Old 12-11-2016, 08:09 PM   #99
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Avoid:
Too loud
Too low
Too wide
and
anything that is not "turn key" reliable.
I have been modding cars for a long time and these are my tried and true lessons learned from the school of "Mistakes Made".
All these things get old really fast and then it cost money to undo them.
The other thing is; never, ever expect to get the money back that you have spent on mods.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 6 Users Say Thank You to Rampage For This Useful Post:
Adam_L (12-02-2018), FX86 (12-13-2016), Mr.Impreza (12-12-2016), RallySport (12-02-2018), Tcoat (12-11-2016), yberther (12-12-2016)
Old 12-11-2016, 08:24 PM   #100
Tokay444
You mean, what I paid for my mods isn't directly added to the value of my car? BLASPHEMY!
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
Adam_L (12-02-2018), FX86 (12-13-2016), Rampage (12-14-2016), Tcoat (12-11-2016)
Old 12-11-2016, 09:56 PM   #101
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by kch View Post
Just replacement bulbs. They blind people. I just wanted the color to more closely match the headlights.
We have to face the facts: bright white fogs do nothing but increase the effects of the vision-limiting fog itself. Optically, the fog is somewhat reduced only with yellow light. It reduces the scatter from the red and blue sides of the spectrum and penetrates the mist a little better. Matching your fogs to the color temp of your headlights is foolish, not to mention rude to your oncoming drivers.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
The Following User Says Thank You to pfaffendorn For This Useful Post:
Tcoat (12-11-2016)
Old 12-11-2016, 10:15 PM   #102
kch
Senior Misanthrope
kch's Avatar
Oh totally. But it doesn't get foggy where I live, and I hated seeing the yellow foglights.
They never get used at all anymore.
Old 12-12-2016, 01:05 AM   #103
nocoolname
Originally Posted by Rampage View Post
Avoid:
Too loud
Too low
Too wide
and
What is this "too loud" thing you speak of?
nocoolname is offline   Reply With Quote
The Following User Says Thank You to nocoolname For This Useful Post:
Old 12-12-2016, 01:14 AM   #104
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
I hate the mod where you grind your wheels on the curb. Avoid!!!
softgrip is offline   Reply With Quote
The Following User Says Thank You to softgrip For This Useful Post:
Tcoat (12-12-2016)
Old 12-12-2016, 01:39 PM   #105
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Nuh uh! That's a great way to reduce unsprung weight!
Sent from my SM-G930W8 using Tapatalk
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
Ultramaroon (12-13-2016)
Old 12-13-2016, 11:51 AM   #106
jochfr
jochfr's Avatar
Drives: 2015 BRZ Limited - Ice Silver
Originally Posted by Poodles View Post
1) Yep, terrible investment (and potentially damaging).
2) There's a lot of cheap lips available on the forums that fit great. Just buy from someone reputable.
3) Can be resold for nearly as much as you bought it for. Totally worth it for that alone.
4) Depends. Factory fogs aren't even visible on the BRZ, so an LED assembly gives you functional fogs. Dunno what you have though...
Depends on the quality. If they used a proper UV stabilized gel coat it should be fine. Most don't though, so getting it properly cleared would alleviate that issue.
Hell, I'd bump that up to $1600. Factory stuff was heavily tuned from the factory and anything less is only going to hurt handling...
YES. The only exception would be ones with dust boots, but those are rare. If you're not inspecting these, you're risking your safety.
Likely wouldn't matter because of the way the hood works. You're more likely to have issues with CF hoods...
Some actually LOST power from what I remember. Long gone are the days of the K&N intake that adds tons of power, the OEM's actually put time into making good intakes because the engine will be more efficient.
Ok, who let the troll out?
Anyway, my additions:
- One piece driveshaft.
- LED's in the door lights as it could blow the body control module (exception would be the version that replaces the entire assembly).
- Metal shift knobs (unless you live somewhere that never gets hot...).
- Most CF hoods. Unless you need some kind of ventilation, the factory hood is lighter.
- Nitrogen in your tires.
I made that mistake... Cold as hell in the winter and hot af in the summer.
about to put my oem one back on.
My car came with Nitrogen in the tires when I bought it... Should I change that?
jochfr is offline   Reply With Quote
Old 12-13-2016, 12:02 PM   #107
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
WAIT! You haven't changed to WINTER nitrogen yet?!?
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
gramicci101 (12-13-2016)
Old 12-13-2016, 05:06 PM   #108
kch
Senior Misanthrope
kch's Avatar
Nah, it's fine.
Old 12-13-2016, 05:08 PM   #109
Nah, it's fine.
Remember the Hindenburg!
I know I know I just like that joke
Guru Woodman (12-14-2016), Ultramaroon (12-13-2016)
Old 12-13-2016, 05:52 PM   #110
FX86
it's a great way to fix your alignment
The Following User Says Thank You to FX86 For This Useful Post:
JD001 (12-14-2016)
Old 12-13-2016, 06:22 PM   #111
justatroll
justatroll's Avatar
If the tires stick out past the rim of the wheel (like intended) that wont happen.
Old 12-13-2016, 06:24 PM   #112
softgrip
Nah, I did it to my stock 2016 BRZ. Easy to do.
The Following 2 Users Say Thank You to softgrip For This Useful Post:
86TOYO2k17 (12-02-2018), Kendallkab (12-31-2016)
Safe mods to avoid warranty- feedback/experience? slags BRZ First-Gen (2012+) — General Topics 8 09-19-2014 01:05 PM
Can't avoid the curse. Tried. D4S Mid-Atlantic 16 06-23-2014 11:29 AM
What sites do you avoid if you are %$@*! merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 6 07-05-2013 12:55 PM
For those in NC avoid this red FRS Zgrinch Southeast 2 05-19-2012 03:30 PM
