#29 |
Last Starfighter
Drives: 2016 FR-S Series 2.0
The issue with the FB oil pan is the size. No one has verified that FR header will fit over it. It was designed for their headers. Blitz makes an oil pan with a return line welded and it looks like in this right place but no one has verified that. The oil lines are setup specifically for you to weld an AN fitting to your pan. So there are options but YMMV. Lots of people run front mount turbos with no real issues. Your AC can suffer in extreme climates and an oil cooler is recommended for extreme use (heavy track).
#30 |
#658
Drives: '13 FR-S 10 Series
That makes sense. I've been researching this kit and I really like what it has to offer. I'm just not a fan of having to weld a fitting on/cutting into the radiator support. I would definitely get an oil cooler when I go forced induction.
#31 |
Last Starfighter
I agree. The cutting isn't optimal. There are some solutions out there that don't require that but I still feel this kit has some of the best tech and response around. Lots of options out there though!
#32 |
#658
Sorry for all the questions, I appreciate the help though. Is there any performance gain or engineering reason for the intercooler piping to come out the top forcing you to cut the support beam as opposed to an intercooler like the ptuning one or a universal mishimoto? Just curious haha. The twin scroll turbo is my favorite part about this kit and I'm having trouble justifying any other kit besides ptuning.
#33 | |||
Drives: BRZ, STI, GT350R, Supra, 987.2
.Thanks, Eric |
| The Following User Says Thank You to VerusEric For This Useful Post: | olsonpg (12-10-2016) |
#34 |
Drives: BRZ. R34 GT-T
I'm so pumped to get this kit. Should be putting an order through within a few weeks. Finally decided on going with the 7163 .80.
I love these new Borgwarner turbos. Truly next level tech.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
| The Following 2 Users Say Thank You to olsonpg For This Useful Post: | djwishbone (12-13-2016), VerusEric (12-10-2016) |
#35 |
#658
Wow, great information. I appreciate the help, you answered all of my questions!!
| The Following User Says Thank You to FR-S10Series For This Useful Post: | VerusEric (12-12-2016) |
#36 | ||
.Quote:
Thanks, Eric |
#37 |
Drives: 91' 240sx
does the fp fit both auto and manual trans
#38 |
#39 |
Drives: 91' 240sx
oh ok thats good, some people say that 3" fp's wont clear that auto
"What's Life Without Big Dreams" Instagram: @dv8_photography
#40 |
Last Starfighter
@Joeyk Did you route both of your coolant lines up? It looks like FR shows pictures of it routing down under the turbo towards the radiator side, but it looks like it would be dangerously close to the exhaust manifold. I'm guessing that's why you routed yours over the top of the turbo? Also, did you use any special tools to tighten the turbo bolts? I'm not sure exactly how to get to those back ones to properly torque them down.
#41 |
Drives: Corsa VXR Stage 3
@VeloxEric thanks a lot for the thread, I wasn't even aware borg wargner was doing turbine for the consumer aftermarket, I always thought they did partner only with manufacturer and racing team. I do love the one that came stock on my car :-)
I have a few question for you. Does the kit come or could work with UEL header? Also, not completely related but nice to know would you be able to help me out with this question? Thanks a lot. |
#42 | ||
Turbo placement isn't massively important. Keeping hot, fast moving exhaust hitting the turbine is a big goal, as is ensuring that the turbo can properly drain the oil from its CHRA. Hope that helps some. Thanks, Eric |
| Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2639 | 04-05-2026 10:31 PM |
| Full-Race Motorsports | White_Lightning | Forced Induction | 259 | 04-11-2017 01:04 AM |
| best turbo kit - currently Full Race? | TEAM SCION | Forced Induction | 41 | 10-14-2016 08:41 PM |
| Full Blown Motorsports turbo kit exhaust question. | Jtbirchfield | Forced Induction | 2 | 09-09-2015 04:19 PM |
| Full blown turbo kit owners | Joeycokeboy | Engine, Exhaust, Transmission | 2 | 09-02-2015 09:49 PM |
