Drives: Toyota GT86
Resources for NA high performance engine builds?
Does anyone have links to any NA engine builds on here?
Some general questions: How much is it possible to increase the bore on the FA20? Any tips on what to go for in terms of donor engines? Would an engine that's thrown a crank bearing be a good candidate or something to avoid? With what (general ballpark) costs should one calculate for components alone? Would 250 crank hp be achievable on pump gas?
#2 |
Drives: Rb25 neo brz
Hey there,
As a rule of thumb we like to see a max overbore of 1mm. Obviously that is a very small change so there isn't much to be gained there. As far as a donor goes look for a motor that had an issue with the heads but make sure the bottom end is perfect. its much cheaper to find a set of perfect heads by themselves. Ballpark on components can be from 2500 for the lowest of low-end to 5000 being all the bells and whistles. That HP level on pump seems too optimistic due to the amount of compression you will need to make it. |
| The Following 5 Users Say Thank You to -Phil For This Useful Post: | Cole (12-15-2016), D_Thissen (12-16-2016), new2subaru (12-15-2016), Teseo (12-15-2016), Tor (12-15-2016) |
#3 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | D_Thissen (12-16-2016) |
#4 | |
Drives: 2004 Toyota RAV-4 5M
At some point in the not so distant future I would like to do an engine build of some sort. I'm competing in NASA's ST/TT4 class which has a power to weight ratio of 12 lbs per avg wheel hp and right now I'm at more like 13.3 making about 195whp avg (205 peak) and 2600lbs competition weight. I'm pretty much out of things to do to make the car lighter without spending obscene amounts of money for dry carbon replacement pieces so I would really like to be able to add like 20whp to the car. I feel like that should be possible to do with an NA build on E85 with some valvetrain work, cams, and a better intake manifold (the Jun one shows some promise for opening up higher RPM range). That being said, no one has been able to make much more than the 205whp that I currently make that I know of, or if they have they haven't shared their results yet. Just trying to figure out if making 220-230whp is feasible in an NA FA20. |
#5 |
I would say 220-225 with 13.1 compression with e85, ethanol is pretty much required due to the compression you are going to run. any compression above 13 is out of my knowledge on these motors.
#6 | |
Hey there, That's mostly correct when you do the cams you'll need to work somewhat closely with Carrillo ( my preferred company for custom pistons ) so that they may make it clear the valves and keep the size of the piston reliable. you really are going to need a custom 13.1 compression piston/cams and most definitely and most importantly e85. @celek is doing a more extreme form of an N/a Build check him out. |
| The Following 3 Users Say Thank You to -Phil For This Useful Post: |
#7 | |
If you go with the average dyno for stock non 2017+ cars, they get about 165whp from 200hp. If you take that loss and apply it to 250hp, that's about 206whp. You should be able to get almost there with an ACE header, full exhaust, good intake and a good tune. People have hit 199whp on california 91 with the ACE header, getting a couple more on 94 octane should be doable.
| The Following User Says Thank You to wparsons For This Useful Post: | D_Thissen (12-16-2016) |
#8 | |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | wparsons (12-16-2016) |
#9 |
AutoX-10/10ths every run
Blue Moon Performance built me a forged internals and WPC coated motor that has been bulletproof. They have also built a number of NA and FI FA20 race motors for competition use as well as building a number of motors for professional race and drift teams. I'd shoot them an email and see what they suggest.
http://bluemoonperformance.com/
#10 |
I'm holding out for 4Piston.com to start building long blocks for us. Or at the very least develop a killer head program. I can build my own short block.
#11 |
Back in the day to tweak more HP out of an engine was to build a stroker. But the new modern engines (Japanese) are built to such tight tolerances and engineered to tight specs a stroker just may not be worth the cost. Saying that, and when we didn't have the money to stroke out a V8 we had other things done such as;
Head port and polish Changed the intake to a higher flow Larger carb to match the extra air going in. Holley double pumper Auto trans was rebuilt with tight clutches, higher performance Torque Convertor, shift kit (to "chirp" second gear with), trans cooler and best fluid we could find Rear gears went from 3.23 to 4.11 or 4.56 if you're brave enough AC delete Larger Radiator Cooler thermostat Headers and Borla Mufflers Now a lot of that is still applicable to todays cars but the fuel air stuff probably won't be effective without telling the computer you're getting more fuel and air. For me I'm going to do a lot of these things over the next 1-4 years. That's the fun with these cars. Trying something different. Trial and error.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | Cole (12-16-2016) |
#12 | |
![]() (BTW, you forgot the high lift cam ..... )humfrz |
#13 |
...Just add nauseum
Drives: 2003 (AP1) S2000
There are many ways to displace.
-Spartarus |
| The Following 4 Users Say Thank You to Spartarus For This Useful Post: |
#14 |
Oh yeh, I had a 66 327 with a solid cam and lifters. That thing loved to rev.
| NorCal shops for engine builds? | Cacksta | Northern California | 5 | 03-06-2016 12:30 PM |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 09:23 PM |
| Engine Builds-Reviews | tg_1981 | Forced Induction | 17 | 01-13-2014 05:19 PM |
| Engine Builds-reviews | tg_1981 | Engine, Exhaust, Transmission | 3 | 01-12-2014 09:14 PM |
| High performance and race engine oil tests | Kamran | Tracking / Autocross / HPDE / Drifting | 16 | 02-10-2013 12:06 PM |
