Old 11-17-2016, 05:26 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What would be great is some pre and post traction mod videos, data-logs, lap times.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
jeepmor (04-05-2022)
Old 11-18-2016, 03:10 AM   #30
maregt
Drives: Subaru BRZ
What about a stock BRZ with camber bolt? I'd like to be able to step on the gas earlier, but don't want the rear to be too soft as the car is already prone to understeer...
Inviato dal mio Galaxy Nexus utilizzando Tapatalk
maregt is offline   Reply With Quote
Old 12-07-2016, 06:43 AM   #31
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Quick update, After dialling the car in at my last event (a new track) I have now set a PB at Queensland Raceway and was extremely happy with how the car felt into, through and out of corners, I was just loving it.
I have a data log via podium. I'll try and find old lap to compare and we may be able to see something.
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
solidONE (12-07-2016)
Old 12-07-2016, 07:11 AM   #32
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
best i can find to demonstrate:
you can see where full throttle is applied pre and post
Pre traction mod:
post traction mod:
The Following 3 Users Say Thank You to 86•BRZ For This Useful Post:
jeepmor (04-05-2022), softgrip (12-07-2016), solidONE (12-07-2016)
Old 12-07-2016, 11:29 AM   #33
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
What's going on with your logging frequency between those two logs?
GSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
jeepmor (04-05-2022), wparsons (12-08-2016)
Old 12-07-2016, 05:07 PM   #34
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
At a guess one was 10Hz, one was 25Hz.
Old 12-07-2016, 06:16 PM   #35
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Looks like it. Are you able to superimpose speed through the corner? That would be telling as well. I'm not that familiar with the software you're using. Thanks!
Jake
Old 12-07-2016, 06:44 PM   #36
solidONE
solidONE's Avatar
Pre traction mod:
post traction mod:
Yeah knowing how fast you enter and exit pre and post would help too. Looks good though. I'm assuming the dot on the left indicates where you have applied full throttle in the corner?
Intent > Content
Old 12-07-2016, 06:47 PM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
From those logs and description of extra stability & ability to open throttle sooner in curve .. that sounds exactly what i got with slight toe-in in rear. BUT! Our cars have toe adjustability as stock, and that doesn't need any extra parts, one can just ask to deal in when doing alignment. About the only thing that this mod might be better for in my eyes is that not-0 toe increases tire wear.
Old 12-07-2016, 11:00 PM   #38
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The dot is full throttle. There's a million ways to fudge data but it does correlate with what I've been saying.
Old 12-07-2016, 11:28 PM   #39
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
MCA Suspension "Traction Mod"
That's a gross simplification of something that is different. A bit like saying you don't need coilovers if you've got a camber bolt.
Sleepless (05-11-2017)
Old 03-13-2017, 07:01 PM   #40
wootwoot
Drives: FRS
Any one know how much this lowers the rear of the car?
Old 03-13-2017, 10:01 PM   #41
wparsons
wparsons's Avatar
Rear toe in also makes the car less willing to rotate at turn in, this mod shouldn't affect off throttle behavior.
It doesn't, it just changes one of the pickup points to reduce rear anti-squat.
flickr
Old 03-13-2017, 10:30 PM   #42
wootwoot
Drives: FRS
You sure? There are control arms from different manufacturers that have two sets of holes where they attach to the chassis. One set for factory height, one for a 15mm drop. How would changing the pick up point be any different than that? Also, one user already mentioned he had to raise his rear after install...
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 11:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 03:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 10:14 PM
