Drives: car
Question about cold start knock, battery
My car struggled somewhat to start this morning in 31*F weather with a low battery. A couple seconds after cold start the engine did a quick stumble which I could hear and feel and guess it was knock. Note I could hear it knock clearly. Everything else after was ok, car drove really strong all day in the cold temps.
Question is, could the low battery induce a knock situation on a cold start? Last edited by radroach; 12-09-2016 at 08:20 PM. |
#2 | |
Sounds like you should invest in a new battery. Back-in-the-day, on cold mornings, back on the farm, it was always best to hand crank the engine over a few times (with the magneto wire unplugged) before trying to start it. If you didn't and lost your grip on the crank (or fell off the bucket you used to reach the crank) or the engine rocked back about the same time one plug fired ...... you would get a big knock (backfire). Yes, and it was snowing out and tractor was parked on the uphill side of the shed ..... humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (12-09-2016) |
#3 | |
#4 |
Drives: car
@humfrz well I'd rather preserve the battery rather than just throw it away, maybe I could use a battery tender, or booster if necessary?
#5 |
Drives: car
@Ultramaroon there was a noticeable knock sound and the car hesitated. Perhaps it was the alternator clutch kicking in while the car was still starting? Either way it kicked which is abnormal for a start.
#6 | |
#7 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (12-09-2016) |
#8 |
Drives: car
@Tcoat well it's always started slow when temps dropped below 31F. A little boost and voila, good start.
It's the stock Panasonic battery, and it works well enough when its not freezing. Starts quick on other days. |
#9 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
I accidentally left my overhead console light on twice and had to boost the battery with a portable jump starter. I notice that as it's gotten colder the starter seems to crank kind of slow as if the battery is weak - it always starts, but seem to struggle, and on a couple of occasions, the engine ran really rough until it 'caught'.
Any chance our batteries and motors are biplane leftovers? And should the overhead light even drain a battery? In a current year vehicle, don't all lights automatically turn off after a programmed amount of time? Confession, have not researched the owner manual on this. Sorry for the unintentional thread quasi hijack. |
#10 | ||
I have followed these starting and battery issues closely (just ask @Ultramaroon ) and it is interesting that about 8 out of 10 people with premature battery failure or problems starting have BRZs. We see the occasional FRS with issues but they are very rare. Considering there are about 10 times the number of FRSs to BRZs out there that is a very telling number. Now the question that raises is, why? There is something different between the two that is causing either a parasitic draw when shut off or preventing the battery from charging properly when running. I have no theory as to what that is though. It will be interesting to see as the 86 gets closer to the same equipment as the BRZs if the frequency of battery issues increases.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#11 |
It is uncanny. I'm still on the factory battery but I'm also a Panasonic fanboi.
It knows.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (12-09-2016) |
#12 | |
As you know, in an emergency ....... the last thing you want is a car that won't start. Besides, by trading in the old battery, you are "preserving" it ....... it will "live" as parts of a new battery ..... ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (12-09-2016), Ultramaroon (12-09-2016) |
#13 | |
![]() humfrz |
#14 |
No if the light is set to manual on. If on auto then it goes off after a few seconds. Unless of course you leave the door open.
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| (Spark?) Knock on cold start idle | nickw14 | Software Tuning | 0 | 04-07-2015 12:41 PM |
| LOUD KNOCK during cold start | Flat_4_Life | Issues | Warranty | Recalls / TSB | 23 | 03-18-2015 05:30 PM |
| Cold start question | ggiddix | Engine, Exhaust, Transmission | 8 | 02-06-2015 10:27 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
