Old 12-15-2016, 08:35 PM   #211
stevesnj
stevesnj's Avatar
Originally Posted by PVLFD View Post
They kept saying this is a fuel problem and not a pump
It's actually both. From an unofficial test myself and others did it was the Ethanol content in the fuel. It seems the pump was not designed for Ethanol. The replacement pump may have fixed this. Time will tell. I am looking forward to the silence in the warmer weather.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (12-21-2016)
Old 12-19-2016, 06:46 PM   #212
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Originally Posted by novice View Post
Did you bring it in tuned or flashed back to stock
Went in tuned.
dhuang is offline   Reply With Quote
Old 12-21-2016, 10:53 AM   #213
stevenwhite1989
Drives: '16 FR-S
The dealer has ordered my replacement. My pump was never really loud, there was occasions where it was, but mostly it was a mild chirp. I will update when I get the new one installed.
stevenwhite1989 is offline   Reply With Quote
Old 12-21-2016, 11:08 AM   #214
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It has been about 30 days on the new pumpg with about 1300 miles. So far no chirps. Still using costco 91 winter blend gas with e10. Temps here have varied from 40 degrees to 73 degrees. Same driving habits and same gas up area. No additives added to the gas. I enjoy sounding like a regular car and not a jalopy.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
funwheeldrive (12-21-2016)
Old 12-30-2016, 10:20 AM   #215
stevenwhite1989
Drives: '16 FR-S
Anybody with the new pump running E85?
Old 01-02-2017, 05:36 PM   #216
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Got Toyota Canada to approve the pump replacement.
I'll report as soon as it's done.
mrderp is offline   Reply With Quote
The Following 2 Users Say Thank You to mrderp For This Useful Post:
HunterGreene (01-03-2017), stevesnj (01-02-2017)
Old 01-03-2017, 07:43 AM   #217
stevenwhite1989
Drives: '16 FR-S
New Pump installed, driven about 500 miles, no chirps to report.
The Following 3 Users Say Thank You to stevenwhite1989 For This Useful Post:
funwheeldrive (01-04-2017), HunterGreene (01-03-2017), N1rve (01-03-2017)
Old 01-04-2017, 08:22 PM   #218
ze12o
Drives: BRZ 2015 DGM
i have a BRZ and hopefully you gents can answer my questions instead of a wacky answer like i would find on the FR-S side of the forum (kidding btw.. )
do i have to wait for Subaru to release the TSB ?
can i bring my BRZ to a toyota dealer ?
can i bring the toyota TSB to a subaru dealer?
Thanks in advanced
ze12o is offline   Reply With Quote
Old 01-04-2017, 10:21 PM   #219
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Thanks in advanced
For Subaru:
Originally Posted by http://techinfo.subaru.com/
Service Bulletin # 09-54-12R
This bulletin provides a procedure to address customer concerns of a high-pitched “chirp”, “squeak” or “cricket” sound heard coming from the engine’s Direct Injection (DI) high-pressure fuel pump. Not all DI pumps may exhibit this sound. Some vehicles may have components which in combination with certain fuel temperatures and / or formulations, may result in aeration of the fuel
within the body of the pump and cause this sound. This result is non-detrimental to the vehicle. Production changes have been made to eliminate the source of the sound. IMPORTANT: A “clack” or mechanical “ticking” sound also made by operation of the highpressure fuel pump is considered to be a normal operating characteristic and no attempt should be made to repair it.
Information contained in any technical document found on the STIS web site should only be used as reference material for highly trained automotive technicians. Only automotive technicians have the training and the special tools/equipment to repair Subaru vehicles.
09-54-12R
09-54-12
Originally Posted by ATL BRZ View Post
Here's a glimpse of the Subaru TSB# 09-54-12R, which is dated 9/27/16
Although I cant find any info that shows that particular TSB is actually dated 9/27/16. :|
Old 01-05-2017, 08:44 AM   #220
The "It is temperature and ethanol content related" crowd are finally officially vindicated! We fought hard to prove this and now at least Subaru makes the same statement.
"Some vehicles may have components which in combination with certain fuel temperatures and / or formulations, may result in aeration of the fuel
within the body of the pump and cause this sound."
Dadhawk (01-05-2017), phrosty (01-09-2017), stevesnj (01-05-2017)
Old 01-05-2017, 10:37 AM   #221
stevesnj
stevesnj's Avatar
Awesome! We are smart one's aren't we?
Tcoat (01-05-2017)
Old 01-05-2017, 10:47 AM   #222
mazeroni
Drives: 2013 Scion FR-S Series 10
Too bad it is 30 degrees outside. Won't hear any crickets until it starts warming up closer to April. I figure we should have concrete answers by then - the procedure to get the pump replaced at Toyota (assuming they recognize the TSB?).
I sure hope so because I feel like the sound got worse over the summer. Maybe it's psychological, but I would like it addressed without me having to spend $$$.
mazeroni is offline   Reply With Quote
Old 01-05-2017, 10:50 AM   #223
stevesnj
stevesnj's Avatar
Just make an appointment and tell them about the TSB. I don't think anyone on here has been denied this fix.
Old 01-05-2017, 10:57 AM   #224
Well stubborn at any rate.
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 06:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
