Old 12-06-2016, 03:47 PM   #15
Originally Posted by Speed2th View Post
parts that you cannot afford and need to finance for it. -> worse financial decision ever
To build on that.
Knockoff offshore parts that seem like the ones you can't afford but really aren't. Hold off for quality instead of jumping on junk just so you can do it sooner.
Old 12-06-2016, 03:58 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
To build on that.
But, But, the widebody kit sitting on the floor of some Chinese warehouse looks totally legit! They claim "perfect fit" right in the add! And only $400 shipped!
What could go wrong!
via Imgflip Meme Generator
Old 12-06-2016, 04:05 PM   #17
Yep that Racket Bummy kit is a bargain. I have had great luck with the Crust toothpaste from the dollar store as well.
Old 12-06-2016, 04:18 PM   #18
DAEMANO
Time Traveller
- Avoid cheap bolt-on spacers. The lug nuts on them can be soft and round out easily. Also, on cheap spacers, the studs can be pressed in not securely enough. If you're going to get bolt-on spacers, make sure to get ones from a reputable mfg or vendor.
- Avoid plasti-dip if you're going to do a shit-job. Use it if you're going to learn, prep, and apply properly. Also avoid it if you have poor taste cause it can look cheap if not part of a cohesive design.
- Avoid external wet carbon fiber parts if you're not going to wax them monthly (for U.V. protection). It needs care to keep from oxidizing.
- Avoid cheap coil-overs (less than $600), they'll fuck up both your ride and handling and will probably wear or break prematurely.
- Avoid rod-ends in suspension parts if you don't plan on servicing them as wear items.
- Avoid the TRD quickshifter kit if you're not ok with using loctite to secure it.
- Avoid hood vents that unintentionally reinforce collision crumple points under the hood. You might regret this (dearly) in a collision.
- Avoid titanium exhaust piping unless you don't mind rasp and noise. They're light, expensive and beautiful, but man are they loud.
- Avoid lowering your car more than 1.6" - 2" in the rear without considering axle/diff geometry. Easiest way to have axle issues (even with aftermarket axles) is to run low without correcting this issue (diff risers work.)
- Avoid custom intakes on N/A cars as they generally don't add any power that a drop-in filter won't also add. Many mfgs that produce intakes compare the stock intake vs. their custom intake + a tune. "Secret" is, most of the 0-10 WHP power gains are coming from the tune not the intake. A Drop-in filter + tune nets roughly the same gains over the stock CAI give or take a 1-3 WHP "margin of error" as an aftermarket intake + tune.
- Avoid the 1st gen Innovate S/C kit (according to some. Personally, idk)
- Anything from vendors that rip on other vendors or try to outsmart customers by spreading FUD about competitors. It's painful to watch them do this. Pet peeve to no end.
- Avoid vendors that don't have a communication process that they stick to. This is tough to find in this industry, but there are vendors that do communicate well and regularly on things like drop-ship, back-orders, and order status.
- OFT is fine if you're not really going aggressive F.I. If you want ECUTek later, OFT's resale reliably for $400.
Old 12-06-2016, 04:19 PM   #19
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
bc coilovers......
pgranberg11 is offline   Reply With Quote
Old 12-06-2016, 04:28 PM   #20
Leonardo
Country Boy 4 Life
Leonardo's Avatar
"Leaves your mouth with that crusty feeling" Mmmmm!
Old 12-06-2016, 06:27 PM   #21
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by kch View Post
4) LED fogs. They look good, but piss people off and I never use them anymore.
Did you just get replacement LED bulbs or the proper housings with proper optics?
Stang70Fastback is offline   Reply With Quote
Old 12-06-2016, 06:29 PM   #22
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Norville Rogers View Post
Mods to avoid.
All of them. It's a car. Most aftermarket stuff is excrement compared to the dull but tried and functional OEM.
You asked
You like the dull but tried and functional OEM Prius tires? Or the terrible OEM base pioneer stereo? How about the OEM speakers? And the OEM hood "wire" to keep it open?
Cause I love my upgrades: MPSS tires, New stereo, Speakers, and hood struts.
Old 12-06-2016, 06:40 PM   #23
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You de man. I can't help staring at you.
Is this answer to just increase your post count?
Was expecting some sort of backup argument for your statement: "all of them".
But OK, uh, Thanks! You da man too!
Old 12-06-2016, 06:47 PM   #24
Stang70Fastback
A.K.A. Starlord
Tell me about your tyres...
Why don't you answer his question first?
Old 12-06-2016, 07:15 PM   #25
Poodles
There are a few mods I've regretted:
1) Pulleys. I don't wanna get into it.
2) Ebay lip. Fit like crap. Waste of money.
3) OFT. Nothing really wrong with it, but I should've just accepted the fact that I'd want ECUtek eventually.
1) Yep, terrible investment (and potentially damaging).
2) There's a lot of cheap lips available on the forums that fit great. Just buy from someone reputable.
3) Can be resold for nearly as much as you bought it for. Totally worth it for that alone.
4) Depends. Factory fogs aren't even visible on the BRZ, so an LED assembly gives you functional fogs. Dunno what you have though...
Depends on the quality. If they used a proper UV stabilized gel coat it should be fine. Most don't though, so getting it properly cleared would alleviate that issue.
Hell, I'd bump that up to $1600. Factory stuff was heavily tuned from the factory and anything less is only going to hurt handling...
YES. The only exception would be ones with dust boots, but those are rare. If you're not inspecting these, you're risking your safety.
Likely wouldn't matter because of the way the hood works. You're more likely to have issues with CF hoods...
Some actually LOST power from what I remember. Long gone are the days of the K&N intake that adds tons of power, the OEM's actually put time into making good intakes because the engine will be more efficient.
Mods to avoid.
You asked.
Ok, who let the troll out?
Anyway, my additions:
- One piece driveshaft.
- LED's in the door lights as it could blow the body control module (exception would be the version that replaces the entire assembly).
- Metal shift knobs (unless you live somewhere that never gets hot...).
- Most CF hoods. Unless you need some kind of ventilation, the factory hood is lighter.
- Nitrogen in your tires.
Old 12-06-2016, 07:18 PM   #26
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Speaking of tires....
I installed mismatched tires front and rear. Michelin front and Nitto rears. The TCS and VSC would activate around every corner. Took the Nittos off the next day, installed Michelin tires, fixed the problem.
So, I would avoid having grossly mismatched UTQG's. I now have had 30 tires on my car.
Old 12-06-2016, 07:25 PM   #27
Or cold. (if you ever got your moist hand stuck on a steel shift knob you know what I mean)
That is an odd number!
Old 12-06-2016, 07:55 PM   #28
radroach
Drives: car
I'll add headers from overseas that won't have good support. There's people who've had their aftermarket headers crack, but they had support / rep in their country so we're able to get warranty / replacement.
On the lightweight crank pully, it's always interesting opening a thread for someone who spun a bearing and the lightweight pully is the first thing mentioned.
Safe mods to avoid warranty- feedback/experience? slags BRZ First-Gen (2012+) — General Topics 8 09-19-2014 01:05 PM
Can't avoid the curse. Tried. D4S Mid-Atlantic 16 06-23-2014 11:29 AM
What sites do you avoid if you are %$@*! merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 6 07-05-2013 12:55 PM
For those in NC avoid this red FRS Zgrinch Southeast 2 05-19-2012 03:30 PM
