| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | |
86
I have found a set of ramps is really handy for oil changes, just drive up and go, no jacks required.. |
#30 | |
veal cordon bleu schnitzel beer battered & fried deep fried in beer marinated overnight in beer oven roasted, basted with beer BBQed, basted with beer/catsup veal and eggs veal burgers veal meatloaf veal meatballs ![]() humfrz |
#31 |
Drives: 2013 Pearl White 6MT
I worked on a few cars I had once and those experiences were enough to hunt out people to do it. I found I didn't have it I had to buy it, take old krap off it breaks or its rusted apart or whatever, I had to go buy it. Took my brakes apart once, caliper had siezed, had to buy them, couldn't find them, had to order them. And I'm not into working on cars. I have a job, I don't want another. My job pays me enough to pay others to do the work. But I know its a hobby for some, but not me, I have hobbies too. How I handle oil changes, online, toyota, make apointment, show up, read a magazine or surf the internet while folks do the oil changes. Done, pay out
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#32 | ||||
Only happy when it rains.
Drives: series.blue
Hey everyone, thank you for all the info. Oh my, so much to ponder. I think my brain is full.
![]() Quote:
I didn't even think of minimum jack height, especially as my car seems to be a little lower. Or that might be my imagination. This will be interesting to find one low enough. Good catch. Time to go get my tape measure. Okay it looks like it is about 5". Maybe a bottle jack will not work. Taking pictures is a great idea I would never have thought of. Quote:
So swarb made a good point about the car's height being only 5", so maybe I might have to use the jack that came with the car for now. So when it comes to sockets and ratchets, do I really need all three sizes like this kit? Or would the automotive sockets all be 1/2 inch? And while I have the tools for the locking lug nuts, are normal sized lug nuts just a standard socket wrench size? Oh and then torque wrenches. It is odd I always spell it the british way and then have to delete the extra "u". Oh my tool overload. And this wrench even has a video. Thank you for all that info. I just have to reread if a few times, digest everything, and then get to buying and figuring everything out. That was so helpful. Quote:
#33 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
One bit of advice I'll give, that may be disagreed with, is to not use the car's jack except in emergencies. It isn't really designed for regular use, more for those few times (hopefully only ever once, preferably never) you need to quickly lift the car to change a flat tire. I wouldn't use it on a regular basis to lift the car for maintenance and have it possibly fail on you.
Tough thing having to work in dirt and gravel but a set of rampsbshould help you to access just about everything in the front you'd need to work on. I like the plywood and carport suggestion that was made to you. That seems like a great solution. Harbor Freight isn't a bad place for you to get some decent hand tools inexpensively. I wouldn't buy everything you need from there, but most hand tools you'd need for car work can be found there at decent quality and price. There you'd also find ramps, safety stands, wheel chocks, and bags of rags. Working on your own car turns out to be pretty easy when you take your time and do a little YouTube searching to out your mind at ease, or to even have a live guide to reference while you're working. Someone out there almost always has done a video to show how to do a lot of typical work on most cars. You should check out ChrisFix on YouTube. He does a great job showing how to DIY tons of stuff on your own car. Most important, if you're going to get under your car, no matter what method you choose to elevate it, just make sure you take the necessary steps to ensure it is secure and won't drop down or roll away on you. Don't ever rely on just one method of lifting/securing the car. If one fails for some reason, you have another. Pick up a maintenance manual or two for your car. They'll show you many jobs you can do on your car, tools you'll need, and steps to get it done. As for oil, I found a container at AutoZone that doubles as both a drain pan and storage. You layout flat, open a hole in its upfacing side, and drain. Your fluid. When done, cap the hole and you can store the container upright like a gas can. To empty it, there's a large cap so you can pour it out like a gas can. I think it was maybe $15. To dispose of the oil, see if a local shop will take it (they often burn it for their indoor heater), and also look out for local Hazmat disposal events put on by the town/state and bring them the fluids in something like gallon jugs you have for milk and water. And as always, ask questions of folks like you're doing here. Someone else always has a different spin on things and you can learn something from everyone, even the people who are wrong, lol.
-O/D
2016 FR-S, Hot Lava |
#34 | |
Drives: series.blue
#35 |
^^ Most low profile jacks will fit under the car. When using ramps for oil changes you may run into the car not being level so the oil won't drain completely.
#36 |
Sittin' Sideways
Low profile 3-ton jack at Harbor Freight usually runs about $100, often there are coupons to get it for less, and with both my cars being less than 6 inches off the ground, it serves them both well. Remember, you're not lifting the car at its corners. You basically have one central jack point in front, and one in back. As gravitylover said above, you can get all four wheels off the ground so the car is level and be pretty assured that you've drained all your oil (our drain plug faces straight down unlike a lot of cars that do a side drain). The emergency jack in the car really isn't suited for a lot of uses.
As for the plywood, you could get a bunch of smaller sheets of it to lay out when needed and store them away when done. That will store a lot easier than one giant piece. If you do the car port thing, try to find one that breaks down easily so you can have an easier time putting it away.
-O/D
#37 | |
Case in point, back in the 60s we moved to California and rented an apartment that had 2 bedrooms and a little balcony. Where I worked, I could borrow hand and small power tools. So, I found this full sized oak teachers style desk, which I bought to refinish. So, I disassembled it and took the pieces up to my balcony on the 3rd floor where I would use a belt sander to start the refinish job. My "neighbors" complained of the noise, so the apartment manager made me stop. Well, I was bound and determined to continue the project, so I moved it into the spare bedroom. After I got it all sanded down, I screwed and glued it together ...... real good, I applied several coats of varnish. It looked GREAT! After a few months, we bought a house and when we moved out of the apartment, guess what ....... yep, you guessed it, ....... no way that desk would go through the door......without cutting off the legs ...... ![]() The moral of the story is ........ you guessed it ...... ![]() humfrz |
#38 |
![]() On the flip side, sometimes the fun is in overcoming the obstacles. I lived in an apartment in Chula Vista the last 3 years I was in the Navy. I was bound and determined to build myself a custom guitar but I didn't have a source for dry compressed air. I did, however, and still have all my SCUBA gear so I chatted up a guy at one of the dive shops and scored an old first stage regulator he had on the "back shelf" as well as an adapter for the pipe threads I needed. I used that setup to lay down three coats of color to match the body to the neck and another fifteen coats of clear to build it up. I think I went through three fills so, all in all...
| DeTalks: The Basics | Junkman2008 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 07-26-2016 01:22 PM |
| Why Processing is ESSENTIAL To Sound Quality | TOOSTUBBORN2FAIL | Electronics | Audio | NAV | Infotainment | 38 | 06-03-2016 03:17 PM |
| Boost Control Basics | pixel67 | Forced Induction | 2 | 06-06-2015 10:27 PM |
| Essential roadtrips. | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-18-2013 02:59 PM |
