive?
Are you going to check into their "can bus solution"? I'd be interested to know what they've figured out.
ILLSMOQ is offline   Reply With Quote
Old 01-23-2017, 09:50 AM   #12
DustinS
DustinS's Avatar
Thanks. I was just looking at it. For the price of the Vorshlag headers, I could piece together almost a full turbo set-up. Was looking into the CX Racing Turbo kit. Looks like I'll go back to looking at Down and forward/up and forward turbo manifolds.
Old 01-25-2017, 03:16 PM   #13
Amir Ghadiri
Go S/C or rear mount turbo IMO. Not worth the trouble otherwise. Too much work when you could just spend some money on good heads and a cam to make the same power.
Old 01-25-2017, 04:01 PM   #14
Bullitt2496
Guest
Posts: n/a
Supercharging has some hood clearance issues depending on what type you use.
But agreed... heads/cam can make similar power on the right setup.
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
Vicious LED Feedback! Vicious LED User/Vendor/Sponsor Reviews, Feedback, Comments 191 10-07-2014 11:57 PM
Thoughts and feedback PLZ!! GarageBRZTuning BRZ First-Gen (2012+) — General Topics 3 11-17-2013 09:34 PM
Cannot submit feedback crazyfrenchbiker Site Announcements / Questions / Issues 20 02-18-2013 03:56 AM
Suspension Feedback JDMSushi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-15-2012 03:26 PM
