Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-10-2016, 02:20 PM | #29 |
Thupercharged
For a Dr., your bedside manner is questionable
Patient: doc I broke my leg, halp me Dr: lol rekt
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
The Following 3 Users Say Thank You to DJCarbine For This Useful Post: |
12-10-2016, 04:33 PM | #30 |
hey you, yeah you <3
Drives: 2014 37J FR-S
I agree on transmission oil flush. Check for metal in fluid.
If you really don't wanna do anything, then dealer warranty. Go go.
12-10-2016, 04:58 PM | #31 | ||
...Just add nauseum
Drives: 2003 (AP1) S2000
Changing the fluid will not fix broken parts. Doesn't matter what variety of snake oil you put in there.
People say it all the time in Manual transmission threads, because they don't understand how manual transmissions work. Most people do not give sound advice about manual transmissions because they lack technical understanding. This is roughly equivalent to telling you to "change the engine oil and see how it runs" if you had dropped a valve. ... F*ck. You broke the baulk ring mechanism. That was the pop. That's why it's "crunchy" on the way in to gear. It's fine, everybody makes mistakes. Replacements are cheap. If this transmission grinds on the way into gear, in any gear, during a normal shift, something is broken. That's what the baulk ring mechanism in this transmission does. It prevents gear engagement until the synchro sleeve and gear are moving the same speed, and partially locked together. It can't grind. If it does, metal parts are broken.* All of the gears (There are more than 6) are in constant mesh, they don't slide in and out. The only things that slide in this transmission are the engagement sleeves, over the engagement teeth. No teeth are "chipped." The engagement teeth can be chipped, but that's impossible unless you first break the baulk ring mechanism, and then continue to shift until one chips. Either way, "chipped teeth" don't cause grinding on shifts. If the baulk ring mechanism is functioning, everything is already locked at the same speed before anything ever slides over anything else. *If it is first engaged, and then carefully half-disengaged with the clutch draging, you can make a correctly functioning transmission in this car grind, but that's for argument's sake, and can't happen on a normal shift. There are 2 distinct steps for every gear engagement. You should be able to feel them. Quote:
With the baulk ring mechanism broken, the car will shift into that gear fine most of the time, but you'll wear the engagement sleeve, the engagement teeth, and the synchro rings out at an accelerated rate. The grinding will get worse until the gear becomes virtually unusable. It's a god damn Toyota though, that wear could take 100,000 miles to happen..
There are many ways to displace.
-Spartarus Last edited by Spartarus; 12-10-2016 at 05:15 PM. |
The Following 5 Users Say Thank You to Spartarus For This Useful Post: | CxG (01-12-2017), DJCarbine (12-11-2016), headlikeahole (12-10-2016), jcw99 (12-27-2016), Ultramaroon (12-11-2016) |
12-10-2016, 09:45 PM | #32 |
Huge E85 fan!
Drives: 2016 Scion FRS
I don't think they are saying to change the fluid to fix it but to see if there's metal in it and to remove anything to do further damage.
You're right, the tranny itself is a big mystery to most humans. It's an oddly shaped box of magic and the stick is the wand. |
The Following 2 Users Say Thank You to guybo For This Useful Post: | Spartarus (12-11-2016), Ultramaroon (12-11-2016) |
12-11-2016, 04:56 AM | #33 | |
Thupercharged
Plenty of car enthusiasts can drive or have a willingness to learn manual, but there are a lot more people who view their car as a tool and the easiest it gets the job done, the better. Can't fault that.
2013 FRS
The Following 2 Users Say Thank You to DJCarbine For This Useful Post: | jcw99 (12-27-2016), Ultramaroon (12-11-2016) |
12-27-2016, 08:35 AM | #34 | |
Drives: 2013 Subaru BRZ Limited (Black)
Life is too short to worry about little things like this for me. Thankfully used transmissions for this car are cheap! Either way, I'll monitor it and act appropriately. |
12-27-2016, 10:09 AM | #35 |
Drives: frs
Sorry the urge beat me. Still have grinding noises when driving normal ? |
12-27-2016, 10:12 AM | #36 |
be glad you blew a synchro and not a tranny
The Following 3 Users Say Thank You to FX86 For This Useful Post: |
12-27-2016, 02:08 PM | #37 |
The Stig's German cousin
I've had light crunches come and go with this transmission, especially early on. Honestly I wouldn't worry until it makes really bad noises. There are no shortage of "wrecked while drifting" twins in junkyards with perfectly good transmissions you can use when yours fails after 100k or whatever.
Change your fluid in case you got metal bits floating around and move on. |
12-27-2016, 02:43 PM | #38 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
12-27-2016, 03:16 PM | #39 | |
Thanks, humfrz |
Similar Threads | ||||
Synchro issue? and Dealership woes. | lextrueno | Issues | Warranty | Recalls / TSB | 31 | 05-28-2017 02:16 PM |
Synchro issue | zypher10 | Issues | Warranty | Recalls / TSB | 10 | 02-18-2016 12:56 PM |
Double Clutch vs Synchro wear | Concorazon | Engine, Exhaust, Transmission | 72 | 12-10-2015 03:16 PM |
5th gear synchro harshness? | Subie | Issues | Warranty | Recalls / TSB | 28 | 05-29-2013 04:22 PM |
Will FT-86 have Synchro Rev Match? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 05-27-2010 11:05 AM |
