Old 12-04-2016, 01:37 PM   #1
Blue_Elite
Drives: 2016 Asphalt FR-S, 2008 E90 335i
OFT Logging Issue
Hey everyone. Brand new OFT tablet user here. I have the Stage 1 US 91 tune loaded currently. Attempted to do some data logging but I have some very weird values... ie IAM pegged at 0. I made a few logs and they all show the same. <br />
<br />
I swear I saw a similar issue in another thread and that a template update solved the issue. I cannot seem to find said thread however... If somebody could take a look and point me in the right direction I would be very grateful.<br />
<br />
http://datazap.me/u/jevenson123/log-...0&data=1-11-12<br />
<br />
* Edit *<br />
After some more research, it appears OFT may not yet support proper data logging for my CAL ID. F00C. If someone could chime in just to make sure I am not crazy...
Sent from my SAMSUNG-SM-G870A using Tapatalk
Blue_Elite is offline   Reply With Quote
Old 12-04-2016, 03:24 PM   #2
steve99
Drives: FT86
Yes I believe that is correct.
Old 12-04-2016, 03:32 PM   #3
Blue_Elite
Thats a shame... Its going to be difficult to dial in my stage 2 uel tune when my jdl header arrives.
Guess I will start emailing open flash find out if an update is in the pipeline.
Old 12-04-2016, 05:05 PM   #4
steve99
Drives: FT86
The older B01C rom will run fine in the F00C cars, you will need to get the oft guys to calid hack a B01C rom and def so it looks like a F00C for you then logging will work fine
Old 12-05-2016, 05:15 AM   #5
fibble
Drives: 2015 86 GTS
Good luck! I have emailed OFT a number of times on the issue over approx 6 mths with no response. A case of product good, service abysmal.......
I hope you have better luck. Everyone can redeem themselves, so if you make progress let us know.
If you don't have any immediate luck, follow Steve's advice.
fibble is offline   Reply With Quote
The Following User Says Thank You to fibble For This Useful Post:
Lonewolf (12-07-2016)
Old 12-05-2016, 03:08 PM   #6
Blue_Elite
Everything I have read lines up with you said so I wont expect any miracles.
Also please excuse my ignorance, but how would I going about getting a B01C rom hacked to look like a F00C rom? Would the defs need to to be edited?
Old 12-05-2016, 09:21 PM   #7
fibble
Drives: 2015 86 GTS
I recommend PMing Wayno and see if he can help out. Throw some cash his way and you will hopefully gain access to a range of base maps tuned to your application.
Lonewolf (12-08-2016)
Old 12-07-2016, 11:38 AM   #8
Blue_Elite
Problem solved. Thanks for the input everyone.
Old 12-07-2016, 07:03 PM   #9
fibble
Drives: 2015 86 GTS
How did you solve? Just interested......
Old 12-07-2016, 07:41 PM   #10
Blue_Elite
Exactly how you suggested I should! If anyone runs into similar issues, definitely PM Wayno.
Old 12-09-2016, 03:19 AM   #11
fibble
Drives: 2015 86 GTS
OP2 logging discussion AdrianG Software Tuning 37 10-06-2017 01:41 PM
How are you logging at the track? yomny Tracking / Autocross / HPDE / Drifting 42 04-23-2015 11:16 AM
OFT where do you put it when logging? TStafford Software Tuning 14 08-27-2014 08:57 AM
IAT logging, what are you guys seeing? BRZPDX Forced Induction 3 03-02-2014 01:59 PM
