Old 12-08-2016, 10:32 PM   #1
Zeuseidon
Zeuseidon's Avatar
Drives: 2014 Sterling Silver BRZ
JDL UQFP mated to Invidia Q300 help
Hey everyone just installed my new Q300 and I am having and issue mating it to my JDL UQFP.
I have a massive exhaust leak right at that junction. I assumed it used a flat gasket and installed it with one. Wrenched it down as tight as I could with no results. However, looking at it a second time, is it actually supposed to use the OEM donut gasket/spring bolts?
I bought the JDL used so don't know what that one is supposed to use. But it has flat flange end so looks like a flat gasket is the correct one for that side.
Although, after looking closer at the Q300 mid pipe it looks like it could possibly need a donut gasket.
Zeuseidon is offline   Reply With Quote
Old 12-08-2016, 11:30 PM   #2
Zeuseidon
Zeuseidon's Avatar
I thought I posted this in the "Issues" section. If a mod wants to move it to that section.
Old 12-08-2016, 11:48 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
What exactly are you asking? The JDL UQFP is available with a flange to suit some cat backs or with a donut gasket setup similar to OEM to suit other cat backs. It sounds like you have the wrong combination of the two.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Zeuseidon (12-09-2016)
Old 12-09-2016, 01:19 AM   #4
Zeuseidon
Zeuseidon's Avatar
lol I'm not so good with words. I guess my question is does the Q300 use a Donut gasket?
The JDL pipe I have is for a flat gasket set-up. I used it with my Corsa so I know that at least.
If the Q300 DOES use a donut gasket, is there anyway to mate the two? With and adapter possibly?
The Following User Says Thank You to Zeuseidon For This Useful Post:
Turdinator (12-11-2016)
Old 12-09-2016, 01:34 AM   #5
D_Thissen
D_Thissen's Avatar
Yes, the q300 uses the donut style.
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 12-09-2016, 02:07 AM   #6
Dfyfzx
Drives: JRSC C38 HBP E85 FRS
I'm not aware of an adapter but I'm sure one probably exists. I think worst case scenario, take it to a muffler shop and they can either make you an adapter or modify one of the pieces to work with the other. Won't be pretty, but it's under the car so looks aren't important. Would kill resale on the modified piece, however.
Dfyfzx is offline   Reply With Quote
The Following User Says Thank You to Dfyfzx For This Useful Post:
Old 12-09-2016, 08:31 AM   #7
Zeuseidon
Zeuseidon's Avatar
Thanks guys! That's what I needed to know! If anybody knows of said adapter, as I really don't want to have to weld something onto the Q300.
Old 12-09-2016, 08:44 AM   #8
jasonojordan
Drives: 2013 satin white brz limited
I had this same issue on my 02 wrx. I just cut off the doughnut flange and welded on a flat one.
jasonojordan is offline   Reply With Quote
Old 12-09-2016, 10:56 AM   #9
Dfyfzx
I just did a quick google search for "donut to flat exhaust adapter" and quite a few options pop up. You'll have to find the right one for your piping diameters. Looks like what you need is out there.
Old 12-09-2016, 11:21 AM   #10
Zeuseidon
Zeuseidon's Avatar
I tried a similar search string, but only found 2.5"-3" donut to flat adapter. I'll try your search string. Thanks for the help!
Old 12-09-2016, 12:48 PM   #11
D_Thissen
D_Thissen's Avatar
You could always have a 'v-band' welded on. At least that way, the exhaust wont be one piece.
Old 12-09-2016, 02:03 PM   #12
kch
Senior Misanthrope
kch's Avatar
Worst case scenario, you can find a shop to weld on a flat flange for under $100. I had a shop change my stock catback to flat flange for $80.
Old 03-24-2017, 08:58 PM   #13
jeantue
Drives: 2015 Scion FR-S
I just wanted to mention that I also have a JDL setup up front mated to the Q300 catback, and I also had the leak problem. I solved it for a while myself by using both a donut and a flat gasket. But then it started again. So I took it to a proper exhaust shop who used some nifty flange & clamp parts that they installed for $40 that solved the problem, seemingly for good. We shall see.
Unfortunately, I have a new problem which is that the Q300 is a lousy system. All the supposedly advanced damping material is burned off after a year of driving and it sounds horrible now. This is going to be the subject of a new thread. I'm ultimately looking for a new catback system now, leaning toward Corsa.
jeantue is offline   Reply With Quote
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 10:21 PM
FS: Invidia Catless Front Pipe/ Invidia Q300 Exhaust Parts timmydatooth Engine, Exhaust, Bolt-Ons 27 04-04-2016 10:46 AM
Invidia Q300 catback & Invidia catless front pipe: 2015 Subaru BRZ WhenzLunch Engine, Exhaust, Transmission 5 02-09-2016 11:18 PM
Invidia Q300 and Invidia Frontpipe Installed! Kevin@RAD Engine, Exhaust, Transmission 19 11-05-2013 06:49 PM
FS: Invidia Q300 & Invidia Front Pipe DR1FT Engine, Exhaust, Bolt-Ons 15 06-07-2013 08:29 PM
