Old 09-02-2016, 05:07 PM   #1429
CaptivaBlueTeg
Drives: WRB Brz
Would anyone be able to take a look at my datalog? I'm waiting to hear back from motoeast but want to make sure it's running safe and get some advise.
kraftwerks supercharged with UEL header and catback.
Capture contains 3rd gear pull and the other where the rpms stick at 2k when the clutch is disengaged going to a stop. Takes a few seconds after stopping to go down.
When doing normal driving, I notice a drop in power from 2.5k to 3k. Haven't captured that but it's noticeable. Working on that capture.
Thanks in advanced!
CaptivaBlueTeg is offline   Reply With Quote
Old 10-25-2016, 11:06 AM   #1430
Tvars
Tvars's Avatar
Drives: Firestorm
Hey Everyone,
Purchased my OFT this past weekend.Thanks Shiv!
On stage1 93Oct. Hopefully a UEL header in the near future.
I have been doing as much reading as i can to learn about the tuning process. Still trying to learn what correlations to look for.
Could someone shed some light on what I am looking at: http://www.datazap.me/u/tvars/102420...l?log=0&data=1
Tvars is offline   Reply With Quote
Old 10-28-2016, 10:52 AM   #1431
Silver86K
Drives: Silver 86
Hi All,
Running a Stage 1 OFT Tune on our local gas which is only 95 ron here in SA. I have been working on getting this tune dialed in but I am struggling with the AFR. AFR is always running a little leaner then the Commanded AFR. I have tried absolutely everything and cant get the AFR to get rich or very close to the commanded AFR.
It's getting close, just want to find out if this is looking okay? Cause I dont know what to do anymore
Here is a log:
Was about 30'C out, 3rd gear 2 pulls
http://www.datazap.me/u/86driver/281...16-20-28-31-34
Silver86K is offline   Reply With Quote
Old 10-28-2016, 03:43 PM   #1432
phrosty
AFR is close enough to target and there's no knock. I'd call it a day, you done good.
phrosty is offline   Reply With Quote
Old 10-31-2016, 09:03 PM   #1433
RichardJ
RichardJ's Avatar
Drives: 15' FRS
http://datazap.me/u/richardfrs/jdl-u...data=1-5-12-13
GUYS I'm fairly new to this so please refrain from bashing due to my ignorance.
I have installed the JDL UEL and tuned it with OFH specific tune with the VVT tables posted by Shiv somewhere.
I datalogged today (2-7k pull) and I am getting one instance of -0.7 knock correction and EXTREMELY varying FLKC during the pull. (This is very bad right)
IAM Seems to be at 1.
For fuel I am using Shell vpower 91. The only higher grade (which is debatable) fuel here is Petro 94.
ANY HELP IS APPRECITED!! Should I switch to the OTS Stage 2 tune?
RichardJ is offline   Reply With Quote
Old 11-03-2016, 01:48 PM   #1434
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If you're running a catless header you should be using a stg 2 tune. Not sure how fresh your flash is in that log but you've got flkc from 3500 to 6800. It's not a terrible amount but pretty consistent all the way to redline. You may want to log some more with multiple pulls to redline in 3rd gear for more data. I'd also log some pulls under warmer conditions just to see if it will pull even more timing. You could pull about 1/2 a degree here and there at high loads to reduce FLKC, but I'd do some more logging before making changes. Good luck.
Intent > Content
Old 11-03-2016, 10:35 PM   #1435
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Thanks for the reply!
I thought the car was running real bad so for now I switched to the off the shelf stage 2 tune. Before I was using the OFH specific stage 2 tune.
I will do some more logging but this time I'll up the fuel to petro 94 and see if that helps. Thank you very much for your input!
Old 11-04-2016, 11:24 PM   #1436
solidONE
solidONE's Avatar
No worries. The logs I've seen with folks running the OFH specific tune using non OFH UEL headers have been prone to some knock without modification to the ignition advance tables, including the JDL headers. Not sure if the same can be said with OFH + OFH tune setups, but it does look to be more aggressive than the standard stg2 UEL at the upper rev range.
Intent > Content
Old 11-05-2016, 03:57 PM   #1437
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
In case someone gets bored and wants to take a peek.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 12-03-2016, 09:13 PM   #1438
Blue_Elite
Drives: 2016 Asphalt FR-S, 2008 E90 335i
Hey everyone. Brand new OFT tablet user here. I have the Stage 1 US 91 tune loaded currently. Attempted to do some data logging but I have some very weird values... ie IAM pegged at 0. I made a few logs and they all show the same.
I swear I saw a similar issue in another thread and that a template update solved the issue. I cannot seem to find said thread however... If somebody could take a look and point me in the right direction I would be very grateful.
http://datazap.me/u/jevenson123/log-...0&data=1-11-12
* Edit *
After some more research, it appears OFT may not yet support proper data logging for my CAL ID. F00C. If someone could chime in just to make sure I am not crazy...
Blue_Elite is offline   Reply With Quote
Old 12-14-2016, 10:14 PM   #1439
Amputechture
Drives: 2014 BRZ
If anyone is feeling generous and could give me any pointers. Advance Multiplier keeps dropping to .75ish after a few days, this is a 3rd gear WOT pull minutes after a fresh reflash. Shell 93 Octane, no boost leaks and/or pre-turbo exhaust leaks. Thanks in advance!
http://www.datazap.me/u/kevinlebrun8...ot?log=0&data=
Amputechture is offline   Reply With Quote
Old 12-14-2016, 11:52 PM   #1440
phrosty
Your log is broken; re-upload it removing the lines starting with # at the beginning of the file.
Old 12-15-2016, 10:39 PM   #1441
Amputechture
Drives: 2014 BRZ
Thanks man. I can't figure this fucking site out to save my life. What lines starting with # are you referring to, could you possibly send me a screenshot?
Old 12-19-2016, 05:50 PM   #1442
504
504's Avatar
Drives: 2014 86 GTS
Hi All,
Im just refining my e85 tune (actually using eflex e70ish relatively consistent) and am slightly confused where the car has -6 LTFT but shows the afr is lean in relation to commanded afr. Fuel trims are pretty good most of the time but spike to a supposed rich -8% at times probably due to my maf scale and myself trying to keep it perfectly smooth. actual AFR is 15.7 with commanded being 14.6 with the negative spikes, though on most of the log its ok
I'm using Waynos v111.2 e85 stage 2 tune with my scaled maf (trims used to get to -13% with the supplied maf)
Let me know what you guys think
504 is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
